Hi @jdev99 ,
when you change between line1() and line2() the encoder keeps its last position.
You have to change the encoder position depending on which of the two values you want to change.
There is a function called
// adjust the current position
void setPosition(long newPosition);
in the Rotary Encoder lib.
Feel free to try this (not tested just coded
// SimplePollRotatorLCD.ino - Example for the RotaryEncoder library.
// This class is implemented for use with the Arduino environment.
// Copyright (c) by Matthias Hertel, http://www.mathertel.de
// This work is licensed under a BSD style license. See http://www.mathertel.de/License.aspx
// More information on: http://www.mathertel.de/Arduino
// 18.01.2014 created by Matthias Hertel
// This example checks the state of the rotary encoder in the loop() function.
// The current position is printed on output when changed.
// Hardware setup:
// Attach a rotary encoder with output pins to A2 and A3.
// The common contact should be attached to ground.
#include <Wire.h>
#include <LiquidCrystal.h>
#include <RotaryEncoder.h>
LiquidCrystal lcd(12, 13, 7, 6, 5, 8);
RotaryEncoder encoder(A2, A3);
#define selectSW1 9
int currentStateSW1;
static int pos = 0;
int newPos = 0;
static int pos1 = 0;
int newPos1 = 0;
pinMode(selectSW1, INPUT_PULLUP);
lcd.begin(16, 2);
lcd.print("Dual Value 1Enc");
delay(2000);
lcd.clear();
// You may have to modify the next 2 lines if using other pins than A2 and A3
PCICR |= (1 << PCIE1); // This enables Pin Change Interrupt 1 that covers the Analog input pins or Port C.
PCMSK1 |= (1 << PCINT10) | (1 << PCINT11); // This enables the interrupt for pin 2 and 3 of Port C.
} // setup()
// The Interrupt Service Routine for Pin Change Interrupt 1
// This routine will only be called on any signal change on A2 and A3: exactly where we need to check.
ISR(PCINT1_vect) {
encoder.tick(); // just call tick() to check the state.
} // ISR
// setPos changes between 1 and 2 depending on whether line1() or line2() is called
byte setPos = 0;
// Read the current position of the encoder and print out when changed.
currentStateSW1 = digitalRead(selectSW1);
if (currentStateSW1 == 1) {
lcd.setCursor(15, 1);
lcd.print(" ");
lcd.setCursor(15, 0);
lcd.print((char)127); // (char)127 = ASCII <-
Line1();
else {
lcd.print(" ");
Line2();
} // loop ()
/**** Print 1st setting on Line1 ***/
void Line1() {
if (setPos != 1){
setPos = 1;
encoder.setPosition(pos);
newPos = encoder.getPosition();
if (pos != newPos) {
lcd.setCursor(0, 0);
lcd.print(newPos);
pos = newPos;
} //Line1 ()
/**** Print 2nd setting on Line2 ***/
void Line2() {
if (setPos != 2){
setPos = 2;
encoder.setPosition(pos1);
newPos1 = encoder.getPosition();
if (pos1 != newPos1) {
lcd.setCursor(0, 1);
lcd.print(newPos1);
pos1 = newPos1;
} //Line2 ()
The changes to your code are:
byte setPos = 0;
and
void Line1() {
if (setPos != 1){
setPos = 1;
void Line2() {
if (setPos != 2){
setPos = 2;
This way the encoder position should be set to the last known pos or pos1 value.
You can check a slightly improved version on Wokwi
https://wokwi.com/projects/390444791965276161
with a separate function to print the position data to the LCD (clears about 10 characters at the beginning of a line to remove unwanted numbers from previous data) and prints the start values in setup().
Sketch
Forum: https://forum.arduino.cc/t/help-with-using-1-encoder-to-set-2-values/1227169/4
Wokwi: https://wokwi.com/projects/390444791965276161
// Hardware setup:
#include <Wire.h>
#define selectSW1 9
static int pos = 0;
int newPos = 0;
int newPos1 = 0;
byte setPos = 0;
lcd.begin(16, 2);
delay(2000);
lcd.clear();
printPos(pos,0);
printPos(pos1,1);
} // setup()
ISR(PCINT1_vect) {
} // ISR
lcd.print(" ");
Line1();
else {
lcd.print(" ");
Line2();
} // loop ()
void Line1() {
if (setPos != 1){
setPos = 1;
printPos(newPos,0);
pos = newPos;
} //Line1 ()
void Line2() {
if (setPos != 2){
setPos = 2;
printPos(newPos1,1);
pos1 = newPos1;
} //Line2 ()
void printPos(int aPos, byte Row){
lcd.setCursor(0, Row);
lcd.print(" ");
lcd.print(aPos);
