Hep to smooth temp sensor
Hi!
I was wonderin if someone can help me to smooth the temperature reading in code.
See when temperature is hanging just above and under alarm temperature - LED is almost blinking which i don’t need.
#include <OneWire.h>
#include <DallasTemperature.h>
const int ledPin =  13;      // the number of the LED pin
int ledState = LOW;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 3
#define TEMPERATURE_PRECISION 9
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
// function that will be called when an alarm condition exists during DallasTemperatures::processAlarms();
void newAlarmHandler(uint8_t* deviceAddress)
  Serial.println("Alarm Handler Start");
  printAlarmInfo(deviceAddress);
  printTemp(deviceAddress);
  Serial.println("Alarm Handler Finish");
void printCurrentTemp(DeviceAddress deviceAddress)
  printAddress(deviceAddress);
void printAddress(DeviceAddress deviceAddress)
  Serial.print("Address: ");
  for (uint8_t i = 0; i < 8; i++)
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
  Serial.print(" ");
void printTemp(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC != DEVICE_DISCONNECTED)
    Serial.print("Current Temp C: ");
    Serial.print(tempC);
  else Serial.print("DEVICE DISCONNECTED");
  Serial.print(" ");
void printAlarmInfo(DeviceAddress deviceAddress)
  char temp;
  temp = sensors.getHighAlarmTemp(deviceAddress);
  Serial.print("High Alarm: ");
  Serial.print(temp, DEC);
  Serial.print("C");
  Serial.print(" Low Alarm: ");
  temp = sensors.getLowAlarmTemp(deviceAddress);
  Serial.print("C");
  Serial.print(" ");
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
  // locate devices on the bus
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  // search for devices on the bus and assign based on an index
  if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
  Serial.print("Device insideThermometer ");
  printAlarmInfo(insideThermometer);
  Serial.print("Device outsideThermometer ");
  printAlarmInfo(outsideThermometer);
  // set alarm ranges
  Serial.println("Setting alarm temps...");
  sensors.setHighAlarmTemp(insideThermometer, 26);
  sensors.setLowAlarmTemp(insideThermometer, 22);
  sensors.setHighAlarmTemp(outsideThermometer, 25);
  sensors.setLowAlarmTemp(outsideThermometer, 21);
  Serial.print("New insideThermometer ");
  Serial.print("New outsideThermometer ");
  // attach alarm handler
  sensors.setAlarmHandler(&newAlarmHandler);
void loop(void)
  // ask the devices to measure the temperature
  sensors.requestTemperatures();
  // if an alarm condition exists as a result of the most recent
  // requestTemperatures() request, it exists until the next time
  // requestTemperatures() is called AND there isn't an alarm condition
  // on the device
  if (sensors.hasAlarm())
    digitalWrite(ledPin, HIGH);
    Serial.println("Oh noes!  There is at least one alarm on the bus.");
  // call alarm handler function defined by sensors.setAlarmHandler
  // for each device reporting an alarm
  sensors.processAlarms();
  if (!sensors.hasAlarm())
     digitalWrite(ledPin, LOW);
    // just print out the current temperature
    printCurrentTemp(insideThermometer);
    printCurrentTemp(outsideThermometer);
A rolling average would do the trick, or just average 8 or 16 readings. Sum the appropriate number of readings into a big enough datatype, and divide by the number of readings you took.
averaging might help but I imagine you need some sort of hysteresis or a dead-zone in the algorithm. Something like once the (average) temp goes .25 degrees over the set point it's triggered and it won't untrigger unless it's .25 degrees below. That's how a house thermostat works for example.
thanks but how can i do that ? im a complete newby in C++ :-/
http://www.arduino.cc/playground/Code/AverageList
