HELP?
Hello,
I'm building a project that's very similar to this --> http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads
(http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads)
just like stated in this website. I'm doing this for a short project.
I did everything that was in that website and it work like a charmed. Now, i want to add an MAN72 led display or a led bar to represent the speed of the motor as i decrease or increase the output level of the potentionmeter, how can i make it work?
here my latest work:
Look at:-
Thanks you for your response,
Indeed i see how now but as for the code, can i add it to my recent program?
Example;
const int transistorPin = 9;
pinMode(transistorPin, OUTPUT);
int sensorValue = analogRead(A0);
int outputValue = map(sensorValue, 0, 1023, 0, 255);
analogWrite(transistorPin, outputValue);
const int analogPin = A0;
const int ledCount = 10;
int ledPins[] = {
2, 3, 4, 5, 6, 7,8,9,10,11 };
for (int thisLed = 0; thisLed < ledCount; thisLed++) {
pinMode(ledPins[thisLed], OUTPUT);
int sensorReading = analogRead(analogPin);
int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
if (thisLed < ledLevel) {
digitalWrite(ledPins[thisLed], HIGH);
else {
digitalWrite(ledPins[thisLed], LOW);
Please point me to the right direction?
You can't have two "loop" functions, so you're going to have to merge the code.
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
AWOL:
Thank you for your suggestion but perhaps you can write the code for me if its not too much t ask, if not its ok? I will go into "how to merge the code" in here but it might take a lot of time for me to follow? :frowning:
Grumpy_Mike:
Thank you, i will see and try it out. Hopefully i will understand?
