Hi All,
I'm trying to create a simple system on arduino using a stepper motor, a dc motor and a servo.
I need the system to soft start.
Any help would be greatly appreciated
Thanks.
Hi All,
Thanks.
Whatever that means.
(deleted)
soft start - needing the dc motor to start slowly and accelerate to a faster speed.
i have no code or wiring done as im unsure as to what to do.
its a project
i need to simulate a glass engraver program.
all im being told is that the system should soft start, and the grinding wheel should be brought into contact with the glass. (simulated using a servo and a dc motor i think)
and the stepper motor simulates the carriage device moving the glass.
I could just use a little advice if possible.
thanks
Take a look at analogWrite. It will let you control DC motor speed using PWM. Note though that you'll need an external power supply and a transistor to switch it - the Arduino won't be able to directly power the motor.
Thanks, i’ll give it a bash.
