Help with webserver - Problems get AJAX work with sending/read .csv file
Hello!
I have a hard time getting a webserver work with both AJAX and fileserver (send .csv data).
Problem is, when the .csv file is availale, the browser do not open, it ask for option to "download". I can not use the "download" as my .csv reciver refuse the connection. And, when I ask for the .csv file, the AJAX function stop. When I try to open index.htm after the .csv request it refuse to open index.htm.
I think the problem is in the http header coding. But I have a hard time understand how to make these two function work together. Anyone out there with knowhow that can help me? :slight_smile:
The AJAX server code, from: https://startingelectronics.org/tutorials/arduino/ethernet-shield-web-server-tutorial/SD-card-IO/
  Program:      eth_websrv_SD_Ajax_in_out
  Description:  Arduino web server that displays 4 analog inputs,
                the state of 3 switches and controls 4 outputs,
                2 using checkboxes and 2 using buttons.
                The web page is stored on the micro SD card.
  Hardware:     Arduino Uno and official Arduino Ethernet
                shield. Should work with other Arduinos and
                compatible Ethernet shields.
                2Gb micro SD card formatted FAT16.
                A2 to A4 analog inputs, pins 2, 3 and 5 for
                the switches, pins 6 to 9 as outputs (LEDs).
  Software:     Developed using Arduino 1.0.5 software
                Should be compatible with Arduino 1.0 +
                SD card contains web page called index.htm
  References:   - WebServer example by David A. Mellis and
                  modified by Tom Igoe
                - SD card examples by David A. Mellis and
                  Tom Igoe
                - Ethernet library documentation:
                  http://arduino.cc/en/Reference/Ethernet
                - SD Card library documentation:
                  http://arduino.cc/en/Reference/SD
  Date:         4 April 2013
  Modified:     19 June 2013
                - removed use of the String class
  Author:       W.A. Smith, http://startingelectronics.com
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   60
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 10, 20); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
File webFile;               // the web page file on the SD card
File webFile2;               // the web page file on the SD card
File webFile3;               // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
boolean LED_state[4] = {0}; // stores the states of the LEDs
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    // switches on pins 2, 3 and 5
    pinMode(2, INPUT);
    pinMode(3, INPUT);
    pinMode(5, INPUT);
    // LEDs
    pinMode(6, OUTPUT);
    pinMode(7, OUTPUT);
    pinMode(8, OUTPUT);
    pinMode(9, OUTPUT);
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // limit the size of the stored received HTTP request
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        SetLEDs();
                        // send XML file containing input states
                        XML_response(client);
                    else {   // web page request
                        client.println("Content-Type: text/html");
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // display received HTTP request on serial port
                   // Serial.print(HTTP_req);
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            else if (StrContains(HTTP_req, "GET /DATA.CSV")) {
               webFile2 = SD.open("/DATA.CSV");
               if (webFile2) {
              client.println();
            File webFile2 = SD.open("/DATA.CSV",FILE_READ);
            while(webFile2.available()) {
              int num_bytes_read;
              uint8_t byte_buffer[32];
              num_bytes_read=webFile2.read(byte_buffer,32);
              client.write(byte_buffer,num_bytes_read);
            webFile2.close();
            delay(1);      // give the web browser time to receive the data
           client.stop(); // close the connection
            } // end if (client.available())
        } // end while (client.connected())
    } // end if (client)
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs AA: Setter digital utgang med checkboks/ny slider?
void SetLEDs(void)
    // LED 1 (pin 6)
    if (StrContains(HTTP_req, "LED1=1")) {
        LED_state[0] = 1;  // save LED state
        digitalWrite(6, HIGH);
        Serial.print("DO6 høy, led1");
    else if (StrContains(HTTP_req, "LED1=0")) {
        LED_state[0] = 0;  // save LED state
        digitalWrite(6, LOW);
           Serial.print("DO6 lav, led 1");
    // LED 2 (pin 7)
    if (StrContains(HTTP_req, "LED2=1")) {
        LED_state[1] = 1;  // save LED state
        digitalWrite(7, HIGH);
           Serial.print("DO7 høy, led 2");
    else if (StrContains(HTTP_req, "LED2=0")) {
        LED_state[1] = 0;  // save LED state
        digitalWrite(7, LOW);
        Serial.print("DO7 lav, led2");
    // LED 3 (pin 8)
    if (StrContains(HTTP_req, "LED3=1")) {
        LED_state[2] = 1;  // save LED state
        digitalWrite(8, HIGH);
        Serial.print("DO8 høy, led3");
    else if (StrContains(HTTP_req, "LED3=0")) {
        LED_state[2] = 0;  // save LED state
        digitalWrite(8, LOW);
        Serial.print("DO8 lav, led3");
    // LED 4 (pin 9)
    if (StrContains(HTTP_req, "LED4=1")) {
        LED_state[3] = 1;  // save LED state
        digitalWrite(9, HIGH);
        Serial.print("DO9 høy, led4");
    else if (StrContains(HTTP_req, "LED4=0")) {
        LED_state[3] = 0;  // save LED state
        digitalWrite(9, LOW);
        Serial.print("DO9 lav, led4");
// send the XML file with analog values, switch status AA BINARY INPUT status
//  and LED status
void XML_response(EthernetClient cl)
    int analog_val;            // stores value read from analog inputs
    int count;                 // used by 'for' loops
    int sw_arr[] = {2, 3, 5};  // pins interfaced to switches
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    // read analog inputs
    for (count = 2; count <= 5; count++) { // A2 to A5
        analog_val = analogRead(count);
        cl.print("<analog>");
        cl.print(analog_val);
        cl.println("</analog>");
    // read switches  AA SWITCH ER ALTSÅ BINARY INPUT....
    for (count = 0; count < 3; count++) {
        cl.print("<switch>");
        if (digitalRead(sw_arr[count])) {
            cl.print("ON");
        else {
            cl.print("OFF");
        cl.println("</switch>");
    // checkbox LED states   AA SENDER TEKST TIL Å STÅ VEDSIDEN AV "SWITCH INPUTS" SOM ER BINÆR INNGANG, ON eller OFF
    // LED1
    cl.print("<LED>");
    if (LED_state[0]) {
        cl.print("checked");
    else {
        cl.print("unchecked");
    cl.println("</LED>");
    // LED2
    cl.print("<LED>");
    if (LED_state[1]) {
    else {
    // button LED states
    // LED3
    cl.print("<LED>");
    if (LED_state[2]) {
        cl.print("on");
    else {
        cl.print("off");
    // LED4
    cl.print("<LED>");
    if (LED_state[3]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
You have to set properly the mime type (example: "Content-Type: text/csv") in the headers section.
Hello and thank you for reply.
I have tried to do that, but it do not work. Reason, if arduino get ajex request, it then send the whole index.htm file. There is a problem with how the if / else statemets work, for how I can reply to ajax requests and in the same time, stream the .csv file.
Hello!
It just seems like it is not technical possible for W5100 or W5500 ethernet chips to stream both AJAX (xml) and .CSV on the same time, to web browser/client. Even if the documentation say 4/8 clients. I`m happy for any tips :slight_smile:
Hello. I have done some research on the subject since I went through the same error.
When the WEB server is mounted and a client is active, pin 10 is active sending and receiving data to the NETWORK card. Now, when you do a read to the SD you use pin 4 (by default). SPI takes care of opening and closing these pins as needed, so far so good. The problem is that if you have AJAX active, and its sending time coincides with the reading of the SD, what exactly should not happen happens and that is the use of both pins at the same time.
