khalid_badawi:
hello guys, im working on a little bit big project.
it contains about 5 servo motors, 4 relays, 4 stepper motors(3 nema23,1 nema17)with their drivers, ldr sensor,12voltlamp, dh11 sensor,12volt fan, 12volt water pump, 12 volt selonoid, ultra sonic, load sensor with HX module, ESP32, arduino mega.
im using external ANTEC power supply which is capable of giving high currents like 10A for 12 volt and around 6 or 8 for 5 Volt
i was building it module by module,every module was working just fine, but unfortuanetely i was using bread board which i know is my bad, but i need some expert advice, so when i merged the project all together, alot of noise occured and some of the modules works in a bad ways, like servo motors shake, stepper motor nema17(a4988 driver) shaking left and right, there are obvious noise or current problems.( note that the stepper motor drivers was powered directly from power supply, but still alot of noise.
i have several questions:
1- do u 10000% confirm that the breadboard is biggest part of the problem?
2- is the arduino mega capable of providing all the control signals for the modules, current wise i mean, im not using it as power supply btw.
3- what can i use to prevent shaking servo motors, stepper motors noise??
i provided the whole description, connections im sure 100% right, but i need help with the problems mentioned above and will be hugely appreciated.
#define LIGHT 22 // define pin 22 for sensor
#define RELAY 23 // define pin 23 for relay
#define DHTPIN 24
#define DHTTYPE DHT11 // DHT 11
#define FAN_SPEED 2
#define LASER 25
#define X 3
#define Y 4
#define food3 7
#define food2 8
#define food1 9
#define pinCleanServo 6
#define dirPin 26
#define stepPin 27
#define enPin 28
#define dirPin2 29
#define stepPin2 30
#define enPin2 31
#define dirPin3 32
#define stepPin3 33
#define enPin3 34
#define dirPin4 38
#define stepPin4 39
#define waterRelay 37
#define vacuumRelay 43
#define limitSwitchPin1 44 // Change this to the appropriate digital pin
#define limitSwitchPin2 45 // Change this to the appropriate digital pin
#define limitSwitchPin3 46 // Change this to the appropriate digital pin
#define limitSwitchPin4 47 // Change this to the appropriate digital pin
#define limitSwitchPin5 A2 // Change this to the appropriate digital pin
#define limitSwitchPin6 A1 // Change this to the appropriate digital pin
#define echoPin 35
#define trigPin 36
#define selRelay 42
#define IRSensor A0
int flag1 = 0;
int flag2 = 0;
#include <DHT.h>
#include <DHT_U.h>
#include <Servo.h>
#include "SD.h"
#include "TMRpcm.h"
#include "SPI.h"
#include <HX711_ADC.h>
#include <EEPROM.h>
#if defined(ESP8266) || defined(ESP32) || defined(AVR)
#endif
//pins:
//HX711 constructor:
const int HX711_dout = 12; //mcu > HX711 dout pin
const int HX711_sck = 13; //mcu > HX711 sck pin
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
TMRpcm tmrpcm;
unsigned long previousMillis = 0; // Variable to store the last time the code was executed
const long interval = 1000; // Interval in milliseconds (1 second)
unsigned long previousMillis2 = 0; // Variable to store the last time the code was executed
const long interval2 = 10000; // Interval in milliseconds (1 second)
int value = -1;
int value2 = -1;
float w = 0;
float newWeight = 0;
float tempe = 0;
DHT dht(DHTPIN, DHTTYPE);
Servo servo_X;
Servo servo_Y;
Servo servo_Food3;
Servo servo_Food2;
Servo servo_Food1;
Servo cleanServo;
long duration;
int distance;
int angle_X = 0;
int angle_Y = 0;
int test = 5;
int limitSwitchState1;
int limitSwitchState2;
int type1, type2, type3;
bool play = true, led = true;
int stepperPos = 1;
int mode = 1; //0=auto 1=manual
bool light = false;
int lastFilled = 3;
bool laserPlayMode = false;
enum TaskState {
IDLE,
READ_TEMPERATURE,
CHECK_LDR,
MOVE_SERVO
TaskState currentTask = IDLE;
bool audioPlayed = false;
Serial1.begin(9600);
pinMode(LIGHT, INPUT_PULLUP);
pinMode(LASER, OUTPUT);
pinMode(RELAY, OUTPUT);
pinMode(vacuumRelay, OUTPUT);
pinMode(FAN_SPEED, OUTPUT);
pinMode(11, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(IRSensor, INPUT); // Sets the echoPin as an Input
pinMode(waterRelay, OUTPUT); // Sets the waterRelay as an Output
pinMode(selRelay, OUTPUT); // Sets the waterRelay as an Output
digitalWrite(FAN_SPEED, LOW);
digitalWrite(RELAY, HIGH);
digitalWrite(vacuumRelay, HIGH);
dht.begin();
servo_X.attach(Y);
servo_Y.attach(X);
servo_X.write(90);
servo_Y.write(90);
servo_Food3.attach(food3);
servo_Food3.write(0);
servo_Food2.attach(food2);
servo_Food2.write(180);
servo_Food1.attach(food1);
servo_Food1.write(180);
digitalWrite(LASER, HIGH); // turn the LASER ON
type1 = type2 = type3 = 0;
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
pinMode(enPin, OUTPUT);
pinMode(stepPin2, OUTPUT);
pinMode(dirPin2, OUTPUT);
pinMode(enPin2, OUTPUT);
pinMode(stepPin3, OUTPUT);
pinMode(dirPin3, OUTPUT);
pinMode(enPin3, OUTPUT);
pinMode(limitSwitchPin1, INPUT);
pinMode(limitSwitchPin2, INPUT);
pinMode(limitSwitchPin3, INPUT);
pinMode(limitSwitchPin4, INPUT);
pinMode(limitSwitchPin5, INPUT);
pinMode(limitSwitchPin6, INPUT);
pinMode(stepPin4, OUTPUT);
pinMode(dirPin4, OUTPUT);
cleanServo.attach(pinCleanServo);
cleanServo.write(120);
digitalWrite(enPin, LOW);
digitalWrite(enPin2, LOW);
digitalWrite(enPin3, LOW);
digitalWrite(waterRelay, HIGH);
digitalWrite(selRelay, LOW);
digitalWrite(limitSwitchPin1, HIGH);
digitalWrite(limitSwitchPin2, HIGH);
digitalWrite(limitSwitchPin3, HIGH);
digitalWrite(limitSwitchPin4, HIGH);
digitalWrite(limitSwitchPin5, HIGH);
digitalWrite(limitSwitchPin6, HIGH);
tmrpcm.speakerPin = 11;
if (!SD.begin(SD_ChipSelectPin)) {
//Serial.println("SD card initialization failed!");
// Stop the program if initialization fails
tmrpcm.setVolume(5);
//Serial.println("SD card initialized successfully");
//playMusic();
// testing food module start
// testing food module end
// weight food start
LoadCell.begin();
float calibrationValue; // calibration value (see example file "Calibration.ino")
calibrationValue = 98.02; // uncomment this if you want to set the calibration value in the sketch
//EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
//EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
unsigned long stabilizingtime = 2000;
boolean _tare = true;
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag()) {
//Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
while (1);
LoadCell.setCalFactor(calibrationValue);
//Serial.println("Startup is complete");
//type1 to type2 267 high
//type2 to type1 267 low
//type1 to type3 267 low
//type3 to type1 267 high
//type2 to type3 267 high
//type3 to type2 267 low
if (laserPlayMode) {
handleLaserPlay();
unsigned long currentMillis = millis(); // Get the current time
if (currentMillis - previousMillis2 >= interval2) {
previousMillis2 = currentMillis;
w = wight();
//Serial.println("Final weight=" + String(w));
delay(100);
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis; // Save the current time for the next iteration
if (w <= 50) {
Serial1.println("w=Almost Empty");
} else if (w > 50 && w <= 200) {
Serial1.println("w=Enough Food");
} else if (w > 200) {
Serial1.println("w=Almost Full");
tempe = readTemperature();
Serial1.println("t=" + String(tempe));
int lvl = waterLevel();
Serial.println("lvl=" + String(lvl));
light = ldr();
delay(50);
if (!light) {
Serial1.println("l=Bright");
delay(50);
Serial1.println("l=Dark");
delay(50);
if (mode == 0) {
autoMode();
if (Serial1.available() > 0) {
// Receive the character from Serial1
String receivedString = Serial1.readStringUntil('\n');
//Serial.println(receivedString);
if (receivedString[0] == 'o')
laserPlayMode = 1;
else if (receivedString[0] == 'l') //auto
mode = 0;
else if (receivedString[0] == 'k') //manual
mode = 1;
analogWrite(FAN_SPEED, 0);
delay(50);
else if (receivedString[0] == 'c') {
char charBuf[receivedString.length() + 1];
receivedString.toCharArray(charBuf, sizeof(charBuf));
char* xString = strtok(charBuf, "=");
char* yString = strtok(NULL, "=");
if (xString && yString) {
// Convert the strings to integers
int fanSpeed = atoi(yString);
analogWrite(FAN_SPEED, fanSpeed);
if (mode == 1) {
mobileControl(receivedString[0]);
void mobileControl(char receivedChar) {
switch (receivedChar) {
case 'a':
digitalWrite(RELAY, LOW);
delay(50);
case 'b':
delay(50);
case 'z':
fillCan();
case 'e':
type1 = 1;
case 'f':
type1 = 0;
case 'g':
type2 = 1;
case 'h':
type2 = 0;
case 'i':
type3 = 1;
case 'j':
type3 = 0;
case 'm':
playMusic();
case 'n':
tmrpcm.disable();
delay(100);
case 'r':
clean();
case 'q':
fillWater();
default:
void handleLaserPlay() {
if (receivedString[0] == 'p') {
laserPlayMode = 0;
return;
// Separate the received string into two strings for X and Y
char* xString = strtok(charBuf, "-");
char* yString = strtok(NULL, "-");
int joystickX = atoi(xString);
int joystickY = atoi(yString);
joystickX = map(joystickX, 0, 1023, 180, 0);
servo_X.write(joystickX);
// Reverse mapping for Y axis
joystickY = map(joystickY, 0, 1023, 0, 180);
servo_Y.write(joystickY);
delay(4);
// Print the joystick and servo values for debugging (optional)
//Serial.print("Joystick X: ");
// Serial.print(joystickX);
//Serial.print(", Y: ");
//Serial.println(joystickY);
void autoMode() {
///ldr
if (light) {
delay(50);
delay(50);
//////fan
///Serial.println(String(tempe));
if (tempe < 25 && value != 0) {
value = 0;
} else if (tempe >= 25 && tempe < 30 && value != 500) {
analogWrite(FAN_SPEED, 500); // half speed
//Serial.println("Case1");
value = 500;
} else if (tempe >= 30 && value != 1000) {
analogWrite(FAN_SPEED, 1000); // max speed
//Serial.println("Case2");
value = 1000;
////////Food
w = wight();
if (w < 50) {
if (lastFilled == 3) {
type1 = 1;
type2 = 0;
type3 = 0;
lastFilled = 1;
} else if (lastFilled == 1) {
type1 = 0;
type2 = 1;
type3 = 0;
lastFilled = 2;
} else if (lastFilled == 2) {
type1 = 0;
type2 = 0;
type3 = 1;
lastFilled = 3;
fillCan();
void fillCan() {
if (type1 == 1 && type2 == 0 && type3 == 0) {
float w2 = w;
float old = w2;
while (w2 < 220) {
servo_Food1.write(100);
delay(50);
w2 = wight();
//Serial.print("w2=" + String(w2));
if (abs(old - w2) < 5) {
old = w2;
delay(50);
} else if (type1 == 0 && type2 == 1 && type3 == 0) {
digitalWrite(dirPin, HIGH); //Changes the rotations direction
moveStepper();
float w2 = w;
float old = w2;
while (w2 < 220) {
servo_Food2.write(100);
delay(50);
w2 = wight();
old = w2;
delay(50);
digitalWrite(dirPin, LOW); //Changes the rotations direction
delay(50);
moveStepper();
} else if (type1 == 0 && type2 == 0 && type3 == 1) {
delay(50);
moveStepper();
float w2 = w;
float old = w2;
while (w2 < 220) {
servo_Food3.write(80);
delay(50);
w2 = wight();
//Serial.println(String(w2));
old = w2;
delay(50);
delay(50);
moveStepper();
} else if (type1 == 1 && type2 == 1 && type3 == 0) {
float w2 = 220 - w;
float wt1 = (w2 / 2.0) + w;
w2 = wight();
float old = w2;
while (w2 < wt1) {
delay(50);
w2 = wight();
old = w2;
delay(50);
delay(50);
moveStepper();
w2 = w;
old = w2;
while (w2 < 220) {
delay(50);
w2 = wight();
old = w2;
delay(50);
delay(50);
moveStepper();
else if (type1 == 1 && type2 == 0 && type3 == 1) {
float w2 = 220 - w;
w2 = wight();
float old = w2;
while (w2 < wt1) {
delay(50);
w2 = wight();
old = w2;
delay(50);
moveStepper();
w2 = w;
old = w2;
while (w2 < 220) {
delay(50);
w2 = wight();
old = w2;
delay(50);
delay(50);
moveStepper();
} else if (type1 == 0 && type2 == 1 && type3 == 1) {
delay(50);
moveStepper();
float w2 = 220 - w;
w2 = wight();
float old = w2;
while (w2 < wt1) {
delay(50);
w2 = wight();
old = w2;
delay(50);
moveStepper();
w2 = w;
old = w2;
while (w2 < 220) {
delay(50);
w2 = wight();
old = w2;
delay(50);
moveStepper();
moveStepper();
// else if( type1==1 && type2==1 && type3==1)
// if(stepperPos==1)
// servo_Food1.write(100);
// delay(1000);
// servo_Food1.write(180);
// digitalWrite(dirPin,HIGH); //Changes the rotations direction
// moveStepper();
// servo_Food2.write(100);
// delay(1000);
// servo_Food2.write(180);
// moveStepper();
// servo_Food3.write(100);
// delay(1000);
// servo_Food3.write(180);
// stepperPos=3;
// else if(stepperPos==2)
// delay(1000);
// moveStepper();
// delay(1000);
// moveStepper();
// delay(1000);
// stepperPos=1;
// else if(stepperPos==3)
// delay(1000);
// digitalWrite(dirPin,LOW); //Changes the rotations direction
// moveStepper();
// delay(1000);
// moveStepper();
// delay(1000);
// stepperPos=1;
float wight() {
float temp;
static boolean newDataReady = false;
for (int i = 0; i < 150; i++) {
delay(25);
// check for new data/start next conversion:
if (LoadCell.update()) {
newDataReady = true;
// get smoothed value from the dataset:
if (newDataReady) {
temp = LoadCell.getData();
// receive command from serial terminal, send 't' to initiate tare operation:
// check if last tare operation is complete:
return temp;
bool ldr() {
int L = digitalRead(LIGHT); // read the light sensor
delay(10);
if (L == HIGH && value2 != 1) {
value2 = 1;
return true;
} else if (L == LOW && value2 != 0) {
value2 = 0;
return false;
//delay(3000);
float readTemperature() {
float t = dht.readTemperature();
//Serial.print("Temperature: ");
//Serial.print(t);
//Serial.println(" °C");
return t;
// if (t < 25&&value!=0)
// analogWrite(FAN_SPEED, 0);
// delay(100);
// value=0;
// else if (t >= 25 && t < 30&&value!=500)
// analogWrite(FAN_SPEED, 500); // half speed
// delay(100);
// value=500;
// else if (t >= 30 && value!=1000)
// analogWrite(FAN_SPEED, 1000); // max speed
// delay(100);
// value=1000;
void laser(int i, int j) {
int loop = i;
if (j > i)
loop = j;
/* for(angle_X=0;angle_X<=i;angle_X++)
servo_X.write(angle_X);
servo_Y.write(angle_X);
//servo_X.write(angle_Y);
delay(10);
for(angle_X=i;angle_X>=0;angle_X--)
delay(10);
angle_X=0;*/
/*for(angle_Y=0;angle_Y<=j;angle_Y++)
servo_Y.write(angle_Y);
delay(10);
for(angle_Y=j;angle_Y>=0;angle_Y--)
delay(10);
angle_Y=0;*/
for (int k = 0; k <= loop; k++) {
if (k <= i) {
angle_X++;
if (k <= j) {
angle_Y++;
delay(5);
for (int k = loop; k >= 0; k--) {
if (k <= i) {
angle_X--;
if (k <= j) {
angle_Y--;
delay(5);
angle_X = 0;
angle_Y = 0;
void playMusic() {
tmrpcm.play("gg.wav");
delay(100);
void clean() {
limitSwitchState1 = digitalRead(limitSwitchPin1);
limitSwitchState2 = digitalRead(limitSwitchPin4);
digitalWrite(dirPin3, HIGH); //Changes the rotations direction
delay(10);
digitalWrite(dirPin2, HIGH);
delay(10);
int sensorStatus;
while (true) {
if (limitSwitchState1 == HIGH) {
digitalWrite(stepPin2, HIGH);
delayMicroseconds(100);
digitalWrite(stepPin2, LOW);
delayMicroseconds(10);
if (limitSwitchState2 == HIGH) {
if(flag1==0){
sensorStatus = digitalRead(IRSensor); // Set the GPIO as Input
if(sensorStatus==0&&flag1==0){
cleanServo.write(32);
flag1=1;
digitalWrite(stepPin3, HIGH);
digitalWrite(stepPin3, LOW);
if (limitSwitchState1 == LOW && limitSwitchState2 == LOW) {
//Shift1 Done
limitSwitchState1 = digitalRead(limitSwitchPin2);
limitSwitchState2 = digitalRead(limitSwitchPin3);
digitalWrite(dirPin3, LOW); //Changes the rotations direction
digitalWrite(dirPin2, LOW);
while (true) {
//Vacuum
digitalWrite(vacuumRelay, LOW);
limitSwitchState1 = digitalRead(limitSwitchPin5);
digitalWrite(dirPin4, LOW); //Changes the rotations direction
while (limitSwitchState1 == HIGH) {
digitalWrite(stepPin4, HIGH);
delayMicroseconds(4000);
digitalWrite(stepPin4, LOW);
limitSwitchState1 = digitalRead(limitSwitchPin6);
digitalWrite(dirPin4, HIGH);
flag1 = 0;
// void loop()
// if (millis() - ldrTimer >= ldrInterval) {
// ldr();
// ldrTimer = millis();
// // ldr();
// // led=false;
// if (millis() - temperatureTimer >= temperatureInterval) {
// readTemperature();
// temperatureTimer = millis();
// //readTempruture();
// // Tempruture System end
// /*if(play)
// playMusic();
// play=false;
// //delay(500);
// /*for(angle_X=0;angle_X<=180;angle_X++)
// servo_X.write(angle_X);
// //servo_X.write(angle_Y);
// delay(10);
// delay(1000);
// for(angle_X=180;angle_X>=0;angle_X--)
// delay(10);
// angle_X=0;
// delay(500);*/
void moveStepper() {
for (int x = 0; x < 267; x++) {
digitalWrite(stepPin, HIGH);
delayMicroseconds(2000);
digitalWrite(stepPin, LOW);
delay(100);
int waterLevel() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration * 0.034 / 2;
return distance;
void fillWater() {
int level = waterLevel();
//Serial.println("level=" + String(level));
if(level>=4){
digitalWrite(waterRelay, LOW);
digitalWrite(selRelay, HIGH);
delay(7000);
type or paste code here
