Herkulex Servo motor with Arduino FIO
Hey folks,
Just having a bit of an issue with my Arduino FIO. I am attempting to connect a Herkulex DRS-201 servo motor to the FIO and control it using a software serial port. I am using a library written for these motors, in the past I have had success using an Arduino Mega on pins 18, 19 for rx,tx. The Herkulex servo comes with a interface manager kit that allows me to run an windows software where I changed the default baud rate to 57600 down from 115200 (to handle software serial).
Here is a bit of sample code I’ve tried and cannot seem to get working.
#include <Herkulex.h>
int n = 0xfd;
int RX = 11;
int TX = 10;
 Herkulex.begin(57600,RX,TX);
 Herkulex.reboot(n);
 Herkulex.initialize();
 delay(200);
  Herkulex.moveOneAngle(n, 90,250,LED_BLUE);
  delay(3000);
  Herkulex.moveOneAngle(n, -90,250,LED_GREEN);
  delay(3000);
Information about the servo:
If the software serial port cannot transmit at 57600 then I want to use the FIO’s hardware serial port. In this case I would rewrite the RX and TX to pins TX0 and RX1, then adjust it in software? Sorry for some fundamental questions, this is my first time using the FIO microcontroller. I setup the FIO for wireless programming, so far that has been working well.
Hopefully you guys can give me some insight on this one.
Thanks!
