ms2000:
dear ieee488, you are wrong by saying i dont value the software part,
its just that think the modification i need is not much work, the parallel of me debugging a hardware glitch,
but unfortionalty most members prefer to spend 5 minutes to analyze my texts and be offended instead of just offering the right help...
W2RG thank you, unfortunately my lack of knowledge in programming holds me back for adjusting this code to my needs,
i will probably try to ask some friends for help... as someone who knows the code will have to compile it...
It's not that I don't want to help, but it seems to me you're either not at a level of knowledge about programming that you're even able to try for yourself, starting small, and asking advice along the way, or alternatively, you just want it all served to you, ready to run.
I am a software person, but when it comes to hardware, its in it's nature that I have to do it myself. If I didn't know how to read a simple electronics diagram, and in general did not know how any parts work or what they are named, not being able to even ask questions or understand any response, then however much I may want to build something, it is just not going to happen.
Your way of asking for help is like if I were to ask someone knowledgable in electronics not just to suggest a solution in text or diagram form, but to solder it together, test it, and physically send it to me.
That's what poeple are reacting to. There is no shame in not knowing, but not being capable of, or not bothering to think, experiment and learn, you're not going to get anywhere. If the current project is too complex for your skills, then start with something easier, that's the way it is for all of us.
This is a resource group, not a manufacturing team.
I have delivered (close to) working code to people on this group, but that's for stuff that I readily know how to do, or for things I wanted to research on my own. Whipping up some C++ classes and doing some I2C, as well as switches and LED's, is within my level of comprehension. I'm not a big fan of all those asking to "simply" merge two pieces of code into one. You may look at several examples and incorporate pieces into your solution, but you have to write it yourself. How else are you going to debug and modify it? Which you will!
Also, asking for code to interface "a digital flowmeter", or some "shield", is far too loosely defined.
Please don't think that I'm angry or upset. What I want you to take home from this reply, is the need to start learning what you need to learn, which means getting more familiar with the software side of microcontrollers. Microcontrollers are about hardware AND software.
You have many aha's ahead of you, with regards to software, just as I have with hardware. Heck, last August I didn't know what a pullup resistor was.
