Help with Wemos relay module problem
Hi guys
I have a relay module problem.
I wanna run a fan through relay module.
It works when I use without the code about PM things. (The part related to 'Timer.run')
but with whole code, it only run just short time at first and stop soon.
Maybe its about Voltage source? I don't know
Plz help me....
I use wemos d1 r1
Here is the whole code.
#define BLYNK_PRINT Serial
#include <pm2008_i2c.h>
#include <DHT.h>
#include "ThingSpeak.h"
PM2008_I2C pm2008_i2c;
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
char auth []="*";
char ssid []="*";
char pass []="*";
int keyIndex = 0;            // your network key Index number (needed only for WEP)
WiFiClient  client;
unsigned long myChannelNumber = *;
const char* myWriteAPIKey = "*";
const char* myReadAPIKey = "*";
float t,h;
WidgetLCD lcd(V1);
WidgetLED led1(V2);
BlynkTimer timer;
bool ledStatus = false;
#define BLYNK_GREEN     "#23C48E"
#define BLYNK_BLUE      "#04C0F8"
#define BLYNK_YELLOW    "#ED9D00"
#define BLYNK_RED       "#D3435C"
int R=5;
uint8_t pm2p5_grade=0;
uint8_t pm10_grade=0;
uint8_t total_grade=0;
void LCD(){
  lcd.clear();
  Serial.begin (9600);
  // Serial.begin (115200);
  pinMode(R,OUTPUT);
  //digitalWrite(R,LOW);
  Blynk.begin(auth,ssid,pass);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo native USB port only
  WiFi.mode(WIFI_STA);
  ThingSpeak.begin(client);
  pm2008_i2c.begin();
  pm2008_i2c.command();
  led1.on();
  dht.begin();
  uint8_t ret = pm2008_i2c.read();
  timer.setInterval(1000L, myTimerEvent);
  timer.setInterval(1000L, blinkLedWidget);
  timer.setInterval(16000L, TempHumEvent);
  Blynk.run();
  timer.run();
BLYNK_WRITE(V3){
  int pinValue=param.asInt();
  if(pinValue==1){
    digitalWrite(R, HIGH);
    //pinMode(R,OUTPUT);
    digitalWrite(R, LOW);
void myTimerEvent()
  if(ret==0||ret==1){
    Serial.print("PM2.5: ");
    Serial.println(pm2008_i2c.pm2p5_grimm);
    Blynk.virtualWrite(V4, pm2008_i2c.pm2p5_grimm);
    Serial.print("PM10: ");
    Serial.println(pm2008_i2c.pm10_grimm);
    Blynk.virtualWrite(V5, pm2008_i2c.pm10_grimm);
    char pm2p5[10];
    lcd.print(0, 0, "PM2.5: ");
    sprintf(pm2p5, "%3d", pm2008_i2c.pm2p5_grimm);
    lcd.print(6, 0, pm2p5);
    char pm10[10];
    lcd.print(0, 1, "PM10: ");
    sprintf(pm10, "%3d", pm2008_i2c.pm10_grimm);
    lcd.print(5, 1, pm10);
void blinkLedWidget()
  if(ret==0||ret==1){
  if(pm2008_i2c.pm10_grimm<31){
    pm10_grade=1;
  } else if(pm2008_i2c.pm10_grimm<81){
    pm10_grade=2;
  } else if(pm2008_i2c.pm10_grimm<151){
    pm10_grade=3;
    pm10_grade=4;
  if(pm2008_i2c.pm2p5_grimm<16){
    pm2p5_grade=1;
  } else if(pm2008_i2c.pm2p5_grimm<36){
    pm2p5_grade=2;
  } else if(pm2008_i2c.pm2p5_grimm<76){
    pm2p5_grade=3;
    pm2p5_grade=4;
  total_grade=max(pm2p5_grade,pm10_grade);
  if (total_grade==1) {
    led1.setColor(BLYNK_BLUE);
    Serial.println("GOOD");
    ledStatus = true;
  } else if(total_grade==2){
    led1.setColor(BLYNK_GREEN);
    Serial.println("NORMAL");
    ledStatus = true;
  } else if(total_grade==3){
    led1.setColor(BLYNK_YELLOW);
    Serial.println("BAD");
    ledStatus = true;
  } else{
    led1.setColor(BLYNK_RED);
    Serial.println("WORST");
    ledStatus = true;
  if ( total_grade>=3 ){
    Blynk.notify("ventilation start");
    digitalWrite(R,HIGH);
  int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
    if(x == 200){
     Serial.println("Channel update successful.");
    else{
     Serial.println("Problem updating channel. HTTP error code " + String(x));
Your post was MOVED to it's current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Does this code compile OK? I can see two } characters. The number of { and } should be the same (unless they are in comments). There are 26 of { and 28 of }
Oh that's just a mistake of copy and paste when I wrote this post.
Compile OK, Upload OK, Doing well without Blynktimer and PM things :sob:
