Hi all can any one help a newbie-Success!!!!
Hi all im new to arduino with zero programing experience but i have purchased books etc yet struggling to piece things together.
i currently have a uno r3 with ide 1.0.4 and i am trying to put together a spectrum analyser/visualizer by using a 8x8 led matrix hooked up to max7219 and the adafruit electret microphone module as the audio in.
Im really struggling to figure out how to write the code to display the output from the fft to the matrix below is what i have so far
#include <fix_fft.h>
#include "LedControl.h"
int audioPin = A0;
 Now we need a LedControl to work with.
 ***** These pin numbers will probably not work with your hardware *****
 pin 12 is connected to the DataIn
 pin 11 is connected to the CLK
 pin 10 is connected to LOAD
 We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1);
/* we always wait a bit between updates of the display */
unsigned long delaytime=100;
const int maxExpectedAudio = 20;  // Change this value to adjust the sensitivity
char data[128], im[128], data_avgs[8];  // FFT array variables
int i, j, x, y;
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,8);
  /* and clear the display */
  lc.clearDisplay(0);
  for (int i = 0; i < 8; i++);
  // Build table of audio samples
  for (i = 0; i < 128; i++) {
    data[i] = analogRead(audioPin);
    im[i] = 0;
  for (i = 0; i < 64; i++)
    data[i] = sqrt(data[i] * data[i] + im[i] * im[i]); // Make values positive
  for (i = 0; i < 8; i++) {
    // Average values
    j = i << 3;
    data_avgs[i] = data[j] + data[j + 1] + data[j + 2] + data[j + 3]
      + data[j + 4] + data[j + 5] + data[j + 6] + data[j + 7];
    if (i == 0);
    data_avgs[i] >>= 1;  // KK: De-emphasize first audio band (too sensitive)
    data_avgs[i] = map(data_avgs[i], 0, maxExpectedAudio, 0, 7); // Map for output to 8x8 display
writeArduinoMatrix();
for (y = 0; y < 8; y++);
  for (x = 0; x < data_avgs[y]; x++)
    delayMicroseconds(500);
this is what im trying to achieve: this is by lady ada using i2c rgb led matrix i wouldnt have a clue where to begin to adapt the sketch to work with my setup Piccolo Music Visualizer - YouTube <<<<<ladyada piccolo
thanks in advance guys and girls i do hope someone can help
That code won't even format (Command-T):
"Auto Format Canceled: Too many right curly braces."
Looks incomplete.
Hi johnwasser thanks for replying, but as i stated in my original post, the code i put up is what i have come up with so far and is incomplete and this is where i am struggling. I am struggling with writing the end piece of code to write to the led matrix i was really hoping someone on the forum may have been able to help me fit the missing piece
You have a library called LedControl that you are using to manipulate the MAX7219. You don't say where you found that library or point to any documentation so it is hard to know how to use it.
A Google search turned up Arduino Playground - LedControl
That says you can set individual LEDs with:
void setLed(int addr, int row, int col, boolean state);
Assuming your data_avgs[] values are in the range 0 to 8:
    for (y = 0; y < 8; y++) {
        for (x = 0; x < 8; x++) {
            setLed(0, x, y, x < data_avgs[y]);
thankyou johnwasser for taking the time to helpi really appreciate it. i took up the arduino after ready it was really easy, apart from flashing leds im finding it really hard to hang in there with it. Ive gone back over my sketch and cleaned it up a bit it will auto format fine but i now get a compile error with the code you suggested saying x and y not declared in this scope :frowning: heres where i am with it and once again thank you
FFT for 8x8 with adafruit electretmicrophone module
 code adapted from Andy Doro FFT for LoL shield code (http://andydoro.com)
 adafruit recomends using 3.3v rail for mic
 based on FFT library and code from the Arduino forum
 BIG thanks to johnwasser on the arduino forum for his assistance
#include <LedControl.h> //library fot the 8x8 matrix
#include <fix_fft.h>    //library for fft
#define AUDIOPIN 5      //define mic to A5
 pin 11 is connected to the DataIn
 pin 13 is connected to the CLK
LedControl lc=LedControl(11,13,10,1); //DIN, CLK, LD pins and number of displays 1
char im[128], data[128];
char data_avgs[14];
int i=0,val;
  lc.setIntensity(0,8); //set the brightness 0 darkest 15 brightest
  lc.clearDisplay(0); //clear the display ready to begin
  for (i=0; i < 128; i++){
    val = analogRead(AUDIOPIN);
    data[i] = val;
    im[i] = 0;
  fix_fft(data,im,7,0);
  for (i=0; i< 64;i++){
    data[i] = sqrt(data[i] * data[i] + im[i] * im[i]); // this gets the absolute value of the
    //values in the array, so we're only dealing with positive numbers
  // average bars together
  for (i=0; i<14; i++) {
    data_avgs[i] = data[i*4] + data[i*4 + 1] + data[i*4 + 2] + data[i*4 + 3]; // average together
    data_avgs[i] = map(data_avgs[i], 0, 8, 0, 8); // remap values 8x8
  // set 8x8
      if (y < data_avgs[8-x]) { // 18-x reverses the bars so low to high frequences are represented from left to right.
        lc.setLed(0, x, y, x < data_avgs[y]);
Hi all ive got this to compile but the matrix flashes for a split secound then nothing does anyone have any ideas where im going wrong
char data_avgs[14];
int i=0,val;
    data[i] = val;
    im[i] = 0;
  // set 8x8
    for (int col = 0; col < 8; col++) {
    for (int row = 0; row < 8; row++) {
      if (row < data_avgs[8-row]) { // 18-x reverses the bars so low to high frequences are represented from left to right.
        lc.setLed(0, row, col, row < data_avgs[i]);
Have you looked at the project notes of the video you posted?
parts, code, ect all there.
hi john i have looked but the display used for the piccolo uses the i2c interface where as the max7219 is spi, so to my understanding the two are completly different and the code cant be 'just modified' and if it could its well beyond me
For those who tried to help me with this i thank you very much here is the working code if anyone wishes to make use of it :slight_smile:
FFT for 8x8 max7219 with adafruit electretmicrophone module
unsigned long delaytime=50;
int audioPin = A0;
char im[128], data[128], data_avgs[8]; //FFt variables
int i, j, col, row;
int maxExpectedAudio = 5;
void setup(){
    im[i] = 0;
  fix_fft(data, im, 7, 0);  // FFT processing
    // Average values
    j = i << 3;
    if (i == 0);
    for(int e = 0; e < 8; e++)
      for(int i = 0; i < 9; i++)
        if(i <= data_avgs[e] && data_avgs[e] < 8)
          lc.setLed(0, 7-e, i-1, true);
          lc.setLed(0, 7-e, i-1, false);
