Help with USB Hub design
Hi there,
I'm creating a new project that includes an Arduino (USB 2.0) and a USB 3.0 device. The Arduino and USB 3.0 device don't connect to each other, they just need to be on the same upstream USB port. Now I need a hub controller for both of these devices to go into, however, USB 3.0 Hubs are hard to come by. Got me thinking, do I necessarily need a USB 3.0 hub chip or can I get away with just a USB 2.0 hub controller? Therefore, the USB 2.0 data lines will go into the controller and the super-speed USB 3.0 data lines will go straight from the USB upstream port to my USB 3.0 device. Will this still work as intended? Or does the super-speed USB 3.0 data lines need to go into a controller as well so that the two USB devices are controlled separately?
Many thanks for any advice.
I said USB a lot there lol
I'm not sure if I understand what you want to achieve or what your problem is. Do you want to design your own hub? Or is this about of-the-shelf hubs?
USB3 devices will work when connected to USB2 ports on a PC so I guess that they will also work when connected to an USB2 hub.
Problems have been reported with Arduinos connected to USB3 ports on the PC; advise in that case was to use a powered USB2 hub.
Hi Callum, I had an issue with a nano that wasn't detected on my computer when connected to a USB 3 port. Maybe there is a way of fixing the arduino to work with a USB3 port then you could splice the leads together and connect them to a single USB3 port?
potential new drinking game?
Hi all,
Really sorry for not explaining this very well, I want to design my own USB hub on my own PCB.
Wasn't sure where to post this question, whether it be on the Arduino forums or any other forum thats on the WWW.
@flackattack at this point, I might as well turn it into a drinking game, buying anything electrical based at the moment is like trying to dig for gold, driving me crackers.
Well, you can always try, but it clearly has nothing whatsoever to do with Arduinox! :pleading_face:
