Help with yield and ESP8266
Dear all,
I am having an issue with the watch dog. I am trying to read messages from an A6 GSM module using the software.serial but my Esp8266 (Wemos D1 mini) keeps crashing even when I use yield() and delays. I think it is readString() command that holds up the module but any hints with what can be done to get the code to run, beside changing MCU type?
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
String state = "initing";
#define powerGSMPin D0
SoftwareSerial A6board (D3, D4);
  A6board.begin(9600);
  pinMode(powerGSMPin, OUTPUT);
  digitalWrite(powerGSMPin, LOW);
  delay(100);
   digitalWrite(powerGSMPin, HIGH);
while(state == "initing" || state == "sms_mode") {
    if (A6board.available()) {
      delay(1);
      Serial.println("reading A6");
      String recievedA6 = A6board.readString();
      delay(1);
      Serial.println(recievedA6);
//            if(state == "initing" && recievedA6.indexOf("+CREG: 5") >= 0) {
//        Serial.println("Mode sms");
//        state = "sms_mode";
//        delay(2000);
//        A6board.println("AT+CMGF=1");
//      } else if(state == "sms_mode" && recievedA6.indexOf("OK") >= 0) {
//        state = "ready";
//        Serial.println("Ready!");
    delay(50);
    yield();
Thanks
You can try this: Serial.setTimeout() so the readString() does not wait too long.
You should not normally have a while() statement in the loop. Especially in this case where an if statement would fit better.
Also, if you must use the String class, define the variables globally and use the reserve() method to strop excessive fragmentation of the heap storage.
Thanks a lot, I will try! :slight_smile:
