"HEX" format for laser
jremington:
That is because the OP is using Serial.print(x,HEX).
Sterretje's approach is the way to go, although I would use snprintf() to simplify the code dramatically.
From the link in reply #5:
So, the first and last three bytes in each received frame could be simply ignored or removed.
I have a laser I am trying to do the same thing with I send a Hex Code to open it which has an address,function code etc and it returns an address,function code,Register number,Measurement and CRC i want to only see the measurement could use some help
burtonrobotics:
You have asked a new question in an old Thread so I am suggesting to the Moderator to move you to your own Thread.
Please post your program and a link to the datasheet for the laser device you are hoping to communicate with.
...R
burtonrobotics:
You have to give a lot more detail and a better description. As I understand it, you have a laser that you want to open?
@burtonrobotics
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
