help........................
hi, please can anyone help me in this project it depends on a password when i enter the password it must activate but instead it deactivate :
#include <LiquidCrystal.h>
#include <Wire.h>
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
#include <Servo.h>
#include "RTClib.h"
//Servo
Servo myservo;        // create servo object to control a servo
int pos = 90;         // variable to store the servo position
int passwd_pos = 15;  // the postition of the password input
//Real Time Clock
RTC_DS1307 RTC;
//Password
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] = { // Define the Keymap
  '1','2','3','A'      }
  '4','5','6','B'      }
  '7','8','9','C'      }
  '*','0','#','D'      }
byte rowPins[ROWS] = {
46, 47, 48, 49};     //connect to the row pinouts of the keypad
byte colPins[COLS] = {
50, 51, 52, 53};     //connect to the column pinouts of the keypad
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // Assignign arduino pins to LCD display module
//Stroke LED Lights
int ledDelay = 50; // delay by 50ms
int redPin = 29;
int bluePin = 31;
//constants for LEDs, inputs and outputs
//int blueLED = 36;
int greenLED = 37;
int redLED = 38;
int pirPin1 = 39;
int pirPin2 = 34;
int reedPin1 = 41;
int reedPin2 = 42;
int speakerPin = 35;
//int relay1 = 3; //
int relay2 = 4; // connected to 12V Blue LED strip
int relay3 = 5; // Cam
int relay4 = 6; //
int alarmStatus = 0;
int zone = 0;
int alarmActive = 0;
void setup(){
lcd.begin(20, 4);
//Adding time
Wire.begin();
RTC.begin();
//If we remove the comment from the following line, we will set up the module time and date with the computer one
RTC.adjust(DateTime(__DATE__, __TIME__));
myservo.attach(2);  // attaches the servo on pin 2 to the servo object
displayCodeEntryScreen();
//Police LED Lights
pinMode(redPin, OUTPUT);
pinMode(bluePin, OUTPUT);
//setup and turn off both LEDs
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(relay2, OUTPUT);  //12V Blue LED lighting
pinMode(relay3, OUTPUT);  //camera, 5V external DC supply
pinMode(relay4, OUTPUT);  //
pinMode(pirPin1, INPUT);  //Bedroom 2
pinMode(pirPin2, INPUT);  //Garage
pinMode(reedPin1, INPUT); //Front door
pinMode(reedPin2, INPUT); //Back door
digitalWrite(redLED, LOW);
digitalWrite(greenLED, HIGH);
digitalWrite(speakerPin, LOW);
digitalWrite(relay2, HIGH); // 12V Blue LED lighting
digitalWrite(relay3, HIGH); // camera, 5V external DC supply
digitalWrite(relay4, LOW); //
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
myservo.write(pos);
void loop(){
//display time and date
DateTime now = RTC.now();
//DATE
lcd.setCursor(0,1);
lcd.print(now.month(), DEC);
lcd.print('/');
//We print the day
lcd.print(now.day(), DEC);
lcd.print('/');
//We print the year
lcd.print(now.year(), DEC);
lcd.print(' ');
//TIME
lcd.setCursor(13,1);
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.setCursor(16,1);
lcd.print(now.minute(), DEC);
//lcd.print(':');
//lcd.print(now.second(), DEC);
//delay(1000);
keypad.getKey();
//Serial.println(digitalRead(reedPin2));
//Serial.println(digitalRead(pirPin));
//Serial.println(digitalRead(pirPin2));
if (alarmActive == 1){
  if (digitalRead(pirPin1) == HIGH)
    zone = 0;
    alarmTriggered();
  if (digitalRead(reedPin1) == LOW)
    zone = 1;
    alarmTriggered();
  if (digitalRead(reedPin2) == LOW)
    zone = 2;
    alarmTriggered();
  if (digitalRead(pirPin2) == HIGH)
   zone = 3;
   alarmTriggered();
/////////////////////////  Functions  /////////////////////////////////
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
  if (passwd_pos - 15 >= 5) {
    return ;
  lcd.setCursor((passwd_pos++),0);
  switch (eKey){
  case '#':
    passwd_pos  = 15;
    checkPassword();
  case '*':
    password.reset();
    passwd_pos = 15;
  default:
    password.append(eKey);
    lcd.print("*");
void alarmTriggered(){
int expected_pos;
int incr;
digitalWrite(speakerPin, HIGH);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
digitalWrite(redPin, HIGH);
password.reset();
alarmStatus = 1;
// alarmActive = 0;
lcd.clear();
lcd.setCursor(0,2);
lcd.print("  SYSTEM TRIGGERED  ");
lcd.setCursor(0,4);
if (zone == 1)
  lcd.print("  Front Door Open  ");
  expected_pos = 65;
 if(zone == 0){
  expected_pos = 40;
  lcd.print("Motion in Bedroom 1 ");
else if(zone == 2){
  expected_pos = 10;
  lcd.print("Backdoor Open");
 else if(zone == 3){
   expected_pos = 145;
 lcd.print("Motion in Garage");
 if (expected_pos > pos) {
   incr = 1;
   incr = -1;
 for (pos = pos; pos != expected_pos; pos += incr) {
  myservo.write(pos);
  delay(5);
 StrokeLight();
void StrokeLight(){
  delay(ledDelay);
  digitalWrite(redPin, LOW);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
  delay(10);
  digitalWrite(bluePin, HIGH);
  delay(ledDelay);
  digitalWrite(bluePin, LOW);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
  delay(ledDelay);
void checkPassword(){
if (password.evaluate())
  if(alarmActive == 0 && alarmStatus == 0)
    activate();
  else if( alarmActive == 1 || alarmStatus == 1) {
    deactivate();
else {
  invalidCode();
void invalidCode()
password.reset();
lcd.clear();
lcd.setCursor(1,0);
lcd.print("INVALID CODE! LOL!");
lcd.setCursor(5,2);
lcd.print("TRY AGAIN!");
digitalWrite(greenLED, LOW);
digitalWrite(redLED, HIGH);
delay(2000);
void activate()
if((digitalRead(reedPin1) == HIGH) && (digitalRead(reedPin2) == HIGH)){
digitalWrite(2, HIGH);
lcd.setCursor(0,0);
lcd.print("SYSTEM ACTIVE!");
alarmActive = 1;
password.reset();
delay(2000);
else{
  deactivate();
void deactivate()
alarmStatus = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" SYSTEM DEACTIVATED!");
alarmActive = 0;
password.reset();
delay(5000);
void displayCodeEntryScreen()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter PIN:");
lcd.setCursor(0,2);
lcd.print("Home Security System");
lcd.setCursor(0,3);
lcd.print("By Jun Peng, TECH169");
please help
You have posted code without using code tags. This creates certain problems and obstacles for other forum members. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click.
If you have already posted without using code tags, open your message and select “modify” from the pull down menu labelled, “More”, at the lower left corner of the message. Highlight your code by selecting it (it turns blue), and then click on the “</>” icon at the upper left hand corner. Click on the “Save” button. Code tags can also be inserted manually in the forum text using the [code] and [/code] metatags.
When you are finished that, please read these two posts:
How to use this forum - please read.
and
Read this before posting a programming question …
I guess you found the code here: https://github.com/techfixpros/HomeSecuritySystem Apart from echoing the good advice above, the only other recommendation I can give at the moment is that a password of '1234' should not be used to protect high value assets.
thanks
6v6gt: a password of '1234' should not be used to protect high value assets.
Maybe it would be ok, sort of double-bluff thinking. Good Guy thinks that Bad Guy thinks nobody would be crazy enough to use "1234" as a password, hoping Bad Guy won't try it :)
JimboZA: Maybe it would be ok, sort of double-bluff thinking.
NO. (But I presume you were joking).
It does not take the Bad Guy very long to try 1234 just in case. Probably doesn't take all that long to try all 9999 options either.
...R
Robin2: NO. (But I presume you were joking).
...R
Yes, a 4 digit password would not sustain a determined brute force attack for very long. However, if the device was booby trapped to self destruct after a small number of unsuccessful attempts, then it could be considered secure. Apple incorporated similar technology in its iPhone product to destroy encryption certificates after a certain number of failed accesses (ongoing case with FBI).
JimboZA: Maybe it would be ok, sort of double-bluff thinking. Good Guy thinks that Bad Guy thinks nobody would be crazy enough to use "1234" as a password, hoping Bad Guy won't try it
Don't know about that - that password is number four on the list!
karrar94, you have learned how to edit, so please go back and correct the subject line in your first post.
