Help with using RTC "hour" from DS3231 as an integer value
Hello,
I am currently working on a project to automate heating and ventilation control of a small greenhouse. One issue I am having is working through the control logic for night vs. day. For the same project, some folks use a photocell sensor to judge night vs day, but this seems that it can be a bit troublesome.
My thought was to use the "hour" value from the RTC to define night and day for my code logic would be pretty simple. I am not worried about setting this as a constant even thought length of day changes throughout the year, don't need that much accuracy in the time i will actually be growing.
So how can I use the RTC to set a variable for hours (0-24) to be able to do this?
Here is the code I have been working on, so far it only has very simple logic for fan and vent control but still working on adding more:
// include the library code:
#include <LiquidCrystal.h>    //library for LCD
#include <DHT.h>              //Library for temp sensors
#include <RunningAverage.h>   //Library for calculating temp average vs instantaneous
//#include <Arduino.h>        //
#include <Wire.h>             //
#include <DS3231.h>           //Needed for real time clock
// define inputs and outputs
#define DHTPIN 9              //Internal temp DHT22 sensor
#define DHTPIN2 2             //External temp DHT22 sensor
#define DHTTYPE DHT22         //sets to use correct DHT library
#define DHTTYPE2 DHT22        //sets to use correct DHT library
//set variables
DHT dht (DHTPIN, DHTTYPE);    //sets internal temp/humidity as dht
DHT dhttwo (DHTPIN2, DHTTYPE2); //sets extermal temp/humidity as dhttwo
//code to set up RTC
DS3231 clock;                   //sets up clock
RTCDateTime dt;                 //sets dt as time variable
int Hour;
//code to setup running average calculation
RunningAverage internalHumidity (5);  //internal hum average
RunningAverage internalTemp(5);       //internal temp average
RunningAverage externalHumidity(5);   //external hum average
RunningAverage externalTemp(5);       //external temp average
int itempRaw = 0;               //sets internal temp Raw
int ihumRaw = 0;                //sets internal humidityRaw
int etempRaw = 0;               //sets external temp Raw
int ehumRaw = 0;                //sets external humidity Raw
int tempI = 0;                  //variable for averaged internal temp
int tempE = 0;                  //variable for averaged external temp
int humidityI = 0;              //variable for averaged internal humidity
int humidityE = 0;              //variable for averaged external humidity
const byte nsum = 5;            //
//set variable type
int chk;                        //
//greenhouse setpoints
int heatTempV = 70; //setpoint temp in F when vent would open
int heatTempF = 71; //setpoint temp in F when fan turns on
int humV = 40;       //setpoint humidity in % when vent opens
int humF = 60;       //setpoint humidity in % when fan kicks on
//digital outputs
int fan = 0;      //this variable is for displaying via LCD or serial fan status
int vent = 0;     //this variable is for displaying via LCD or serial fan status
const int rs = 3, en = 4, d4 = 5, d5 = 6, d6 = 7, d7 = 8;  //set LCD pins
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);                    //start LCD
    //setting up outputs
  pinMode (43, OUTPUT);     //output trigger for vent
  pinMode (41, OUTPUT);     //output trigger for fan
  lcd.begin(20, 4);           //starts LCD
  Serial.begin(9600);         //opens serial port
  dht.begin ();               //starts int temp sensor
  dhttwo.begin ();            //starts ext temp sensor
  clock.begin ();             //starts rtc
  //clock.setDateTime (__DATE__, __TIME__); //sets clock from computer, only need to do this once unless battery dies on RTC or time is wrong
  //Setting up the values to be read
  ihumRaw = dht.readHumidity();              //reads internal humidity
  itempRaw = dht.readTemperature (true);     //sets up to read int temp in F, for C remove "true"
  ehumRaw = dhttwo.readHumidity ();          //sets up to read ext humidity
  etempRaw = dhttwo.readTemperature (true);  //sets up to read ext temp in F, for C remove "true"
  //setting how large the variables can be
  ihumRaw = constrain (ihumRaw, 0, 100);      //limits value to 0-100
  ehumRaw = constrain (ehumRaw,0,100);        //limits value to 0-100
  itempRaw = constrain (itempRaw,-50,100);    //limits value to -50 to 100
  etempRaw = constrain (etempRaw,-50,100);    //limits value to -50 to 100
  //assinging the actual values to the variables
  if (ehumRaw > 1)
    externalHumidity.addValue(ehumRaw);
  if (etempRaw > 1)
    externalTemp.addValue(etempRaw);
  if (ihumRaw > 1)
    internalHumidity.addValue(ihumRaw);
   if (itempRaw > 1)
    internalTemp.addValue(itempRaw);
  //calculating the average and setting it to variables to be used in further logic and displayed
  humidityI = internalHumidity.getAverage();
  humidityE = externalHumidity.getAverage();
  tempI = internalTemp.getAverage();
  tempE = externalTemp.getAverage();
 //Calculate heat index
 float hif = dht.computeHeatIndex (tempE, humidityE);
 //setting up clock to get time
  dt = clock.getDateTime ();  //sets dt to get the clock time
  /*______________________________________________Serial debugging_________________________________________________________
    //Serial print code for debugging
 Serial.println(clock.dateFormat("M jS y, h:ia", dt));
  Serial.print("Raw Int Humidity: ");
  Serial.print(ihumRaw);
  Serial.print(" %, Raw Int Temp: ");
  Serial.print (itempRaw);
  Serial.println(" Farenheit");
  Serial.print("Avg Int Humidity: ");
  Serial.print (humidityI);
  Serial.print(" %, Avg Int Temp: ");
  Serial.print (tempI);
  Serial.print("Raw Ext Humidity: ");
  Serial.print(ehumRaw);
  Serial.print(" %, Raw Ext Temp: ");
  Serial.print (etempRaw);
  Serial.print("Avg Ext Humidity: ");
  Serial.print (humidityE);
  Serial.print(" %, Avg Ext Temp: ");
  Serial.print (tempE);
  Serial.print(" Farenheit");
  Serial.println(" ");
 //_________________________________________________LCD Display Code_________________________________________
  lcd.clear ();
  lcd.setCursor(0,0);
  lcd.print("IT:");
  lcd.print(tempI);
  lcd.print(" ");
  lcd.print((char)223);
  lcd.print("F |");
  lcd.print(clock.dateFormat("  h:ia", dt));
  lcd.setCursor(0,1);
  lcd.print("IH:");
  lcd.print(humidityI);
  lcd.print(" %  |  ");
  lcd.print("VENT:");
  if (vent == 1)
    lcd.print("OPN");
  else if (vent == 0)
    lcd.print("CSD");
  lcd.setCursor(0,2);
  lcd.print("ET:");
  lcd.print(tempE);
  lcd.print(" ");
  lcd.print("F |  ");
  lcd.print("FAN :");
  if (fan == 1)
    lcd.print("ON");
  else if (fan == 0)
    lcd.print("OFF");
  lcd.setCursor(0,3);
  lcd.print("EH:");
  lcd.print(humidityE);
  lcd.print(" %  |");
  lcd.print("  WATR:OFF");
  delay (1000);
//_______________________________________Logic Control___________________________________________________
//vent logic
if (humidityE > humV + 1)
    digitalWrite (43, HIGH);
    vent = 1;
else if (humidityE < humV + 1)
    digitalWrite (43, LOW);
    vent = 0;
//fan logic
if (humidityE > humF + 1)
    digitalWrite (41, HIGH);
    fan = 1;
else if (humidityE < humF + 1)
    digitalWrite (41, LOW);
    fan = 0;
Are you using this libary? If so, there's a function getHour() that'll return 24Hr or 12Hr.
Look at the header.
Thanks, using that library after multiple attempts and looking at other code tonight I was able to get what I needed.
To control day night logic I've added the following to the code to, tod is for "time of day"
 Hour = now.hour();           //sets Hour as the 0-23 value
// day-night logic
if (Hour >= 7 && Hour <= 19)
    tod = 0;
  tod = 1;
How does "time of day" relate to true or false? Making the type boolean, and naming the variable isDay, with values of true or false WOULD make sense. isDay = false means that it is not daytime. isDay = true means that it IS daytime.
there is a low overhead sunrise/sunset library that you may want to try.
You can use sunMoon.h library as attached. It is very accurate (Astronomical-clock). DS3232RTC.h will work with this library. I am also struggling to do the same if you can handle this library.
I use this simple logic with LDR which is giving the result as suspected but after 24:00 it will gose error
 time_t sRise = sm.sunRise();
 time_t sSet  = sm.sunSet();
if (RTC.get() > sRise && RTC.get() < sSet && lt > 680 )
    Serial.println("Day");
    lcd.setCursor(4, 3);
    lcd.print("Day");
  else if (RTC.get() > sSet && lt <590 || RTC.get() > sSet && lt <590)
    Serial.println("Night ");
    lcd.print("Night");
    Serial.println("Error ");
    lcd.print("Error");
sunMoon-master.zip (16 KB)
