HF RFID WITH GPRS MODULE AT COMMANDS USING ARDUINO
HI
I’m working on gprs module with hf rfid using arduino uno.i m getting trouble in gprs AT command,where i have established my tcp connection using arduino code,but i got error in at+cipsend
my arduino code are here
plz help anyone…plz
thanks in advance
#include <SoftwareSerial.h>
#include <String.h>
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
SoftwareSerial mySerial(7, 8 );
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
String result;
mySerial.begin(9600); // the GPRS baud rate
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
// Serial.println(“Approximate your card to the reader…”);
// Serial.println();
// Serial.println(F(“Ready!”));
// Serial.println(F("======================================================"));
// Serial.println(F(“Scan for Card and print UID:”));
if (mySerial.available())
Serial.write(mySerial.read());
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(“Tagid:”));
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
// Helper routine to dump a byte array as hex values to Serial
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
result += String(buffer*, HEX);*
_ Serial.print(String(buffer < 0x10 ? " 0" : " "));_
_ Serial.print(String(buffer*, HEX));
Send2xampp();
Serial.println();_
mfrc522.PICC_HaltA(); // Stop reading*
///send2xampp()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2xampp()
* String data;*
* mySerial.println(“AT+CGATT=1”); //Attach or Detach from GPRS Service (Result 1 = Attach , 2 = Detached )*
* delay(300);*
* ShowSerialData();*
* mySerial.println(“AT+CIPSHUT”); //Close TCP Connection*
* delay(300);*
* mySerial.println(“AT+CIPSPRT=0”);*
* delay(3000);*
* mySerial.println("AT+CIPSTART=“TCP”,“49.207.183.202”,“4000"”);//start up the connection*
* delay(2000);*
* mySerial.println("\n");//here is the feed you apply from pachube*
* delay(500);*
* mySerial.println(“AT+CIPSEND”);//begin send data to remote server*
* delay(4500);*
* mySerial.print(“tag_id= " + String(result) +”""); //DATA feed name*
* delay(10);*
* mySerial.print(“POST /rfid1/rest/insertrfiddata”);//here is the feed you apply from pachube*
* delay(500);*
* delay(500);*
* mySerial.print(" HTTP/1.1\r\n");*
* delay(500);*
* mySerial.println(“Content-Type: application/json”);*
* delay(100);*
* mySerial.print(“Host: 49.207.183.202\r\n”);*
* delay(500);*
* //mySerial.print(“Connection: keep-alive”); //working*
* mySerial.print(“Connection: close”); //working as well*
* mySerial.print("\r\n");*
* //mySerial.println();*
* delay(500);*
// mySerial.println((char)26);//sending
* delay(500);//waitting for reply, important! the time is base on the condition of internet*
* mySerial.println();*
* mySerial.println(“AT+CIPCLOSE”);//close the connection*
* delay(100);*
* mySerial.println(“AT+CIPSHUT=0”);*
* delay(100);*
void ShowSerialData()
* while(mySerial.available()!=0)*
* Serial.write(mySerial.read());*
gprs_testing.ino (3.56 KB)
I was trying the new GPRS module(sim900a) and its works but i having an error when i want to post it in xampp server.
Thanks in advance…plz help anyone…i am trying these so many days…but i got…
My arduino is here.
#include <String.h>
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
SoftwareSerial mySerial(7, 8); //your pins to serial communication
String result;
int valor;
//String token = “96307f50”; //your token to post a value
//String result = “96307f50”; //ID of your variable
mySerial.begin(9600); //the GPRS baud rate
delay(500);//the serial communication baud rate
Serial.println(“Starting”);
delay(2000);
return;
return;
Serial.print(F(“tag_id:”));
Serial.println();_
* Serial.println(“Sending to xampp Value=”+ result);*
* save_value(String(result)); //call the save_value function*
* if (mySerial.available())*
//this function is to send the sensor data to Ubidots, you can see the new value in Ubidots after running this function
void save_value(String result)
* int num;*
* String le;*
* String data;*
* data=“tag_id = “+ result;
// data=”{“tag_id”:”+ result + “}”;
_ num=data.length();
le=String(num);
mySerial.println(“AT+CGATT?”); //this is better made repeatedly because it is unstable*
* delay(2000);
ShowSerialData();
// mySerial.println(“AT+CSTT=“www”,”","""); //start task and set the APN*
// delay(1000);
// ShowSerialData();
// mySerial.println(“AT+CIICR”); //bring up wireless connection
// delay(3000);
// mySerial.println(“AT+CIFSR”); //get local IP adress
// delay(2000);
delay(3000);
ShowSerialData();
mySerial.println("AT+CIPSTART=“tcp”,“49.207.183.202”,“4000"”); //start up connection*
* delay(3000);
ShowSerialData();
mySerial.println(“AT+CIPSEND”); //begin sendiing data to the remote server*
* delay(5000);
ShowSerialData();_
mySerial.print(“POST /gprs_rfid/rest/insertrfiddata HTTP/1.1\n”);
_ delay(100);
ShowSerialData();_
mySerial.println("tag_id = " + String(result));
_ delay(100);
ShowSerialData();
delay(100);
ShowSerialData();
mySerial.println("Content-Length: "+le);
delay(100);
ShowSerialData();_
mySerial.print("X-Auth-tag_id: ");
_ delay(100);
ShowSerialData();
mySerial.println(result);
delay(100);
ShowSerialData();
mySerial.println(“Host: 49.207.183.202”);
delay(100);
ShowSerialData();
mySerial.println();
delay(100);
ShowSerialData();
mySerial.println(data);
delay(100);
ShowSerialData();
mySerial.println();
delay(100);
ShowSerialData();
delay(7000);
mySerial.println();
ShowSerialData();
mySerial.println(“AT+CIPCLOSE”); //close communication*
* delay(1000);
ShowSerialData();
}_
gprs_sim900a.ino (4.02 KB)*
Didn’t you think we’d like to know what the error is?
Please remember to use code tags when posting code.
:slightly_frowning_face: Sorry sir/madam,i apologize...
 Starting
tag_id:362a8050
Sending to xampp value=362a8050
AT+CGATT?
+CGATT: 1
OK
AT+CIPSPRT=0
OK
AT+CIPSTART="tcp","49.207.183.202","4000"
ERROR
AT+CIPSEND
ERROR
tag_id = 362a8050
Content-Length: 17
X-Auth-tag_id: 362a8050
tag_id = 362a8050
ERROR
AT+CIPCLOSE
ERROR
Starting
tag_id:362a8050
AT+CGATT?
+CGATT: 1
OK
AT+CIPSPRT=0
OK
ERROR
AT+CIPSEND
ERROR
tag_id = 362a8050
Content-Length: 17
tag_id = 362a8050
ERROR
AT+CIPCLOSE
ERROR
plz plz plz reply...i need your help...plz do the needful
