the project: make an LCD Counter using push button, 2 buttons.. one for counting (increment +1), and the other one for resetting.
i have made it already, but for a bonus task, showing Arabic letters instead of English letters.
For Example:
In English:
Counter: 1
In Arabic:
عداد: 1
I tried using the U8b library, but my teacher says i can do it with a code instead of searching for a certain library..
How can i do that, if it's possible.
He is right but it's a bit like working out your sine tables rather than pushing a button on the calculator.
If you open the library with notepad ++, you'll probably see a lookup table of characters in hex, which are actually bitmaps in binary. I think it will be damn hard in an eastern language - as much an art as a science.
My advice - if that is a task you have been set for bonus points, forget it. You have beter things to spend your time on.
Too much effort for too little return
Maybe true, but if you don't say what LCD display you're using is not an easy task...
Example, if you have a regular 16x2 characters LCD you could program some custom letters (up to 8) to draw arabic ones. If you have a graphical LCD the things are a bit more complex, so if your teacher said you can do that without a library, I suppose you're using a 16x2 LCD: in this case just search for "arduino custom characters LCD 16x2" and you'll find tons of examples.
Based on the example given, he doesn't want to translate the numbers, but just the word "Counter". If he needs to translate the numbers, he simpy can't do it due to the 8 custom char limit (he needs 10).
My iPad wouldn't open your link. It gave me warnings.
I was just trying to help by offering alternative information. My apologies if my action offended you. I'll be more careful if I ever attempt to help again.
Kidding? I'm absolutely not offended, but, if you think so, I suppose your iPad can't show emoticons also, so I apologise if my smiling face at the end of my sentence has not been shown... Like this: C'm on, take it easy, pal!
