Help witha Web Server Controlled Neopixel
Hi so I've been trying to do this for a while, I'm new to C++, I only know python and this has been a really long process. The code isn't all mine and most of it based of of examples as I don't know the syntax. My aim is to have a webserver that allows me to change between lighting functions. I don't understand why this code wont work, it might be obvious, I am new. Otherwise does anyone have any ideas to a different approach, been trying for weeks now to figure out how to do this.
Thanks,
Dylan
ERROR MESSAGE:
expected '}' at end of input
(referring to line 801)
#include <EEPROM.h>
#define NUM_LEDS 300
#define PIN 13
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
#include <WiFi.h>
const char* ssid     = "";
const char* password = "";
WiFiServer server(80);
byte selectedEffect=0;
    pinMode(5, OUTPUT);
    delay(10);
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
// *** REPLACE FROM HERE ***
   WiFiClient client = server.available();
  if (client) {
    Serial.println("New Client.");
    String currentLine = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n') {
          if (currentLine.length() == 0) {
            client.println("Content-type:text/html");
            client.println();
            client.print("Click <a href=\"/RGB\">here</a>.<br>");
            client.print("Click <a href=\"/L\">here</a> to turn the LEDs off.<br>");
            client.println();
            currentLine = "";
        } else (c != '\r'); {
          currentLine += c;
        if (currentLine.endsWith("GET /RGB")) {
          selectedEffect=0;
  switch(selectedEffect) {
    case 0  : {
                // RGBLoop - no parameters
                RGBLoop();
    case 1  : {
                // FadeInOut - Color (red, green. blue)
                FadeInOut(0xff, 0x00, 0x00); // red
                FadeInOut(0xff, 0xff, 0xff); // white
                FadeInOut(0x00, 0x00, 0xff); // blue
    case 2  : {
                // Strobe - Color (red, green, blue), number of flashes, flash speed, end pause
                Strobe(0xff, 0xff, 0xff, 10, 50, 1000);
    case 3  : {
                // HalloweenEyes - Color (red, green, blue), Size of eye, space between eyes, fade (true/false), steps, fade delay, end pause
                HalloweenEyes(0xff, 0x00, 0x00,
                              1, 4,
                              true, random(5,50), random(50,150),
                              random(1000, 10000));
                              1, 4,
    case 4  : {
                // CylonBounce - Color (red, green, blue), eye size, speed delay, end pause
                CylonBounce(0xff, 0x00, 0x00, 4, 10, 50);
    case 5  : {
                // NewKITT - Color (red, green, blue), eye size, speed delay, end pause
                NewKITT(0xff, 0x00, 0x00, 8, 10, 50);
    case 6  : {
                // Twinkle - Color (red, green, blue), count, speed delay, only one twinkle (true/false)
                Twinkle(0xff, 0x00, 0x00, 10, 100, false);
    case 7  : {
                // TwinkleRandom - twinkle count, speed delay, only one (true/false)
                TwinkleRandom(20, 100, false);
    case 8  : {
                // Sparkle - Color (red, green, blue), speed delay
                Sparkle(0xff, 0xff, 0xff, 0);
    case 9  : {
                // SnowSparkle - Color (red, green, blue), sparkle delay, speed delay
                SnowSparkle(0x10, 0x10, 0x10, 20, random(100,1000));
    case 10 : {
                // Running Lights - Color (red, green, blue), wave dealy
                RunningLights(0xff,0x00,0x00, 50);  // red
                RunningLights(0xff,0xff,0xff, 50);  // white
                RunningLights(0x00,0x00,0xff, 50);  // blue
    case 11 : {
                // colorWipe - Color (red, green, blue), speed delay
                colorWipe(0x00,0xff,0x00, 50);
                colorWipe(0x00,0x00,0x00, 50);
    case 12 : {
                // rainbowCycle - speed delay
                rainbowCycle(20);
    case 13 : {
                // theatherChase - Color (red, green, blue), speed delay
                theaterChase(0xff,0,0,50);
    case 14 : {
                // theaterChaseRainbow - Speed delay
                theaterChaseRainbow(50);
    case 15 : {
                // Fire - Cooling rate, Sparking rate, speed delay
                Fire(55,120,15);
              // simple bouncingBalls not included, since BouncingColoredBalls can perform this as well as shown below
              // BouncingColoredBalls - Number of balls, color (red, green, blue) array, continuous
              // CAUTION: If set to continuous then this effect will never stop!!!
    case 16 : {
                // mimic BouncingBalls
                byte onecolor[1][3] = { {0xff, 0x00, 0x00} };
                BouncingColoredBalls(1, onecolor, false);
    case 17 : {
                // multiple colored balls
                byte colors[3][3] = { {0xff, 0x00, 0x00},
                                      {0xff, 0xff, 0xff},
                                      {0x00, 0x00, 0xff} };
                BouncingColoredBalls(3, colors, false);
    case 18 : {
                // meteorRain - Color (red, green, blue), meteor size, trail decay, random trail decay (true/false), speed delay
                meteorRain(0xff,0xff,0xff,10, 64, true, 30);
// ** LEDEffect Functions **
void RGBLoop(){
  for(int j = 0; j < 3; j++ ) {
    // Fade IN
    for(int k = 0; k < 256; k++) {
      switch(j) {
        case 0: setAll(k,0,0); break;
        case 1: setAll(0,k,0); break;
        case 2: setAll(0,0,k); break;
      showStrip();
      delay(3);
    // Fade OUT
    for(int k = 255; k >= 0; k--) {
      switch(j) {
      showStrip();
      delay(3);
void FadeInOut(byte red, byte green, byte blue){
  float r, g, b;
  for(int k = 0; k < 256; k=k+1) {
    r = (k/256.0)*red;
    g = (k/256.0)*green;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
  for(int k = 255; k >= 0; k=k-2) {
    r = (k/256.0)*red;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause){
  for(int j = 0; j < StrobeCount; j++) {
    setAll(red,green,blue);
    showStrip();
    delay(FlashDelay);
    setAll(0,0,0);
    showStrip();
    delay(FlashDelay);
 delay(EndPause);
void HalloweenEyes(byte red, byte green, byte blue,
                   int EyeWidth, int EyeSpace,
                   boolean Fade, int Steps, int FadeDelay,
                   int EndPause){
  randomSeed(analogRead(0));
  int i;
  int StartPoint  = random( 0, NUM_LEDS - (2*EyeWidth) - EyeSpace );
  int Start2ndEye = StartPoint + EyeWidth + EyeSpace;
  for(i = 0; i < EyeWidth; i++) {
    setPixel(StartPoint + i, red, green, blue);
    setPixel(Start2ndEye + i, red, green, blue);
  showStrip();
  if(Fade==true) {
    float r, g, b;
    for(int j = Steps; j >= 0; j--) {
      r = j*(red/Steps);
      g = j*(green/Steps);
      b = j*(blue/Steps);
        setPixel(StartPoint + i, r, g, b);
        setPixel(Start2ndEye + i, r, g, b);
      showStrip();
      delay(FadeDelay);
  setAll(0,0,0); // Set all black
  delay(EndPause);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// used by NewKITT
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i =((NUM_LEDS-EyeSize)/2); i>=0; i--) {
    setAll(0,0,0);
    setPixel(NUM_LEDS-i, red/10, green/10, blue/10);
      setPixel(NUM_LEDS-i-j, red, green, blue);
    setPixel(NUM_LEDS-i-EyeSize-1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = 0; i<=((NUM_LEDS-EyeSize)/2); i++) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void Twinkle(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
  for (int i=0; i<Count; i++) {
     setPixel(random(NUM_LEDS),red,green,blue);
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
     setPixel(random(NUM_LEDS),random(0,255),random(0,255),random(0,255));
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void Sparkle(byte red, byte green, byte blue, int SpeedDelay) {
  int Pixel = random(NUM_LEDS);
  setPixel(Pixel,red,green,blue);
  showStrip();
  delay(SpeedDelay);
  setPixel(Pixel,0,0,0);
void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
  setPixel(Pixel,0xff,0xff,0xff);
  showStrip();
  delay(SparkleDelay);
  showStrip();
  delay(SpeedDelay);
void RunningLights(byte red, byte green, byte blue, int WaveDelay) {
  int Position=0;
  for(int i=0; i<NUM_LEDS*2; i++)
      Position++; // = 0; //Position + Rate;
      for(int i=0; i<NUM_LEDS; i++) {
        // sine wave, 3 offset waves make a rainbow!
        //float level = sin(i+Position) * 127 + 128;
        //setPixel(i,level,0,0);
        setPixel(i,((sin(i+Position) * 127 + 128)/255)*red,
                   ((sin(i+Position) * 127 + 128)/255)*green,
                   ((sin(i+Position) * 127 + 128)/255)*blue);
      showStrip();
      delay(WaveDelay);
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
  for(uint16_t i=0; i<NUM_LEDS; i++) {
      setPixel(i, red, green, blue);
      showStrip();
      delay(SpeedDelay);
void rainbowCycle(int SpeedDelay) {
  byte *c;
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< NUM_LEDS; i++) {
      c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
      setPixel(i, *c, *(c+1), *(c+2));
    showStrip();
    delay(SpeedDelay);
// used by rainbowCycle and theaterChaseRainbow
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
void theaterChase(byte red, byte green, byte blue, int SpeedDelay) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < NUM_LEDS; i=i+3) {
        setPixel(i+q, red, green, blue);    //turn every third pixel on
      showStrip();
      delay(SpeedDelay);
        setPixel(i+q, 0,0,0);        //turn every third pixel off
void theaterChaseRainbow(int SpeedDelay) {
  byte *c;
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
          c = Wheel( (i+j) % 255);
          setPixel(i+q, *c, *(c+1), *(c+2));    //turn every third pixel on
        showStrip();
        delay(SpeedDelay);
void Fire(int Cooling, int Sparking, int SpeedDelay) {
  static byte heat[NUM_LEDS];
  int cooldown;
  // Step 1.  Cool down every cell a little
  for( int i = 0; i < NUM_LEDS; i++) {
    cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
    if(cooldown>heat[i]) {
      heat[i]=0;
      heat[i]=heat[i]-cooldown;
  // Step 2.  Heat from each cell drifts 'up' and diffuses a little
  for( int k= NUM_LEDS - 1; k >= 2; k--) {
    heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
  // Step 3.  Randomly ignite new 'sparks' near the bottom
  if( random(255) < Sparking ) {
    int y = random(7);
    heat[y] = heat[y] + random(160,255);
    //heat[y] = random(160,255);
  // Step 4.  Convert heat to LED colors
  for( int j = 0; j < NUM_LEDS; j++) {
    setPixelHeatColor(j, heat[j] );
  showStrip();
  delay(SpeedDelay);
void setPixelHeatColor (int Pixel, byte temperature) {
  // Scale 'heat' down from 0-255 to 0-191
  byte t192 = round((temperature/255.0)*191);
  // calculate ramp up from
  byte heatramp = t192 & 0x3F; // 0..63
  heatramp <<= 2; // scale up to 0..252
  // figure out which third of the spectrum we're in:
  if( t192 > 0x80) {                     // hottest
    setPixel(Pixel, 255, 255, heatramp);
  } else if( t192 > 0x40 ) {             // middle
    setPixel(Pixel, 255, heatramp, 0);
  } else {                               // coolest
    setPixel(Pixel, heatramp, 0, 0);
void BouncingColoredBalls(int BallCount, byte colors[][3], boolean continuous) {
  float Gravity = -9.81;
  int StartHeight = 1;
  float Height[BallCount];
  float ImpactVelocityStart = sqrt( -2 * Gravity * StartHeight );
  float ImpactVelocity[BallCount];
  float TimeSinceLastBounce[BallCount];
  int   Position[BallCount];
  long  ClockTimeSinceLastBounce[BallCount];
  float Dampening[BallCount];
  boolean ballBouncing[BallCount];
  boolean ballsStillBouncing = true;
  for (int i = 0 ; i < BallCount ; i++) {
    ClockTimeSinceLastBounce[i] = millis();
    Height[i] = StartHeight;
    Position[i] = 0;
    ImpactVelocity[i] = ImpactVelocityStart;
    TimeSinceLastBounce[i] = 0;
    Dampening[i] = 0.90 - float(i)/pow(BallCount,2);
    ballBouncing[i]=true;
  while (ballsStillBouncing) {
      TimeSinceLastBounce[i] =  millis() - ClockTimeSinceLastBounce[i];
      Height[i] = 0.5 * Gravity * pow( TimeSinceLastBounce[i]/1000 , 2.0 ) + ImpactVelocity[i] * TimeSinceLastBounce[i]/1000;
      if ( Height[i] < 0 ) {
        Height[i] = 0;
        ImpactVelocity[i] = Dampening[i] * ImpactVelocity[i];
        if ( ImpactVelocity[i] < 0.01 ) {
          if (continuous) {
            ballBouncing[i]=false;
      Position[i] = round( Height[i] * (NUM_LEDS - 1) / StartHeight);
    ballsStillBouncing = false; // assume no balls bouncing
      setPixel(Position[i],colors[i][0],colors[i][1],colors[i][2]);
      if ( ballBouncing[i] ) {
    showStrip();
    setAll(0,0,0);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
// used by meteorrain
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
// *** REPLACE TO HERE ***
// ** FastLed/NeoPixel Common Functions **
// Apply LED color changes
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
// Set a LED color (not yet visible)
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
// Set all LEDs to a given color and apply it (visible)
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
  showStrip();
Delete the brace Noted.
Welcome to the forums. Nice job using code tags for your code and having your code formatted as well! That is usually the first hurdle for a new-comer.
As @runaway_pancake points out, you have one extra closing brace.
Also, all your case statements do NOT need to be enclosed inside opening/closing braces. It does not really impact your code, your each case statement is its own scope without them so they are not necessary.
As your code stands, you never set selectedEffect to anything other than 0 so not of your patterns will ever run.
You should also look into enumerations (e.g. enum { ... }) so your case number can be turned into something more human readable
enum { RGB_LOOP, FADE,  STROBE, ... };
int selecteState = XXX;
case RGB_LOOP: ...
case FADE: ...
Thanks Guys!!
Will do
