Help writing a library that decodes IR remotes
Hello, I'm trying to write a library that decodes signals from a433 MHz RF remote. I've plugged in the receiver and I can see some data being sent, as you can see from the image.
The protocol of the remote is known:
However, I have these questions:
  • how can I distinguish noise from real data?
  • how can I read the data from the sensor? (I've seen that most libraries use an interrupt, but then, what happens if there are two ones? Obviously I could save the timestamp / look every x us) And this brings me to:
  • How can I know when a bit should come?
Attached below you'll find my code and a screenshot of the serial plotter
  pinMode(8, INPUT);
  if (!digitalRead(7)) {
    /*Serial.print(micros());
    Serial.print(", ");*/
    Serial.println(analogRead(A1));
Look at IRMP GitHub - IRMP-org/IRMP: Infrared Multi Protocol Decoder it supports also RF remotes.
