Heltec WiFi LoRa32 V2 communication with Raspberry Pi (Dragino LoRa/GPS Hat)
I am using LoRa32 as a node to communicate with Raspberry Pi. For now I am able to run the code on both ends but I am not receiving or sending any data to the devices. I am looking for some advice thanks in advance!
Heltec LoRa32 code:
// This program sends a response whenever it receives the “INF” mens
// This file is part of rpsreal/LoRa_Ra-02_Arduino
// Based on example Arduino9x_RX RADIOHEAD library
// It is designed to work with LORA_SERVER
#include <SPI.h>
#include <RH_RF95.h>
#define RFM95_CS 18
#define RFM95_RST 14
#define RFM95_INT 26
// Change to 434.0 or other frequency, must match RX’s freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
// Blinky on receipt
#define LED 13
pinMode(LED, OUTPUT);
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
while (!Serial);
delay(100);
// manual reset
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (!rf95.init()) {
Serial.println(“LoRa radio init failed”);
while (1);
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println(“setFrequency failed”);
while (1);
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
// Bw = 125 kHz, Cr = 4/8, Sf = 4096chips/symbol, CRC on.
// Slow+long range.
//rf95.setModemConfig(RH_RF95::Bw125Cr48Sf4096);
// Defaults after init are 434.0MHz, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
// Medium Range
rf95.setTxPower(18);
Serial.println(“START”);
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.available()){
if (rf95.recv(buf, &len)){
  digitalWrite(LED, HIGH);
  //RH_RF95::printBuffer("Got: ", buf, len);
  Serial.print("Received:  ");
  Serial.println((char*)buf);
  Serial.print("RSSI: ");
  Serial.println(rf95.lastRssi(), DEC);
  if (strcmp("INF",((char*)buf)) == 0){
    Serial.println("Received data request INF");
    delay(2000);
    Serial.println("Send mens: DATA ARDUINO");
    uint8_t data[] = "DATA ARDUINO";
    rf95.send(data, 13); //sizeof(data)
    rf95.waitPacketSent();
  digitalWrite(LED, LOW);
  Serial.println("Receive failed");
Raspberry Pi python code:
import time
from SX127x.LoRa import *
#from SX127x.LoRaArgumentParser import LoRaArgumentParser
from SX127x.board_config import BOARD
BOARD.setup()
BOARD.reset()
#parser = LoRaArgumentParser("Lora tester")
class mylora(LoRa):
    def __init__(self, verbose=False):
        super(mylora, self).__init__(verbose)
        self.set_mode(MODE.SLEEP)
        self.set_dio_mapping([0] * 6)
        self.var=0
    def on_rx_done(self):
        BOARD.led_on()
        #print("\nRxDone")
        self.clear_irq_flags(RxDone=1)
        payload = self.read_payload(nocheck=True)
        print ("Receive: ")
        print(bytes(payload).decode("utf-8",'ignore')) # Receive DATA
        BOARD.led_off()
        time.sleep(2) # Wait for the client be ready
        print ("Send: ACK")
        self.write_payload([255, 255, 0, 0, 65, 67, 75, 0]) # Send ACK
        self.set_mode(MODE.TX)
        self.var=1
    def on_tx_done(self):
        print("\nTxDone")
        print(self.get_irq_flags())
    def on_cad_done(self):
        print("\non_CadDone")
    def on_rx_timeout(self):
        print("\non_RxTimeout")
    def on_valid_header(self):
        print("\non_ValidHeader")
    def on_payload_crc_error(self):
        print("\non_PayloadCrcError")
    def on_fhss_change_channel(self):
        print("\non_FhssChangeChannel")
    def start(self):
        while True:
            while (self.var==0):
                print ("Send: INF")
                self.write_payload([255, 255, 0, 0, 73, 78, 70, 0]) # Send INF
                time.sleep(3) # there must be a better solution but sleep() works
                self.reset_ptr_rx()
                self.set_mode(MODE.RXCONT) # Receiver mode
                start_time = time.time()
                while (time.time() - start_time < 10): # wait until receive data or 10s
                    pass;
            self.var=0
            self.reset_ptr_rx()
            time.sleep(10)
lora = mylora(verbose=True)
#args = parser.parse_args(lora) # configs in LoRaArgumentParser.py
#     Slow+long range  Bw = 125 kHz, Cr = 4/8, Sf = 4096chips/symbol, CRC on. 13 dBm
lora.set_freq(915.0)
lora.set_pa_config(pa_select=1, max_power=21, output_power=15)
lora.set_bw(BW.BW125)
lora.set_coding_rate(CODING_RATE.CR4_8)
lora.set_spreading_factor(12)
lora.set_rx_crc(True)
#lora.set_lna_gain(GAIN.G1)
#lora.set_implicit_header_mode(False)
lora.set_low_data_rate_optim(True)
#  Medium Range  Defaults after init are 434.0MHz, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on 13 dBm
#lora.set_pa_config(pa_select=1)
# assert(lora.get_agc_auto_on() == 1)
try:
    print("START")
    lora.start()
except KeyboardInterrupt:
    sys.stdout.flush()
    print("Exit")
    sys.stderr.write("KeyboardInterrupt\n")
finally:
    sys.stdout.flush()
    print("Exit")
    lora.set_mode(MODE.SLEEP)
    BOARD.teardown()
Thanks in advance for the help!
I did not read it all but this caught my eye: you need to initialise len EACH time before you call the function.
  len = sizeof(buf);
  if (rf95.recv(buf, &len)) {
len is use to tell the recv() function how many bytes are available in the buffer, and then the function modifies the value to let you know how many it actually wrote.
what do you see in the Serial monitor ? anything at all from the setup?
I don't see anything from the serial monitor but my print statement START, not sure what else I would need to print out
Ok just wanted to make sure you were not stuck in setup()
Did you try updating Len?
yes, I updated the Len. I still wasn't able to have the Heltec talk to the RPi.
I'm not sure why it's unable to send packets between each other. I check it is on the same frequency and such. I also ensure the pins were correct on the RPi:
DIO0 = 4
DIO1 = 23
DIO2 = 24
DIO3 = 21
RST = 0
LED = 18
SWITCH = 7
Ive also tested the frequency by changing from 903.2 and 915.0 MHz
Did you update Len was the question
yes I did update Len. not sure if Len is the issue?
// This program sends a response whenever it receives the "INF" mens
#include <SPI.h>
#define RFM95_CS 18
// Change to 434.0 or other frequency, must match RX's freq!
#define LED 13
  while (!Serial);
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    Serial.println("LoRa radio init failed");
    while (1);
    Serial.println("setFrequency failed");
    while (1);
  // Slow+long range.
  // Medium Range
  Serial.println("START");
        delay(2000);
it was one possible issue as it would limit the number of bytes to the min size payload you get as you keep looping.
may be there are other issues...
