Hii all,
i got an arduino uno and i have a problem. I tried pretty much everything and i can't figure out why it doesn't work.
Here is the problem. When i connect my arduino to my computer the on light goes on and the L (i believe it's led) starts blinking very fast and has a very low light. When i open my arduino software i tried to insert a blank code and here is the thing i don't get. I got this code
vrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.
I did check if the board was connected right, if i got the right port and all the settings i checked. I checked the cable itself (not the problem, cause on another arduino uno it does work), i checked if it were my usb ports (also was not it cause on another arduino it works normally).
I'm kind of out of options here. Someone please help me!!
