#include <SPI.h>
#include <MFRC522.h>
//NodeMCU--------------------------
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define SS_PIN D2 //D2
#define RST_PIN D1 //D1
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
/* Set these to your desired credentials. */
const char *ssid = "wifi";
const char *password = "123456789";
const char* device_token = "c93080ec3f675356";
String URL = "http://192.168.101.8/rfidattendance/getdata.php"; //computer IP or the server domain
String getData, Link;
String OldCardID = "";
unsigned long previousMillis = 0;
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
connectToWiFi();
//check if there's a connection to Wi-Fi or not
if(!WiFi.isConnected()){
connectToWiFi(); //Retry to connect to Wi-Fi
if (millis() - previousMillis >= 15000) {
previousMillis = millis();
OldCardID="";
delay(50);
//look for new card
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;//got to start of loop if there is no card present
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;//if read card serial(0) returns 1, the uid struct contians the ID of the read card.
String CardID ="";
for (byte i = 0; i < mfrc522.uid.size; i++) {
CardID += mfrc522.uid.uidByte[i];
if( CardID == OldCardID ){
return;
else{
OldCardID = CardID;
// Serial.println(CardID);
SendCardID(CardID);
//************send the Card UID to the website*************
void SendCardID( String Card_uid ){
Serial.println("Sending the Card ID");
if(WiFi.isConnected()){
HTTPClient http; //Declare object of class HTTPClient
//GET Data
getData = "?card_uid=" + String(Card_uid) + "&device_token=" + String(device_token); // Add the Card ID to the GET array in order to send it
//GET methode
Link = URL + getData;
http.begin(Link); //initiate HTTP request //Specify content-type header
int httpCode = http.GET(); //Send the request
String payload = http.getString(); //Get the response payload
// Serial.println(Link); //Print HTTP return code
Serial.println(httpCode); //Print HTTP return code
Serial.println(Card_uid); //Print Card ID
Serial.println(payload); //Print request response payload
if (httpCode == 200) {
if (payload.substring(0, 5) == "login") {
String user_name = payload.substring(5);
// Serial.println(user_name);
else if (payload.substring(0, 6) == "logout") {
String user_name = payload.substring(6);
else if (payload == "succesful") {
else if (payload == "available") {
delay(100);
http.end(); //Close connection
//********************connect to the WiFi******************
void connectToWiFi(){
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
WiFi.mode(WIFI_STA);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connected With Wi-Fi");
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
I'm trying to add another const char*
Welcome and thanks for using code tags in your first post
Please post the complete error message (again using code tags).
It does not sound like you have a problem with the IDE but a programming problem; hence your topic has been moved.
I don't have error in the code but I want to declare another const char* device_token = " " with the same variables.
The simplest way would be something like
const char* device_token2 = "12345";
This however is not scalable and it would be better to use arrays; something like
const char* device_token[] =
"c93080ec3f675356",
"12345",
I suggest that you read up on arrays if you're not familiar with them.
hello sir sterretje. I'm getting an error like this
C\Users\ASUS\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\cores\esp8266/WString.h:57:9: note: String::String(const String&)
String(const String &str);
C:\Users\ASUS\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\cores\esp8266/WString.h:57:9: note: no known conversion for argument 1 from 'const char* [2]' to 'const String&'
exit status 1
Compilation error: call of overloaded 'String(const char* [2])' is ambiguous
Please post your updated code (in a new reply).
#include <SPI.h>
const char* device_token2 = "424b8af2d53545cd"
connectToWiFi();
OldCardID="";
delay(50);
//look for new card
String CardID ="";
return;
else{
OldCardID = CardID;
SendCardID(CardID);
//GET Data
getData = "?card_uid=" + String(Card_uid) + "&device_token=" + String(device_token), "&id=" + String(id);** // Add the Card ID to the GET array in order to send it
//GET methode
delay(100);
Serial.println("");
here is the updated
Missing something here in the second line:
a7
