I was investigating in the forum about a Sumobot´s programming. However i didn´t found what i wanted so i decided open a new topic about it.
I have the IR program :
int ir1 = 2;
pinMode(ir1; INPUT);
int estado = digitalRead(ir1);
Serial.println(estado);
delay(1);
The Ultrasoinc sensors:
long distancia; //distancia= distance
long tiempo; // tiempo= time
int m1=10; //m1 here is a led
pinMode(9,OUTPUT);
pinMode(8,INPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
digitalWrite(9,LOW);
delayMicroseconds(10);
digitalWrite(9,HIGH);
delayMicroseconds(20);
digitalWrite(9, LOW);
tiempo=pulseIn(8,HIGH);
distancia=int(0.017*tiempo);
Serial.println("Distancia ");
Serial.print(distancia);
Serial.println(" cm");
if (distancia<80&&distancia>0)
{ Serial.println ("Atack 12V");
digitalWrite(m1,HIGH);
{digitalWrite(m1,LOW);
And it is now my program
int IRD=2, IRTI=3, IRTD=4, EDI=5, TDI=6, EDD=7, TDD=8, EI=9, TI=10, ED=11, TD=12, led=13, pul=14, MAI=15, MAD=16, MRI=17, MRD=18;
long distancia;
long tiempo;
pinMode(2;INPUT);
pinMode(3;INPUT);
pinMode(4;INPUT);
pinMode(5;INPUT);
pinMode(6;OUTPUT);
pinMode(7;INPUT);
pinMode(8;OUTPUT);
pinMode(9;INPUT);
pinMode(10;OUTPUT);
pinMode(11;INPUT);
pinMode(12;OUTPUT);
pinMode(13;INPUT);
pinMode(14;INPUT);
pinMode(15;INPUT);
pinMode(16;INPUT);
pinMode(17;INPUT);
pinMode(18;INPUT);
pinMode(19;INPUT);
pinMode(20;INPUT);
enc=0;
int lb1 = digitalRead(IRD);
int lb2 = digitalRead(IRTI);
int lb3 = digitalRead(IRTD);
if ( digitalRead(pul)==HIGH && enc=0 )
{ digitalWrite(led==HIGH);
delay(5000);
enc=1;
if (digitalRead(pul)==HIGH && enc=1)
{digitalWrite(led==LOW);
delay(100);
enc=0;
if (enc==1) {
//program here!
void avanzar () { //forward
digitalWrite(MRI==LOW);
digitalWrite(MRD==LOW);
delay(5);
digitalWrite(MAI==HIGH);
digitalWrite(MAD==HIGH);
void giroizq () { //turnleft
digitalWrite(MAI==LOW);
delay(5);
digitalWrite(MRI==HIGH);
void giroder () { //turnright
digitalWrite(MAD==LOW);
delay(5);
digitalWrite(MRD==HIGH);
void retroceder () { //backward
delay(5);
IRD = IR forward
IRTI = IR BACK LEFT
IRTD = IR BACK RIGHT
EDI = ECHO forward left
TDI = TRIGGER forward left
EDD = ECHO forward right
TDD = TRIGGER forward right
EI = ECHO left
TI = TRIGGER left
ED= ECHO right
TD = TRIGGER right
MAI = motor forward left
MAD = motor forward right
MRI =motor backward left
MRD =motor backward right
Sorry for this but the acronym is in spanish for my classmates and teacher
I used:
3 CNY70
4 hc sr04
2 gearmotors
l298 dual h bridge
Arduino UNO
My problem is how to run the testings sensors simultaneously because if i use delay, the next function won't start until the last function ends. In other words, how to test the IR sensors while motors are ON
Thank you.
