Help
Hey im new to arduino and i was wondering if someone could check this code.
#include <Servo.h>
//Drive pins
const int motor1Forward = 3;
const int motor1Backward = 4;
const int enablePin1 = 7;
//Steering pins
const int motor2Forward = 5;
const int motor2Backward = 6;
const int enablePin2 = 8;
//Serial information varriables
char inSerial;
//Pan Variables
Servo panServo;           //Panning servo
const int panPin = 10;
bool bPan;                // If true enables the ability for the servo to pan
bool bPanDirPos;          //If true servo should pan only in the positive direction
float panSpeed = .01;     //Degrees in which servo pans per tic
float panVal = 60;        //Panning servo starting position
//Tilt Variables
Servo tiltServo;           //Tilting servo
const int tiltPin = 9;
bool bTilt;                // If true enables the ability for the servo to tilt
bool bTiltDirPos;          //If true servo should tilt only in the positive direction
float tiltSpeed = .01;     //Degrees in which servo tilts per tic
float tiltVal = 60;        //Tilting servo starting position
  Serial.begin(115200);      //serial connection number
  pinMode(motor1Forward, OUTPUT);
  pinMode(motor1Backward, OUTPUT);
  pinMode(enablePin1, OUTPUT);
  pinMode(motor2Forward, OUTPUT);
  pinMode(motor2Backward, OUTPUT);
  pinMode(enablePin2, OUTPUT);
  digitalWrite(enablePin2, HIGH);
  Serial.println("Setup Complete");
  //Initalize Servos to starting positions
  //Pan Servos
  panServo.attach(panPin);
  panServo.write(panVal);
  bPan = false;
  bPanDirPos = true;
  //Initalize Tilt Servos
  tiltServo.attach(tiltPin);
  tiltServo.write(tiltVal);
  bTilt = false;
  bTiltDirPos = true;
void SteerLeft()
  digitalWrite(motor2Forward, HIGH);
  digitalWrite(motor2Backward, LOW);
  digitalWrite(enablePin1, HIGH);
  digitalWrite(motor1Forward, LOW);
  digitalWrite(motor1Backward, HIGH);
void SteerRight()
  digitalWrite(motor2Forward, LOW);
  digitalWrite(motor2Backward, HIGH);
  digitalWrite(motor1Forward, HIGH);
  digitalWrite(motor1Backward, LOW);
void SteerStop()
  digitalWrite(enablePin2, LOW);
  digitalWrite(motor2Forward,LOW);
  digitalWrite(motor2Backward,LOW);
  digitalWrite(enablePin1, LOW);
void DriveForward()
  digitalWrite(motor2Forward,HIGH);
void DriveBackward()
  digitalWrite(motor2Backward,HIGH);
void DriveStop()
void PanUp()
  bPan = true;
  bPanDirPos = true;
void PanDown()
  bPan = true;
  bPanDirPos = false;
void PanStop()
  bPan = false;
void TiltUp()
  bTilt = true;
  bTiltDirPos = true;
void TiltDown()
  bTilt = true;
  bTiltDirPos = false;
void TiltStop()
  bTilt = false;
   //read the serial data into the buffer
  if(Serial.available() > 0)
    inSerial = Serial.read();
     if(inSerial == 'w')
          DriveForward();
      else if(inSerial == 'b')
          DriveBackward();
      else if(inSerial == 's')
          DriveStop();
      else if(inSerial == 'a')
        SteerLeft();
      else if(inSerial == 'd')
         SteerRight();
      else if(inSerial == 'q')
         SteerStop();
      else if(inSerial == 'p')
        PanUp();
      else if(inSerial == 'o')
        PanDown();
      else if(inSerial == 'n')
        PanStop();
      else if(inSerial == 't')
        TiltUp();
      else if(inSerial == 'g')
        TiltDown();
      else if(inSerial == 'x')
        TiltStop();
//Controll panning
if(bPan)
	if(bPanDirPos)
		if(panVal<180)
			panVal+=panSpeed;
		if(panVal>0)
			panVal-=panSpeed;
//Controll Tilting
if(bTilt)
	if(bTiltDirPos)
		if(tiltVal<180)
			tiltVal +=tiltSpeed;
		if(tiltVal>0)
			tiltVal-=tiltSpeed;
What does the compiler say?
It said that it is good but i cant get it to work with my project that i am building. Also that project that i am working on is like an rc car. But the arduino board controls a sn754410 motor drive ic, which controls two 3v motors. The arduino board also controls a set of servos that are mounted on the front.
What does/doesn't it do?
Debug prints would be useful
