Help...
I am new to arduino, I need answers on simple matters....
  • Is there a problem if I remove atmega328 then put it back correctly and it does not work?
-how to reset the duemilanove?
thanks.
I've removed the chip then replaced it, and it still worked. I don't know what your problem is.
Pressing the reset button?
... then put it back correctly...
Sure? Are you sure, you 've not bent a pin under the circuit while putting it back? Or stressed the board if not on a flat surface when you put the circuit back?
Remove it again and inspect the pins to make sure none bent inwards. Also be sure it is inserted with pin 1 of the chip matching pin 1 of the socket.
Lefty
