Hexadecimal Display Driver
Greetings.
I had free time, and I decided to code some fun project, then I decided to write this :
and turn my Arduino Uno R3 to a display server for Seven Segment.
P.S : I know using a 7447 is always a better idea, but it's only for fun :smiley:
"I know using a 7447 is always a better idea"
I'd disagree. First, it's obsolete. TPIC6C595 or TPIC6B595 is better, same as 74HC595 shift register but with open drain high current outputs. Just add a 10-bye font lookup array in software. And you can daisy chain a bunch of them.
byte fontArray[] = {
0b00111111, // 0 DP-g-f-e-d-c-b-a. 1 = segment on
0b00000110, // 1
//etc
a
f b
g
e c
d DP or colon if used
shiftOut (dataPin, clockPin, MSBFIRST, fontArray[numberToDisplay]);
or for faster updates
SPI.transfer (fontArray[numberToDisplay]);
Then you don't need a shift register in front of the 7447, and they run cooler too.
Here's a board I offer with 12 TPIC6B595 designed to drive up to 12 digits of 7-seven segment displays made with LED strips for the segments.
http://www.crossroadsfencing.com/BobuinoRev17/
A variation drives the digital Pace Clock sold here http://www.kiefer.com/
CrossRoads:
Thanks dude, I have both 7447 and 74595 IC's , and I will test both of them in action :smiley:
Now, I've updated the code, and it also can drive a common cathode display.
Now I have this code :
#define DS 7
#define ST_CP 8
#define SH_CP 9
byte digits[10] = {
  0x3f,
  0x06,
  0x5b,
  0x4f,
  0x66,
  0x6d,
  0x7d,
  0x07,
  0x7f,
  0x6f
int i;
  pinMode(DS, OUTPUT);
  pinMode(ST_CP, OUTPUT);
  pinMode(SH_CP, OUTPUT);
  for(i = 0; i < 10; i++){
    digitalWrite(ST_CP, LOW);
    shiftOut(DS, SH_CP, MSBFIRST, ~(digits[i]));
    digitalWrite(ST_CP, HIGH);
Which is much better than what I've written before.
P.S : I used 74595 shift register in this case.
