help
Sketch uses 6,158 bytes (19%) of program storage space. Maximum is 32,256 bytes.
Global variables use 32 bytes (1%) of dynamic memory, leaving 2,016 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
help please
There is a good chance your Arduino is NOT on COM 1
Open the IDE and select the correct COM port in there
TOOLS
PORT
and select the correct one.
Match that to what you see in DEVICE MANAGER for windows under com ports.
If you don't see it there you may require a driver.
If your board is a real genuine Arduino they are stored in the "drivers" folder of the Arduino installation.
If its a clone board then the CH340 or CH420 drivers can be found on google.
Any extra help you can provide to assist would be welcome. pictures of the board or a link to your supplier etc. Operating system, type of USB ports being used and so on
