Heres a Challenging one for yas! :) PinActive code issues...
hey guys so i'm having an issue where i need the sensor on a live stock drafting cage to work with more certainty..
at the moment the sensor detect an animal and clamps the animal. a comand to weigh the animal is sent to a weigh scale unit.
a weight category is sent back...now this is where it gets tricky.. once the weight category is sent back the clamp releases along with a rear gate, and i have set the sensor up to only re activate once a timer has become true..the idea was that the animal should be out by then, then the sensor would be ready for the next animal to enter and be sensed.. however in real life it isnt working like that and i need to hold the sensor from retriggering if an animal is still in there and once it has left begining a very short timer of 1 second before it will re activate..
all help would be much appreciated!
#include <SPI.h>
const int PinOne = 1;
const int PinTwo = 2; //sensor
const int PinThree = 3;
const int PinFour = 4;
const int PinFive = 5;
const int PinSix = 6;
const int PinSeven = 7;
const int PinEight = 8;
const int PinNine = 9;
const int PinTen = 10;
const int PinEleven = 11;
const int PinTwelve = 12 ;// Pin Addresses
int incomingByte;
static bool PinTwoActive;
unsigned long interval = 2000;
unsigned long startTime;
byte lastPress;
byte lastPress1;
byte lastPress2;
byte lastPress3;
byte lastPress4;
// a variable to read incoming serial data into
// initialize serial communication:
Serial.begin(38400);
digitalWrite(PinNine,HIGH);
digitalWrite(PinTen,HIGH);
digitalWrite(PinEleven,HIGH);
digitalWrite(PinTwelve,HIGH);
PinTwoActive = true;
// initialize the pins:
// INPUTS
pinMode(PinTwo, INPUT);
pinMode(PinThree, INPUT);
pinMode(PinFour, INPUT);
pinMode(PinFive, INPUT);
pinMode(PinSix, INPUT);
pinMode(PinSeven, INPUT);
//OUTPUTS
pinMode(PinEight, OUTPUT );
pinMode(PinNine, OUTPUT );
pinMode(PinTen, OUTPUT);
pinMode(PinEleven, OUTPUT);
pinMode(PinTwelve, OUTPUT);
// see if there's incoming serial data:
if (Serial.available() > 0) {
// read the oldest byte in the serial buffer:
incomingByte = Serial.read();
byte pressed1 = (PinTwoActive && digitalRead(PinTwo));
if (pressed1)
if (pressed1 != lastPress1)
Serial.print ("{RH}");
lastPress1 = pressed1;
byte pressed2 = (PinTwoActive && digitalRead(PinTwo));
if (pressed2)
if (pressed2 != lastPress2)
digitalWrite(PinTen, LOW);
lastPress2 = pressed2;
byte pressed3 = (PinTwoActive && digitalRead(PinTwo));
if (pressed3)
if (pressed3 != lastPress3)
digitalWrite(PinNine, LOW);
lastPress3 = pressed3;
if (digitalRead(PinThree)) // Draft Left
digitalWrite(PinEleven, LOW);
digitalWrite(PinTwelve, HIGH);
if (digitalRead(PinFour)) // Draft Centre
digitalWrite(PinEleven, HIGH);
if (digitalRead(PinFive)) // Draft Right
digitalWrite(PinTwelve, LOW);
if (digitalRead(PinSix))
digitalWrite(PinTen, HIGH);//CLAMP REMOTE RELEASE
digitalWrite(PinNine, HIGH); //GATE REMOTE RELEASE
if (incomingByte == '1')
digitalWrite(PinTen, HIGH); // RELEASE COMMAND
if (incomingByte == '2')
if (incomingByte == '3')
PinTwoActive = false; // RELEASE COMMAND
if (incomingByte == '1') // Draft Left
if (incomingByte == '2') // Draft Centre
if (incomingByte == '3') // Draft Right
digitalWrite(PinEight, HIGH);
byte pressed = digitalRead(PinSeven);
if (pressed)
if (pressed != lastPress)
startTime = millis();
lastPress = pressed;
if (digitalRead(PinSeven))
if (millis() - startTime >= interval)
digitalWrite(PinEight,LOW);
Serial.print("{RD}");
PinTwoActive = true; // this is where i need to have some advice.....i only want this to be active once the timer has completed and if the sensor is not triggered at the time...????
You could always add a sensor on the rear gate which detects when that one is closed - once it has been opened after weighing, wait for it to close before resetting for the next animal. (Presumably you close that gate before letting the next one in).
Alternatively, wait for the sensor that detects the animal to show it isn't there anymore, (then maybe wait a bit just in case), then start checking for the next animal.
I would like to help but because you have not put your code in code tags and you have literally dozens of unnecessary blank lines the code is difficult to read and understand. Use code tags and format it better and I will take a look.
One thing that I did notice early on in the code was that you have given totally meaningless names to pins such as
const int PinOne = 1;Why ?
im no expert and am self taught so i appologise for the amature style of my code...im really trying my best here!
NZarduino:
But surely you can see that the layout is crap, particularly the blank lines by the dozen, and you will, of course, have read Read this before posting a programming question ... - Programming Questions - Arduino Forum before posting your programming question.
it makes it a lot easier for me to read which section is which if i add space between...i didn't think it was such an issue?
cheers for the hate dude
"Code tags" are where you type
</mark> <mark>[code]</mark> <mark>
on one line
followed by your code/sketch
and the
</mark> <mark>[/code]</mark> <mark>
on the line after all that.
That makes the window with the slider, you may have noticed.
It's easier on the eyes and keeps the presentation better organized.
I use "devices" like
for example
to section off routines and so on.
Carry on.
Adopt, Adapt, Be Resilient
OK For the benefit of anyone that may want to debug your code, I've taken out all the spaces. Personally I'd rather have all the details of what every pin is connected to and do a complete rewrite.
#include <SPI.h>
int incomingByte;
byte  lastPress;
byte  lastPress1;
byte  lastPress2;
byte  lastPress3;
byte  lastPress4;
  // INPUTS
  //OUTPUTS
  if (pressed1)
  if (pressed2)
    if (pressed3)
  if (pressed)
Hi, after you have weighted the animal, does the weighing device still measure the weight if the animal has not moved off.
You could get the program to wait until the weight measurement is below a certain amount, signifying that the animal has moved on.
Tom..... :slight_smile:
It is a challenge... to make sense of it all.
You should set the pinMode before you set their state:
  digitalWrite(PinNine,HIGH);//<<<<<<<<<<<you are telling PinNine to go HIGH
  // INPUTS
  //OUTPUTS
  pinMode(PinNine, OUTPUT );//<<<<<<<< before you told your arduino that you were going to use it as an OUTPUT
you know that an if statement can accommodate more than one action...?
    digitalWrite(PinTen, HIGH); // RELEASE COMMAND/
    //digitalWrite(PinTen, HIGH); // RELEASE COMMAND/<<<<<<<<<<<<you can put that here<<<<
    //PinTwoActive = false; // RELEASE COMMAND<<<<<<<<<<<<<<<<the other one below... here
or, is it that you really don't yet understand how to handle your serial input here:
i am using one of those RElAY cards that are Activated when they get a signal LOW from the arduino, to counter it i changed my
highs and lows and set the pins for relay output to be high when the system starts to prevent the relays becoming active untill the
loop starts.
But could you give us a list, pin by pin, of what all of your inputs and outputs do?
eg Pin1 Opens Door
Pin2 Activates clamp
pin 3 Sends message to weighing machine
pin 5 Microswitch to front door (high when open)
etc...
Pin0 = bluetooth rx hc 05 unit
pin1 = bluetooth tx hc 05 unit
pin2 = Sensor..on/off
pin3 = handheld remote control, left gate select
pin4 = handheld remote control, centre gate select
pin5 = handheld remote control right gate select
pin6 = handheld remote control clamp and gate release
pin7 & pin 8 are used as a physical logic relay
pin9 output relay left gate
pin10 output relay right gate
pin11 output clamp .... clamps animal
pin12 output Rear gate....stops more animals from entering pen
have you read through this yet?
yes reading currently.. i dont have the time to do a full rewrite..the code i have is working currently its just one thing i want to add to it, does anyone see it being possible given my current code??
NZarduino:
No hate here, just an intense dislike. I agree with your reasons for separating code sections with blank lines, I do it myself, but this is the sort of thing that I was talking about
  if (pressed2)
15 blank lines .......
NZarduino:
Lol. Get a grip, man. This is ridiculous.
How to use this forum
Code tags.
