Help with using Logitech Extreme 3D + Arduino Uno
Hello arduino world. My name is Daniel and I am new to this strange world.
I am working on a project where I will be controlling Victor 888's with Arduino Uno. But that is not my problem, for I know how to make the victors work and move. My question is, will it work for me to have the Joystick plugged into my laptop and then have my Arduino Uno connected to my laptop and have the Joystick values be transferred to the Uno? Because I need to have my joystick axis values for the code to work properly. Help!!!
Don't know. Don't know what kind of joystick you have, and/or whether there is even a mechanism to plug it into the PC.
That will certainly work.
What is going to read the joystick values? Is it capable of sending the data to a serial port?
For what code to work properly? I didn't see any code.
It is just a USB 2.0 joystick that I plan on plugging into the USB port on my Laptop
I was considering just using the laptop to read the joystick values and send it to the UNO also connected to the PC via USB. So it should be, of course I am not to sure.
What I meant by "the code" is the simple arcade drive concept that I had planned. The problem is I don't know how to code Arduino that well. Do you?
Thank you for taking the time in your day to respond to my question.
Peace, Love, and Robot Grease
Do you?
Yes.
But not all in the same pocket.
If you have other questions, we'll keep the light on for you.
So is there a Library or driver that Arduino already has as standard with the IDE that I should include to get Joystick Values?
Thanks. :)
The Arduino isn't getting joystick values. Some application on the PC is.The application on the PC is sending data to the Arduino.
What does that data look like?
The arduino Program is getting the values? In that case, how do I transpose those recieved input values as variable for the program to utilize?
Is it? I haven’t seen your Arduino program.
Hell if I know. I have no idea what data you are getting.
What is the PC sending?
