Helps needs to under stand the SD Card data logging program.
First of all i am not an expert person in Arduino.Now i have tried to learn and under stand the program through this type web plat form.So i expecting favorable reply from this community.I want to make data loging in SD card module with the help of arduino Uno.So i collect the program from the gogle and its working fine. Here is my code.
#include <Wire.h>     // lib for RTC
#include "RTClib.h"   // lib for RTC
#include <SPI.h>      // lib for SD
#include <SD.h>       // lib for SD
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 4;
File data;
// set up for RTC
RTC_DS1307 RTC;
// set up for led + button
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  3;      // the number of the LED pin
int buttonState = 0;         // variable for reading the pushbutton status
int pbuttonState;
byte ok;  //stop the loop if SD card was not initialized
byte first=1;
  Serial.begin(57600);
  // led + button
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  // SD
   Serial.print("Initializing SD card...");
   pinMode(10, OUTPUT); // it's needed for SD library to work even if the CS is not connected to pin 10
            // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    ok=0;
  }else{
  Serial.println("card initialized.");
  ok=1;
  // RTC
  Wire.begin();
  RTC.begin();
  // RTC.adjust(DateTime(__DATE__, __TIME__));  // set to pc time
 if(ok==1)
  if(first==1)
  buttonState = digitalRead(buttonPin);
  pbuttonState= buttonState;
  call(buttonState);
  first = 0;
    if(pbuttonState != buttonState)
    {call(buttonState);
    pbuttonState=buttonState;
  delay(100);
String time()
 String dataString = "";
 DateTime now = RTC.now();
 dataString += String(now.year(), DEC);
 dataString += String('/');
 dataString += String(now.month(), DEC);
 dataString += String(now.day(), DEC);
 dataString += String(' ');
 dataString += String(now.hour(), DEC);
 dataString += String(':');
 dataString += String(now.minute(), DEC);
 dataString += String(now.second(), DEC);
return dataString;
void call( int buttonState)
    if (buttonState == LOW) {
    // door is open
    digitalWrite(ledPin, HIGH);
    SDwrite(buttonState);
  else {
    // door is closed
    digitalWrite(ledPin, LOW);
void SDwrite(int state)
String message = "";
if (state==LOW)
{message = "OPEN";}
{message = "CLOSED";}
    data = SD.open("log.txt", FILE_WRITE);
    if (data) {
    if(state == LOW)
    {Serial.print("Door is open");}
    {Serial.print("Door is closed");}
    data.print(time());
    data.print("   ");
    data.println(message);
  // close the file:
    data.close();
    Serial.println("  :done.");
    // if the file didn't open, print an error:
    Serial.println("error opening log.txt");
But i can’t under stand below mentioned line in this code.
if (state==LOW)
{message = "OPEN";}
How the “state” co related with “buttonPin” position?
