HELP....
Ajuda por favor. Help Pls.
GOSTAVA DE SABER COMO FASSO PARA CONSEGUIR FAZER ESSAS DUAS TAREFAS AO MESMO TEMPO SENDO QUE, A PRIMEIRA TAREFA É O CONTROLO DE UM MOTOR DE PASSO, VAL = VALOR DO POTENCIOMETRO, E A SEGUNDA PARTE É PARA FAZER CICLOS, X TEMPO PARA A DIREITA X TEMPO PARA ESQUERDA.
ESTOU UTILISANDO UM LCD KEYPAD SHIELD PARA DETERMINAR O TEMPO TOTAL, CRONOMETRO, QUE CONTA PARA BAIXO 10, 9, 8, ...
A ESSE TEMPO DIVIDO PELO NUMERO DE CICLOS QUE EU DETERMINEI, NESTE CASO 4.
ENTÃO SE O UTILISADOR PRETENDE QUE A MAQUINA ESTEJA LIGADA DURANTE 20 SEGUNDOS ENTÃO É 20 / 4 = 5 SEGUNDOS
DE 5 EM 5 SEGUNDOS ELA MUDA DE DIREÇÃO, RODA PARA A DIREITA, 5 SEGUNDOS DEPOIS RODA ESQUERDA E ASSIM VAI.
I LIKE TO KNOW HOW TO FASE TO DO THESE TWO TASKS AT THE SAME TIME AS THE FIRST TASK IS THE CONTROL OF A STEP MOTOR, VAL = POTENTIOMETER VALUE, AND THE SECOND PART IS TO MAKE CYCLES, X TIME TO THE RIGHT X TIME LEFT.
I'M USING A KEYPAD SHIELD LCD TO DETERMINE THE TOTAL TIME, TIMER, countdown ( 10, 9, 8, ...)
TO THAT TIME DIVIDED BY THE NUMBER OF CYCLES I DETERMINED, IN THIS CASE 4.
THEN IF THE USER INTENDS THAT THE MACHINE IS CONNECTED FOR 20 SECONDS THEN IS 20/4 = 5 SECONDS
OF 5 IN 5 SECONDS SHE CHANGE OF DIRECTION, WHEEL TO RIGHT, 5 SECONDS AFTER LEFT WHEEL AND SO GO.
CC = (TIMER TIME THE USER WANTS THE MACHINE TO BE WORKING / 4)
HOW DO I DO IT TO JOIN ??
CC = (TEMPO DO TIMER QUE O UTILISADOR QUER QUE A MAQUINA ESTEJA TRABALHANDO / 4)
COMO FAÇO PARA ELA TRABALHAR EM CONJUNTO??
// ---------------- PRIMEIRA PARTE ------- FIRST STEP-----------
if ( xx == 1) { int val = analogRead(A1) + 340; // 280 ou mais
digitalWrite(11, HIGH); // 380 +/- / 350 / 400 micro segundos - 0 no potenciometro 25000 - 2023 potenciometro delayMicroseconds (val); digitalWrite(11, LOW); delayMicroseconds (val);// val
} // ----------------- FIM DA PRIMEIRA PARTE ---------- END OF FIRST STEP ---------
// ---------------- SEGUNDA PARTE -------------- SECOND STEP ----
if ( xx== 1) {
digitalWrite(32, LOW); delay(CC); digitalWrite(32, HIGH); delay(CC); }
// --------- FIM DA SEGUNDA PARTE ----------- END
Porque é que metes tudo em caps??? Isso é doloroso de ler!!!!
Abre o exemplo blink without delay e vê como usar a função millis().
