Help!
I have my project hooked up to two buttons 2 and 3, The code is checking for an update on the two buttons then it displays it in the serial monitor D1 (Door 1) works fine but when I press D2 (Door 2) it displays the text for D1 and D2
This is my code:
int D1 = 2;
int D2 = 3;
int D1state = 0;
int lastD1state = 0;
int D2state = 0;
int lastD2state = 0;
//Start Serial
Serial.begin (9600);
// Initalize Door D1
pinMode(D1, INPUT);
pinMode(D2, INPUT);
Serial.print(">Executing startup.sh");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
Serial.println(".");
delay (500);
Serial.print(">Executing libaries.sh");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (500);
Serial.print(">Executing buttons.sh");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (500);
Serial.println(" ");
Serial.println(">Ready");
// read the pushbutton input pin:
D1state = digitalRead(D1);
D2state = digitalRead(D2);
// compare the buttonState to its previous state
if (D1state != lastD1state) {
// if the state has changed, increment the counter
if (D1state == HIGH) {
Serial.println("--------------------------");
Serial.print(">Executing open_door1.sh");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (500);
Serial.print(">Initiating");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (1500);
Serial.println(">Success!");
delay (1000);
Serial.println(">Ready"); // Ready to receive commands
if (D2state != lastD2state) {
if (D2state == HIGH) {
Serial.print(">Executing open_door2.sh");
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (500);
delay (500);
Serial.print(".");
delay (500);
Serial.print(".");
delay (500);
delay (1500);
delay (1000);
 delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
 delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
 delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
What's all that bollocks?
Where are the code tags?
Oh, Its the "Startup" procedure its meant to replicate a AI startup, Its just aesthetics
If you press ctrl-T in the IDE (or cmd-T on a Mac) you'll see your bug
J-M-L:
That didnt fix it
He didnt say "fix it", he said "see"
BryceTech:
Its just aesthetics
I've never seen "bollocks" spelled like that.
I am working on a project that opens and closes doors. There are two buttons hooked up D1 is hooked up to pin 2. D2 is connected to pin 3. The code right now is supposed to detect a change in the state of the buttons and when a change is detected display is in the serial monitor. when I press D1 it works completely fine. But when I press D2 it Displays the text for D1 first and also rind D2 text when it is supposed to only display D2 text with pressing D2 and D1 text with pressing D1.
int D1 = 2;
int D2 = 3;
int D1state = 0;
int D2state = 0;
  //Start Serial
  pinMode(D1, INPUT);
  pinMode(D2, INPUT);
  delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
  delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
  delay (500);
  Serial.print(".");
  delay (500);
  Serial.print(".");
  delay (500);
  delay (500);
      delay (500);
      Serial.print(".");
      delay (500);
      Serial.print(".");
      delay (500);
      delay (500);
      delay (500);
      Serial.print(".");
      delay (500);
      Serial.print(".");
      delay (500);
      delay (1500);
      delay (1000);
        delay (500);
        Serial.print(".");
        delay (500);
        Serial.print(".");
        delay (500);
        delay (500);
        delay (500);
        Serial.print(".");
        delay (500);
        Serial.print(".");
        delay (500);
        delay (1500);
        delay (1000);
Don't cross post!
How is your wiring? Straight from 5 V to hour pin? I suspect your pin is floating and you get false readings.
You also have lots of delays giving you a very laggy experience. Remove and / or reduce some of them for a more responsive code.
You forgot to set lastD1state and lastD2state anywhere in loop().
Where do you update lastD1state and lastD2state?
I have figured out how to update both buttons but randomly nothing happens when I press either button but sometimes it works flawlessly.
const int  switchOnePin = 2;    // digital in 2 (pin the switch one is attached to)
const int  switchTwoPin = 3;    // digital in 3 (pin the switch two is attached to)
int switchOneState = 0;         // current state of the switch
int lastSwitchOneState = 0;     // previous state of the switch
int switchTwoState = 0;
int lastSwitchTwoState = 0;
  //initialize serial communication at 9600 bits per second:
  int lastSwitchOneState = 0;     // previous state of the switch switch pins as an input
  pinMode(switchOnePin, INPUT);
  pinMode(switchTwoPin, INPUT);
  // read the switch input pins:
  switchOneState   = digitalRead(switchOnePin);
  switchTwoState   = digitalRead(switchTwoPin);
  // compare the switchState to its previous state
  if (switchOneState != lastSwitchOneState) {
    if (switchOneState == HIGH) {
      // if the current state is HIGH then the button
      // went from off to on:
      Serial.println("Switch one is on");
      // if the current state is LOW then the button
      // went from on to off:
      Serial.println("Switch one is off");
  if (switchTwoState != lastSwitchTwoState) {
    if (switchTwoState == HIGH) {
      Serial.println("Switch two is on");
      Serial.println("Switch two is off");
  // Delay a little bit to avoid bouncing
  delay(50);
  // save the current state as the last state,
  //for next time through the loop
  lastSwitchOneState   = switchOneState;
  lastSwitchTwoState   = switchTwoState;
Buttons "bounce". You should read up on button debouncing techniques, or use one of the available libraries.
It is not nearly as simple to handle (i.e. with a 50 ms delay) as you seem to think.
@BryceTech, stop cross-posting. Threads merged.
