Hex string (like 01a2b4) to ASCII
Dear Forum,
I am looking for a way to convert a string with hex characters inside into readable ASCII.
For example the hex string would be 6167653d41726b68616d and the expected output is age=Arkham
I tried some suggestions i found onlie but struggle with the dynamic size of the string as well as the conversion into one string with the message in the end.
Does anyone know a awy?
Thanks so much and have a great weekend :slight_smile:
Is the original data in a String or a C style string ?
Show us the code you have so far.
(in code tags)
make a minimal sketch which shows which variable types you are using and what you plan with the new value after having it as ASCII.
edit:
by the way, quite interesting to read what the forum comes up with:
In og. String format
"6167653d41726b68616d"
I am on the go atm
But can show some code but the code itself is hug
isn't a hex string already ascii?
there are 10 bytes. what data type is this? array of bytes?
look this over
output
x = 0x1a2b4
z = 6167653d41726b68616d
long x = 0x01a2b4;
byte z [] = { 0x61, 0x67, 0x65, 0x3d, 0x41, 0x72, 0x6b, 0x68, 0x61, 0x6d };
const int Zlen = sizeof(z);
char s [90];
void
setup (void)
    Serial.begin (9600);
    sprintf (s, "x = 0x%lx", x);
    Serial.println (s);
    int j = 0;
    for (int i = 0; i < Zlen; i++, j += 2)
        sprintf (& s[j], "%02x", z [i]);
    s [j] = '\0';
    Serial.print   ("z = ");
    Serial.println (s);
void loop (void) { }
like this you mean?
  char hex_str[]="6167653d41726b68616d";
  char char_str[(strlen(hex_str)+2)/2]={0};
  int i=0,j=0;
  for(i=0; i < strlen(hex_str); i+=2){
    char temp[3] ={0};
    memcpy(temp,&hex_str[i],2);
    char_str[j++]=strtol(temp, NULL, 16);
  Serial.print("Hex string: ");
  Serial.println(hex_str);
  Serial.print("\nCoverted Hex string: ");
  Serial.println(char_str);
Output:
Hex string: 6167653d41726b68616d
Coverted Hex string: age=Arkham
hope that helps....
thank you for the suggestion.
The issue is I cant get my string (got it in a variable of type String) to a char [] as it can't know the size:
Compilation error: initializer fails to determine size of 'hex_str'
i tried putting the length of the String in to it but get the error
Compilation error: array must be initialized with a brace-enclosed initializer
so I put {} around it and get error
Compilation error: cannot convert 'String' to 'char' in initialization
this is the last one char hex_str[strURI.length()]= {strURI};
did you try using c_str?
yes I did:
        char convertStringURI = strURI.c_str();
        char hex_str[]= convertStringURI;
Compilation error: invalid conversion from 'const char*' to 'char' [-fpermissive]
also tried
        char* convertStringURI = strURI.c_str();
Compilation error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
That's the point.
If YOU had posted a short demo sketch as suggested, you might have gotten an example with a String object not strings...
here's an example using c_str()
  char *str_p;
  String Str = "this is a string";
  str_p = &Str.c_str()[0];
  Serial.println(str_p);
  Serial.println(strlen(str_p));
I let you combine this with code in post #7! :wink:
hope that helps...
I can do a shortened version:
String strURI ="";
strURI = "6167653d41726b68616d";  //example value as value comes from a nfc card and is written to the strURI pair by pair
really don't know what more I should add as code.
The whole code is a mess and huge as I need to clean-up the nfc card functions (reader)
do you want me to post all the code?
no.
I just wanted you to do the ground work
String hexToAscii( String hex )
  uint16_t len = hex.length();
  String ascii = "";
  for ( uint16_t i = 0; i < len; i += 2 )
    ascii += (char)strtol( hex.substring( i, i+2 ).c_str(), NULL, 16 );
  return ascii;
  String strURI ="";
 String out= hexToAscii(strURI);
 Serial.println(out);
will output
age=Arkham
by the way, the function comes from another thread, you could have found if you followed the forum search.
Hi sherzaad,
I posted the code one to one in a new sketch and same error:
I use Wokwi and did not get any errors for the share example I did.... :face_with_raised_eyebrow:
did you try MY example code from post 12?
Maybe its related to the esp32 I use? but shouldnt make a diffrence?
I tried wokwi with your code:
ifi-scan.ino: In function 'void setup()':
wifi-scan.ino:5:11: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
5 | str_p = &Str.c_str()[0];
| const char*
Error during build: exit status 1
  for (int i = 0; i < sizeof z; i++)
    Serial.print((char)z[i]);
void loop() {}
Output:
age=Arkham
ah... so ur using an ESP32....
I tested with a UNO...
fixed it for esp32! :sunglasses:
  String hex_S = "6167653d41726b68616d";
  const char *hex_str;
  hex_str = &hex_S.c_str()[0];
  int i=0,j=0;
    char temp[3] ={0};
https://wokwi.com/projects/406480084365072385
