I'm trying to build a wordclock. I have 3d printed and bought the parts. And now google gets me nowhere. Please help the noob!!
My error is:
Arduino: 1.8.15 Hourly Build 2021/05/12 03:35 (Mac OS X), Board: "Arduino Uno"
/var/folders/yd/d4m9h63s7dj3r6kyfp5rsqm80000gn/T//ccdW5eq7.ltrans0.ltrans.o: In function checkDST': /Users/n/Documents/Arduino/libraries/DST_RTC/DST_RTC.cpp:37: undefined reference to
rulesDST'
/Users/n/Documents/Arduino/libraries/DST_RTC/DST_RTC.cpp:37: undefined reference to rulesDST' /var/folders/yd/d4m9h63s7dj3r6kyfp5rsqm80000gn/T//ccdW5eq7.ltrans0.ltrans.o: In function
write':
Multiple libraries were found for "DST_RTC.h"
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Print.h:53: undefined reference to rulesDST' Used: /Users/n/Documents/Arduino/libraries/DST_RTC Not used: /Users/n/Documents/Arduino/libraries/DST_RTC-1.1.1 /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Print.h:53: undefined reference to
rulesDST'
/var/folders/yd/d4m9h63s7dj3r6kyfp5rsqm80000gn/T//ccdW5eq7.ltrans0.ltrans.o: In function checkDST': /Users/n/Documents/Arduino/libraries/DST_RTC/DST_RTC.cpp:55: undefined reference to
rulesDST'
/var/folders/yd/d4m9h63s7dj3r6kyfp5rsqm80000gn/T//ccdW5eq7.ltrans0.ltrans.o:/Users/n/Documents/Arduino/libraries/DST_RTC/DST_RTC.cpp:55: more undefined references to `rulesDST' follow
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
Please read the instructions on how to use this board. Also my eyes are not what they use to be and I cannot see your schematic, I know you drew one and not a frizzy thing.
I'm trying to do a new build for an old version of the World Clock, so I'll see if I can figure this out and post here.
In the mean time, noob or not, step through the error messages one by one and you'll see that you have several issues - one of them you can likely fix on your own (Multiple libraries were found for "DST_RTC.h"
Here's what I'm getting today:
C:\Users\john\AppData\Local\Temp\cc8vpVU7.ltrans0.ltrans.o: In function `DST_RTC::checkDST(DateTime) [clone .constprop.21]':
D:\dev\hardware\libraries\DST_RTC/DST_RTC.cpp:36: undefined reference to `rulesDST'
D:\dev\hardware\libraries\DST_RTC/DST_RTC.cpp:71: undefined reference to `rulesDST'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "Wire.h"
Used: C:\Users\john\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13\libraries\Wire
Not used: C:\Users\john\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire
exit status 1
Error compiling for board Pro Trinket 5V/16MHz (USB).
So for some reason I have two versions of the wire library. this isn't killing the build for me, but it probably is something I want to fix (just like you probably need to make sure the IDE can only find the one DST_RTC library (although I could be wrong)).
I just looked at the GitHub repo for the original project and it was updated a while back to deal with the changes in the DST Library. You can get the latest code at GitHub - andydoro/WordClock-NeoMatrix8x8: Wordclock using NeoMatrix 8x8. As soon as I updated my clone and changed the LED settings to match my hardware, it compiled the first time.
