Help with writing a library
Hello,
I am trying to write a library to control the PCF8574 I/O expander from TI. I followed the tutorial on writing a library at http://playground.arduino.cc/Code/Library but I’m getting compiler errors. Specifically, when I compile the example sketch, I get errors (even without trying to use the class). I get several errors of the following type: ISO C++ forbids declaration of ‘writeData’ with no type (for many different functions in the library).
I have done some reading and some research, but I haven’t figured out what I’m doing wrong. Any help is greatly appreciated! I really want to understand what I’m doing wrong, rather than just fixing it.
Here is the code:
The header file Pcf.h
  Pcf.h - Library for controlling a pcf8574 I/O port expander.
    Created by James Petersen, 2013.
    Released under the GPL.
#ifndef Pcf_h
#define Pcf_h
#include "Arduino.h"
#include "Wire.h"
class Pcf
  public:
    Pcf(byte address);
    togglePin(byte pin);
    writePin(byte pin, boolean value);
    boolean readPin(byte pin);
    writeData(byte data);
    byte readData();
    clearData();
  private:
    byte _address;
#endif
Pcf.cpp
/*  Pcf.cpp - Library for controlling a pcf8574 I/O port expander.
#include "pcf8574.h"
#include "Wire.h"
Pcf::Pcf(byte address)
  Wire.begin();
  _address = address;
  Wire.beginTransmission(_address);
  Wire.write((byte)0x00);
  Wire.endTransmission(_address);
void Pcf::toggle(byte pin) {
  Wire.requestFrom(_address,1);
  if(Wire.available()) {
    byte _data = Wire.read();
  boolean bit = bitRead(_data, pin);
  bitWrite(_data, ~bit);
  Wire.write((byte)_data);
void Pcf::clearData() {
void Pcf::writePin(byte pin, boolean value) {
  bitWrite(_data, value);
void Pcf::writeData(byte data) {
  Wire.write((byte)data);
byte Pcf::readData() {
  return _data;
boolean Pcf::readPin(byte pin) {
  return bitRead(_data, pin);
And the example sketch that doesn’t compile:
/* Example sketch showing use of the Pcf Library.
 * Written by James Petersen, 2013.
 * Copyright under the GPL.
#include <Pcf.h>
#include <Wire.h>
void setup(){
//  Pcf pcf = Pcf(32); //32 is the default address for the PCF8574 with all three input pins tied to ground.
void loop(){
If the method isn't returning a value, it's needs to have void in place of its return type.
Arrch:
The only exception is the constructor - that is a special case, and probably the cause of the confusion.
Wonderful! Thanks for the help! I feel like I understand what's going on now.
I have finished tweaking the library, and it now compiles without a problem. I will be testing it next week (I don't have my hardware handy right now). Once I've made sure it works the way I'd like, I will be posting it to GitHub, and I'll add the link to this thread.
Thanks again for helping me understand!
