Heltec Wireless Stick and OLED
Hi, I recently bought the heltec wireless stick board that has a 0.49 "oled screen, using a very basic example from the heltec library to display text on the screen it works
#include "heltec.h"
  Heltec.begin(true, false, false); // Display, LoRa, Serial
  Heltec.display->clear();
  Heltec.display->drawString(0, 0, "Hello world");
  Heltec.display->display();
but my problem is that I don't want to use the heltec library (which includes the configuration for the display, LoRa and serial port), but if I need something I add it on my own. This is the code I made for the basic example, but it doesn't show anything on the display
#include <Wire.h>
#include "SSD1306Wire.h"
SSD1306Wire display(0x3c, 4, 15, GEOMETRY_64_32);
  display.init();
  display.flipScreenVertically();
  display.clear();
  display.drawString(0, 0, "Hello world");
  display.display();
:thinking:
This module uses RST signals as well as SDA and SCL for I2C OLED.
Probably requires operate RST pin of OLED.
Please use library corresponding to it.
Thanks for your answer. I solved the problem by adding a reset to the pin of the OLED screen in the setup code.
pinMode(16, OUTPUT);
digitalWrite(16, LOW);
delay(50);
digitalWrite(16, HIGH);
