Help with Zero Crossing code
Hi.
The code below enters on an ISR everytime the pin 2 (interrupt 0) receives a pulse on negative edge from a zero crossing detector circuit. If I use delays instead of if conditions with micros() the code works fine. This project is about AC control of multiple lamps so I can't use delays.
Arduino is triggering the ISR but it's not generating the phased pulse (dimmer) inside the ISR. Dimmer is constantly 0 V. The code was tested on simulation (ISIS Proteus) and on a real Arduino UNO but both presented the same result.
EDIT: Code revised with suggestions
#define dimmer 3
// Initializing variables
volatile          long pot      = 0.0;          // potentiometer reading
volatile unsigned long t        = micros();     // time
volatile unsigned long lastTime = 0.0;          // last time
volatile unsigned long period   = 8333;         // Period (us)
volatile unsigned long t_on     = 100.0;        // pulse duration
volatile          bool state    = LOW;          // pulse's state - HIGH/LOW
void zeroCross() { // ISR
  // Calculates t1 that depends on potentiometer readings
  unsigned long t1 = 8333L * (100L - pot) / 100L;
  t = micros(); // Added after users suggestions
  if ((t - lastTime) <= t1 || ((t - lastTime) >= (t1 + t_on))) {
    state = LOW;
  else {
    state = HIGH;
  if ((t - lastTime) >= period) {
    lastTime = t;
  digitalWrite(dimmer, state);
  pinMode(dimmer, OUTPUT);
  attachInterrupt(0, zeroCross, FALLING);
  pot = map(analogRead(A0), 0, 1023, 1, 99); // Reads potentiometer
What can I do to make this code work? I'm pretty sure my logic is right :grinning:
I've attached an image where it shows the logic I built for this.
You never update 't'
See Arduino Playground - ACPhaseControl
aarg:
I update it every 8333 us, right?
Sorry, but I can't see this problem.
You say t = micros() in your initialization code (which only runs once) and ignore micros() afterwards.
JCA34F:
I put t = micros(); inside ZeroCross() ISR and inside loop(), but the problem still remains.
Please post the entire revised sketch in a new post, so that we can have a look at the changes you made.
aarg:
@aarg I edited the current post, so You can see the changes I made in the code.
danicomartins:
@anon57585045 I edited the current post, so You can see the changes I made in the code.
There is a reason why I asked you to do it specifically that way. If you edit previous posts, it makes the replies look like nonsense and so makes it hard for people to follow from the beginning. But too late now, please post according to the forum guidelines next time.
Have you tried bypassing the pot reading?
//  pot = map(analogRead(A0), 0, 1023, 1, 99); // Reads potentiometer
pot = 50;
aarg:
pot = 50;
Yes, I did, but it didn't work. The output (dimmer) remains at 0 V.
I don't think so.
    state = LOW;
  else {
    state = HIGH;
    lastTime = t;
t-lastTime will always be equal to 8333 and I believe that value will always satisfy the second condition and the output will be LOW.
    state = LOW;
Your ISR is called through the zero-crossing signal. It runs down once per zero-crossing-signal and that's it.
Until the next zero-crossing-signal occures. Again running down once and that's it.
The time when it is called is always when the zero-crossing signal occurs but not at a time that has some delay after the zero-crossing signal.
Timing with millis() or micros() needs a functionality that the if-condition that is used to check if a certain timeperiod is over will be checked repeatedly thousands of times per second. The code you have so far does not check repeatedly.
The basic principle for timing with micros() is:
the ISR just sets a boolean flag. And your main-loop checks if flag is set true. If flag has value true start timing
best regards Stefan
Your code needs to be in loop(), not the ISR. The ISR can record the latest zero-crossing, but its not
happening when the output needs to be toggled.
That can be tested for in loop, or perhaps scheduled using a timer interrupt if you want to do this
in the background with accurate timing.
Do you understand state-transition diagrams?
First of all, Thank You for the time You took to help me. I've made some progression on my code. Let's go
cattledog:
@cattledog You're right. So I changed the conditions to
if (t <= t1 + lastTime) {
      state = LOW;
    else if (t >= t1 + t_on + lastTime) {
      state = LOW;
StefanL38:
best regards Stefan
MarkT:
@Stefan and @MarkT, I thought the ISR would last untill all conditions are satisfied and all actions are made, but I was wrong and You're right on your statement. I've made some changes in the code with your suggestions:
  flag = HIGH;              // Activates the flag everytime an interrupt occurs
With all changes the NEW code is down below. What happens now is that the pulse (dimmer signal) works for some time, falls down to zero (0 V) for some time, and then it works again and so on. t1 should be constant as the pot is constant too, but in first microseconds t1 varies until it reaches the constante value. (attached images)
image graphs:
Zero Cross signal -> blue
dimmer (pulse signal) -> red
Sine rms on lamp -> green
#define dimmer 4                                // OUTPUT on Pin 4
unsigned long t        = 0.0;          // time
volatile  bool flag     = LOW;          // flag that indicates ISR triggering
  attachInterrupt(digitalPinToInterrupt(2), zeroCross, FALLING);
  pot = 50.0; // potentiometer reading - it actually comes from an analogRead(A0)
              // It is set to 50 just to simplify the test
  t = micros();
  // If flag is HIGH, the dimmer signal routine starts
  if (flag == HIGH) {
      state = LOW;
      state = LOW;
    else {
      state = HIGH;
    if (t - lastTime >= period) { // period end check
      lastTime = t;
      flag = LOW;                   // If period has passed away, it sets flag to LOW
  digitalWrite(dimmer, state);    // OUTPUT
I think you may be having conflicts between when the flag is set HIGH in the interrupt and LOW in loop based on the period.
Try this variation where the flag is set LOW after the 100us trigger signal to the ssr is brought LOW and the zero cross time ("lastTime") is set in the ISR.
Your timing conditions should be expressed as subtractions to prevent rollover issues.
  lastTime = micros();
  t = micros();
  if (flag == HIGH)
    //if (t <= t1 + lastTime)
      if (t - lastTime <= t1)
      state = LOW;
    //else if (t >= t1 + t_on + lastTime)
     else if (t - lastTime >= t1 + t_on)
      state = LOW;
      flag = LOW;
      state = HIGH;
  //  if (t - lastTime >= period)
  //  { // period end check
   //   lastTime = t;
   //   flag = LOW;                   // If period has passed away, it sets flag to LOW
All this said, I think that you are going to be more successful following the timer based AC phase control tutorial referenced earlier in the thread.
cattledog:
That was a good point. With your code some pulses are not being triggered, in other words there are some skiping pulses (attached image). Can we fix that? Note that t1 is always at 4333 us which is right because pot = 50. So I think we're close to solve the problem. :slight_smile:
So my intention is to make a PID to control Vrms on a resistance load and with that the temperature will be controlled as well. I need to keep the code as simple as possible because i'm not an expert on internal Timers/Registers of Arduino as shown in the referenced tutorial
danicomartins:
I solved this particular problem by making lastTime = t instead of lastTime = micros
  lastTime = t;
[\code]
BUT if I do
the output pulse is always 0 V. Solved a problem and got another one :P
did you read this?
there are two working simple sketches
analogRead() is relatively slow and blocking. It takes about 110 microseconds which is longer than the pulse timing. I think that reading the pot every pass through loop() is creating problems for the tight timing of the sketch
There is not need to read the pot every pass through loop. How responsive does the duty cycle change need to be?
Try putting the analogRead() on a blink without delay style millis() timer so that you only read the value every second.
