bonjour , j'ai une carte Helte ESP32 lora et ESP32-CAM-CH340 ESP32 CP2102 je veux brancher la caméra mai j'ai pas trouveer le code dans l'exemple je trouve seulement sur ESP32 et je veux sur heltec esp32 , pouvez vous m'aider et merci beaucoup
Can you post in English please, this is an English forum.
hello , i want to connect ESP32-CAM with Heltec ESP32 LoRa V3 , i didn't found examples in arduino , just i found with ESPS32 only , can anyone tell me how i connect the espcam and how it works and thank you
Potentially the ESP32CAM could take a picture and you could copy the image over a serial port connection or over WiFi or ESPNOW so the Heltec receives the image, but that is not at all straight forward.
A hardware UART serial connection is the easiest. Look up how to add serial ports to ESP32.
