Hex2Dec Compiling error
Hello
I am new to Arduino and have been reading the Book: Getting Started with Arduino (Massimo Banzi / Michael Shiloh).
In chapter 7 there is an example of a Networked Lamp. The sketch includes hex2dec commands. The compiling returns the error: Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\moser\Documents\Arduino\NetworkedLamp\NetworkedLamp.ino: In function ‘void loop()’:
NetworkedLamp:48:28: error: ‘hex2dec’ was not declared in this scope
r = hex2dec(buffer[1]) + hex2dec(buffer[0]) * 16;
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
I have reread the sketch several times and compared it to the book but couldn’t find an error.
Here is the whole sketch:
// Networked Lamp
const int SENSOR = 0;
const int R_LED = 9;
const int G_LED = 10;
const int B_LED = 11;
const int BUTTON = 12;
int val = 0; // variable to store the value coming
// from the sensor
int btn = LOW;
int old_btn = LOW;
int state = 0;
char buffer[7] ;
int pointer = 0;
byte inByte = 0;
byte r = 0;
byte g = 0;
byte b = 0;
Serial.begin(9600); // open the serial port
pinMode(BUTTON, INPUT);
val = analogRead(SENSOR); // read the value from the sensor
Serial.println(val); // print the value to
// the serial port
if (Serial.available() > 0) {
// read the incoming byte:
inByte = Serial.read();
// If the marker’s found, next 6 characters are the colour
if (inByte == ‘#’) {
while (pointer < 6) { //accumulate 6 chars
buffer[pointer] = Serial.read(); // store in the buffer
pointer ++; // move the pointer forward by 1
// now we have the 3 numbers stored as hex numers
// we need to decode them into 3 bytes r, g and b
g = hex2dec(buffer[3]) + hex2dec(buffer[2]) * 16;
b = hex2dec(buffer[5]) + hex2dec(buffer[4]) * 16;
pointer = 0; // reset the pointer so we can reuse the buffer
btn = digitalRead(BUTTON); // read input value and store it
// Check if there was a transition
if ((btn == HIGH) && (old_btn == LOW)){
state = 1 - state;
old_btn = btn; // val is now old, let’s store it
if (state == 1) { // if the lamp is on
analogWrite(R_LED, r); // turn the leds on
analogWrite(G_LED, g); // at the colour
analogWrite(B_LED, b); // sent by the computer
analogWrite(R_LED, 0); // otherwise turn off
analogWrite (G_LED, 0);
analogWrite (B_LED, 0);
delay(100); // wait 100ms between each send
int hex2dex(byte c) { // converts one HEX character into a number
if (c >= ‘0’ && c <= ‘9’) {
return c - ‘0’;
} else if (c >= ‘A’ && c <= ‘F’) {
return c - ‘A’ + 10;
What could be wrong?
Thank you for the help!
moses
What would happen if you changed hex2dec() to hex2dex(), meaning they are spelled the same way?
Also, please read the first 4 posts at the top of this Forum to learn how to properly post code here using code tags.
Hi econjack
This did the trick.
I will have a look at the code posting thread
Thank you!
moses
