im trying to drive this 5v 2a stepper motor using tip 122 transistor ....after the connection the motor drive but the torque is not high enough as i can easily stop it using my hand....the resistor im using is 0.4ohm should i use 1Kohm as in this diagram so the motor will operate at high torque?
If it is a 6-wire stepper just ignore the two centre wires (keep them separate from each other and everything else) and treat the motor as a 4-wire bipolar stepper. Then just get a proper stepper motor driver board and save yourself a lot of trouble. I would get a 3amp driver board to give a bit of headroom.
The main shortcoming with your design is that you can't use high voltages because you have no current limiting circuitry to prevent overloading the motor.
zamir89:
The diodes are in the wrong place, they go anode to collector, cathode to +ve motor
supply. You have possibly blown something.
You'll need ~6.5V supply to get to about 5V to the motor, since darlingtons drop lots
of voltage at high current. And enough amps in the power supply.
Did you measure the resistor Mike asked you about ? Is it really 0.4 ohms ?
You never posted your code. You never posted a photo of your circuit. You never posted any measurements for the TIP122s.
I really don't see how you can draw any conclusions on your own, considering the circuit was miswired to begin with, the resistor value you claim to be using doesn't match the schematic you posted, and we still haven't seen your code.
Absolutely, subject lines are there to identify the subject of the posting so those with
the right expertise can find relevant threads to contribute to. We can all work out
someone posting here is wanting help with an Arduino project!
im so sorry robbin before this u has helped me in many of my post im really appericiate ur efforts and all of u guys thnks so much im just a noob and newbie nothing more .....please accept my apologies....
