i have written a program for my hexapod whit some InverseKinemetics.
the InverseKinemetics formula's are already debugd.
Only i still doesn't get the right output.
i will post a little piece of the software, can some one tell me if they see a problem ?
O Will writing this i thought of one of the errors, RADIANS =( i was expecting degrees. (I feel a little stupid now)
Can some one still give some critics ?
a 2 minute refactor gave me 2 places where the code was doubtful, indicated with comments
I advice to give the functions a more meaningful name if possible to improve readabililty
Th ehypot function comes from - avr-libc: Modules = math.h (all can be used in Arduino)
#include "InverseKinemetics.h"
void RL3 (int i, Data *DataLine)
    int t = i*3;
long x = DataLine->ServosPosition[2+t];
if (x != 0) DataLine->l3 = hypot(DataLine->ServosPosition[0+t], x);
else DataLine->l3 = DataLine->ServosPosition[0+t];
float ZX (int i, Data *DataLine)
 int t = i*3;
 RL3(i, DataLine);
 long y = DataLine->ServosPosition[0+t];
 if ((x != 0) && (y != 0))                // <<<<<<<<<<
  return atan(float(x) / float(y));
  return 90; // Math Error Protection.
float TT (int i, Data *DataLine)
 int t = i*3;
 long x = DataLine->ServosPosition[0+t];
 long y = DataLine->ServosPosition[2+t];
 float x2 = x * x;
 float y2 = x * x;            //// you might meant index DataLine->ServosPosition[1+(i*3)] here ????
 float z2 = y * y;
 float s2 = DataLine->s * DataLine->s ;
 float l32 = DataLine->l3 * DataLine->l3;
Â
 DataLine->s = sqrt(x2 + y2 + z2);
 float t1 = 0;
 if (x != 0) t1 = acos((s2 + y2 - l32) / (2 * DataLine->s * x));
 else t1 = acos(0.0); // Math Error Protection.
 Â
 float a = (s2 + l1 * l1 - l2*l2);
 float b = (2 * DataLine->s * l1);
 float t2 = acos(a / b);
 return t1 + t2;
float LL (Data *DataLine)
 return acos(l1*l1 + l2*l2 - DataLine->s*DataLine->s) / (2 * l1 * l2));
void setleg (int i, Data *DataLine)
 int t = i*3;
 if (i >= 3)
  DataLine->ServosAngles[0+t] = ((float)180 - ZX(i, DataLine));
  DataLine->ServosAngles[1+t] = ((float)180 - TT(i, DataLine));
  DataLine->ServosAngles[2+t] = LL(DataLine);
  DataLine->ServosAngles[0+t] = ZX(i, DataLine);
  DataLine->ServosAngles[1+t] = TT(i, DataLine);
  DataLine->ServosAngles[2+t] = ((float)180 - LL(DataLine));
void InverseKinemetics::IK(Data *DataLine)Â
#ifdef DEBUG
 Serial.println("### InverseKinemetics->IK ###");
#endif
 for (int i=0; i<6; i++)
  setleg(i, DataLine);
#ifdef DEBUG
  if (i != 0)
   Serial.print(", ");
   Serial.print("### InverseKinemetics->ServosPosition's are: ");
  Serial.print(DataLine->ServosPosition[0+(i*3)]);
  Serial.print(", ");
  Serial.print(DataLine->ServosPosition[1+(i*3)]);
  Serial.print(", ");
  Serial.print(DataLine->ServosPosition[2+(i*3)]);
 Serial.println(";");
#endif
#ifdef DEBUG
  if (i != 0)
   Serial.print(", ");
   Serial.print("### InverseKinemetics->Angles are: ");
  Serial.print(DataLine->ServosAngles[0+(i*3)]);
  Serial.print(", ");
  Serial.print(DataLine->ServosAngles[1+(i*3)]);
  Serial.print(", ");
  Serial.print(DataLine->ServosAngles[2+(i*3)]);
#endif
Thank you, indeed i made a typing error
i am looking at the code now and it looks a lot better, i am still learning c++ for arduino.
There are some difference's whit VS 2010 C++ that made me confused. ( some weird behavior with the functions of the math library )
don't understand how the code works in detail but I see atan(x/y) on some places. SOmetimes one need atan2(x,y) instead. See the link I send earlier. (2 posts ago)
I have replaced the atan whit atan2, but the problem is whit the T1 Function i think.
T1 returns 0, and it must be 90 degrees at x 10 y 15.
The strange think is that the math part worked without an problem in my VisualStudio C++ Application.
I am getting a bit desperate. =(
A new simple piece of code, the greatest error's are out of it.
but one bug i still have is, if z isn't Zero then the left qaudrant isn't correct calculated.
