Help with using a diy capacitive switch for an led strip
I am creating a diy capacitive switch using aluminum foil that turns on/off led when the switch is touched slightly, and changes the brightness of the led when its touched and held. But it's just not working and I don't know where it has gone wrong. Can somebody tell me where it has gone wrong and provide me a solution for this?
int capSensePin = 3;  // pin connected to alunmium foil
int ledPin = 13;
int touchedCutoff = 100;
bool ledState = false;
unsigned long touchStartTime = 0;
int brightness = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(capSensePin, INPUT);
  if (readCapacitivePin(capSensePin) > touchedCutoff) {
    if (!ledState) {
      ledState = true;
      touchStartTime = millis();
      unsigned long touchDuration = millis() - touchStartTime;
      if (touchDuration < 1000) {
        ledState = false;
        digitalWrite(ledPin, LOW);
        brightness += 10;
        if (brightness > 255) {
          brightness = 0;
        analogWrite(ledPin, brightness);
        while (readCapacitivePin(capSensePin) > touchedCutoff) {
          delay(50);
    if (ledState) {
      if (touchDuration > 1000) {
        while (readCapacitivePin(capSensePin) <= touchedCutoff) {
          delay(50);
uint8_t readCapacitivePin(int pinToMeasure){
  volatile uint8_t* port;
  volatile uint8_t* ddr;
  volatile uint8_t* pin;
  byte bitmask;
  if ((pinToMeasure >= 0) && (pinToMeasure <= 7)){
    port = &PORTD;
    ddr = &DDRD;
    bitmask = 1 << pinToMeasure;
    pin = &PIND;
  if ((pinToMeasure > 7) && (pinToMeasure <= 13)){
    port = &PORTB;
    ddr = &DDRB;
    bitmask = 1 << (pinToMeasure - 8);
    pin = &PINB;
  if ((pinToMeasure > 13) && (pinToMeasure <= 19)){
    port = &PORTC;
    ddr = &DDRC;
    bitmask = 1 << (pinToMeasure - 13);
    pin = &PINC;
  *port &= ~(bitmask);
  *ddr  |= bitmask;
  delay(0);
  *ddr &= ~(bitmask);
  int cycles = 16000;
  for(int i = 0; i < cycles; i++){
    if (*pin & bitmask){
      cycles = i;
  *ddr  |= bitmask;
  return cycles;
assigning a non-integer value to an int. What do you think might be the result?
Why not print out touchedCutoff to see what value the compiler assigned.
oh wait that was supposed to be a 100 - I've just fixed it
Well? Has the behaviour changed, and if so, how?
By the way, on this forum, modifying the OP is frowned upon, it often makes follow-on posts nonsensical.
My bad, didn't know that :frowning:
and it's still not working
That's a pretty unhelpful answer, really. Not working - What does it do, act as if it's pressed, only act as if it's pressed for a short time, ???
'Splain to me, where in your code do you actually measure a physical pin?
*ddr &= ~(bitmask);
Again, the code ChatGPT produced is not working because the program (ChatGPT) does not understand how to program a simple LED. Humans do. You could if you dumped ChatGPT and helped yourself to Arduino Built-in sketches.
https://docs.arduino.cc/built-in-examples/
But, to repeat, fading an LED using a button you will need:
  1. Detect a button press
  2. Add or Subtract from a PWM value.
  3. Light the LED with the PWM.
  4. Reverse direction at max and min
  5. Go to 1.
And... why did you start a separate topic with the same, failed, ChatGPT "program?"
