HELP!!!
I have a problem using the ttl camera with Arduino, I keep getting the following error when trying to upload the code.
In file included from C:\Users\aa6888th\Desktop\Arduino\arduino-camera-wifi-master\camera_test\camera_test.ino:16:0:
\EmpFS2\Home\aa6888th\Arduino\libraries\Adafruit-VC0706-Serial-Camera-Library-master/Adafruit_VC0706.h:66:7: error: redefinition of ‘class Adafruit_VC0706’
class Adafruit_VC0706 {
In file included from C:\Users\aa6888th\Desktop\Arduino\arduino-camera-wifi-master\camera_test\camera_test.ino:7:0:
\EmpFS2\Home\aa6888th\Arduino\libraries\Adafruit-VC0706-Serial-Camera-Library-master/Adafruit_VC0706.h:66:7: error: previous definition of ‘class Adafruit_VC0706’
exit status 1
Error compiling for board Arduino/Genuino Uno.
Below is my Code
#include <Adafruit_CC3000.h>
#include <Adafruit_CC3000_Server.h>
#include <ccspi.h>
#include <RTClib.h>
#include <Adafruit_VC0706.h>
This is a sketch to test the camera module
Written by Marco Schwartz for Open Home Automation.
// Include camera libraries
#include <SoftwareSerial.h>
// Software serial & camera instance
SoftwareSerial cameraconnection = SoftwareSerial(A0, A1);
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
Serial.println(“Camera test”);
// Try to locate the camera
if (cam.begin()) {
Serial.println(“Camera found:”);
Serial.println(“Camera not found !”);
return;
// Set picture size
cam.setImageSize(VC0706_640x480);
// Wait 3 seconds before taking a picture
Serial.println(“Picture in 3 seconds …”);
delay(3000);
if (! cam.takePicture())
Serial.println(“Failed to snap!”);
Serial.println(“Picture taken!”);
This is what I am trying to do.
https://openhomeautomation.net/wireless-camera/
This is the Camera I am using
https://www.amazon.com/Spinel-Serial-Compatible-Arduino-Solutions/dp/B00UZJABYG/ref=sr_1_6?ie=UTF8&qid=1494894867&sr=8-6&keywords=ttl+camera
The issue is that you did “#include <Adafruit_VC0706.h>” twice.
This is actually bad code on Adafruit’s part – there is apparently no duplicate checking.
Just remove one and you should be good to go!
P.S. For future posts, put your code in code tags :wink:
"How to use this forum" number 6
6. Make a meaningful subject line
And number 7
7. If you are posting code or error messages, use "code" tags
Go back and read the entire sticky post and try again. :slight_smile:
