im new too this so what is wrong wit this code keep gettin function message
FirstCode.ino (1.4 KB)
Without looking deeply, your braces ('{') are misplaced.
Use CTRL T to format your code.
Attach your sketch between code tags
[code]Paste your sketch here[/code]
Check your braces { }
41Elysian:
How about posting the message ?
...R
41Elysian:
Where does the setup() function end ?
Just post the code, in code tags.
int redLEDPin=9; // redLedpin is int on pin9
int yellowLEDPin=10; // yellow pin is on int pin10
int redOnTime=1000; // red on this time
int yellowOnTime=500; // yellow on this time
int redOffTime=100; // red off time
int yellowOffTime=100; // yellowOffTime
int greenLEDPin=11; // green pin11
int greenOnTime=1000; // on time
int greenOffTime=500; // off
int blueLEDPin=6;
int blueOnTime=500;
int blueOffTime=500;
int turquiseLEDPin=12;
int turquiseOnTime=500;
int turquiseOffTime=40;
int whiteLEDPin=3;
int whiteOnTime=500;
int whiteOffTime=40;
pinMode(redLEDPin,OUTPUT);
pinMode(yellowLEDPin,OUTPUT);
pinMode(greenLEDPin,OUTPUT);
pinMode(blueLEDPin,OUTPUT);
pinMode(turquiseLEDPin,OUTPUT);
pinMode(whiteLEDPin,OUTPUT);
digitalWrite(redLEDPin,HIGH); // turn red on
delay(redOnTime);
digitalWrite(redLEDPin,LOW); // turn off red
delay(redOffTime);
digitalWrite(yellowLEDPin,HIGH); // turn on
delay(yellowOnTime);
digitalWrite(yellowLEDPin,LOW); // turn off
delay(yellowOffTime);
digitalWrite(greenLEDPin,HIGH); //turn on
delay(greenOnTime);
digitalWrite(greenLEDPin,LOW); // off
delay(greenOffTime);
digitalWrite(whiteLEDPin,HIGH);
delay(whiteOnTime);
digitalWrite(whiteLEDPin,LOW);
delay(whiteOffTime);
digitalWrite(turquiseLEDPin,HIGH);
delay(turquiseOnTime);
digitalWrite(turquiseLEDPin,LOW);
delay(turquiseOffTime);
Braces MUST always be in pairs, opening { and closing }. You have 3 {{{ and only 1 }. That can never work.
Steve
