Hi can some one help make homing to work?
#include <AccelStepper.h> // AccelStepper Library
#include <Keypad.h>  // Keypad Library
#include "U8glib.h"  // U8glib for Nokia LCD
// Variables to hold entered number on Keypad
volatile int firstnumber=99;  // used to tell how many numbers were entered on keypad
volatile int secondnumber=99;
volatile int thirdnumber=99;
volatile int fourthnumber=99;
// Variables to hold Distance and CurrentPosition
int keyfullnumber=0;  // used to store the final calculated distance value
String currentposition = "";  // Used for display on Nokia LCD
// Keypad Setup
const byte ROWS = 4; // Four Rows
const byte COLS = 4; // Four Columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {22, 24, 26, 28}; // Arduino pins connected to the row pins of the keypad
byte colPins[COLS] = {31, 33, 35, 37}; // Arduino pins connected to the column pins of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );  // Keypad Library definition
// U8glib Setup for Nokia LCD
#define backlight_pin 11
U8GLIB_PCD8544 u8g(3, 4, 6, 5, 7);  // Arduino pins connected to Nokia pins:
                                    // CLK=3, DIN=4, CE=6, DC=5, RST=7
// AccelStepper Setup
AccelStepper stepperX(1, 2, 3);   // 1 = Easy Driver interface
                                  // Arduino A0 connected to STEP pin of Easy Driver
                                  // Arduino A1 connected to DIR pin of Easy Driver
// Define the Pins used
#define home_switch 9 // Pin 9 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
long TravelX;  // Used to store the X value entered in the Serial Monitor
int move_finished=1;  // Used to check if move is completed
long initial_homing=-1;  // Used to Home Stepper at startup
   Serial.begin(9600);  // Start the Serial monitor with speed of 9600 Bauds
   pinMode(home_switch, INPUT_PULLUP);
   delay(5);  // Wait for EasyDriver wake up
   //  Set Max Speed and Acceleration of each Steppers at startup for homing
  stepperX.setMaxSpeed(100.0);      // Set Max Speed of Stepper (Slower to get better accuracy)
  stepperX.setAcceleration(100.0);  // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
  Serial.print("Stepper is Homing . . . . . . . . . . . ");
  while (digitalRead(home_switch)) {  // Make the Stepper move CCW until the switch is activated
    stepperX.moveTo(initial_homing);  // Set the position to move to
    initial_homing--;  // Decrease by 1 for next move if needed
    stepperX.run();  // Start moving the stepper
    delay(5);
  stepperX.setCurrentPosition(0);  // Set the current position as zero for now
  initial_homing=1;
  while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
    stepperX.run();
    initial_homing++;
    delay(5);
  Serial.println("Homing Completed");
  Serial.println("");
  stepperX.setMaxSpeed(1000.0);      // Set Max Speed of Stepper (Faster for regular movements)
  stepperX.setAcceleration(1000.0);  // Set Acceleration of Stepper
// Print out Instructions on the Serial Monitor at Start
  Serial.println("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): ");
 while (Serial.available()>0)  { // Check if values are available in the Serial Buffer
  move_finished=0;  // Set variable for checking move of the Stepper
  TravelX= Serial.parseInt();  // Put numeric value from buffer in TravelX variable
  if (TravelX < 0 || TravelX > 1350) {  // Make sure the position entered is not beyond the HOME or MAX position
    Serial.println("");
    Serial.println("Please enter a value greater than zero and smaller or equal to 1350.....");
    Serial.println("");
    Serial.print("Moving stepper into position: ");
    Serial.println(TravelX);
  stepperX.moveTo(TravelX);  // Set new moveto position of Stepper
  delay(1000);  // Wait 1 seconds before moving the Stepper
  if (TravelX >= 0 && TravelX <= 1350) {
// Check if the Stepper has reached desired position
  if ((stepperX.distanceToGo() != 0)) {
    stepperX.run();  // Move Stepper into position
// If move is completed display message on Serial Monitor
  if ((move_finished == 0) && (stepperX.distanceToGo() == 0)) {
    Serial.println("COMPLETED!");
    Serial.println("");
    move_finished=1;  // Reset move variable
  //  Light up the LCD backlight LEDS
  analogWrite(backlight_pin, 0);  // Set the Backlight intensity (0=Bright, 255=Dim)
  //  AccelStepper speed and acceleration setup
  stepper.setMaxSpeed(1200);  // Not to fast or you will have missed steps
  stepper.setAcceleration(200);  //  Same here
  // Draw starting screen on Nokia LCD
  u8g.firstPage();
 do {
  u8g.drawHLine(0, 15, 84);
  u8g.drawVLine(50, 16, 38);
  u8g.drawHLine(0, 35, 84);
  u8g.setFont(u8g_font_profont11);
  u8g.drawStr(0,10, "ENTER DISTANCE");
  u8g.drawStr(62, 29, "MM");
  u8g.drawStr(4, 46, "cur-pos");
  u8g.drawStr(57, 47, "Home");     //when hit Home switch
  while( u8g.nextPage() );
void loop(){
  char keypressed = keypad.getKey();  // Get value of keypad button if pressed
  if (keypressed != NO_KEY){  // If keypad button pressed check which key it was
    switch (keypressed) {
      case '1':
        checknumber(1);
      case '2':
        checknumber(2);
      case '3':
        checknumber(3);
      case '4':
        checknumber(4);
      case '5':
        checknumber(5);
      case '6':
        checknumber(6);
      case '7':
        checknumber(7);
      case '8':
        checknumber(8);
      case '9':
        checknumber(9);
      case '0':
        checknumber(0);
      case '*':
        deletenumber();
      case '#':
        calculatedistance();
void checknumber(int x){
  if (firstnumber == 99) { // Check if this is the first number entered
    firstnumber=x;
    String displayvalue = String(firstnumber);  //  Transform int to a string for display
    drawnokiascreen(displayvalue); // Redraw Nokia lcd
    if (secondnumber == 99) {  // Check if it's the second number entered
      secondnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber));
     if (thirdnumber == 99) {  // Check if it's the third number entered
      thirdnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber));
       } else {  // It must be the 4rd number entered
      fourthnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber)+ String(fourthnumber));
        Serial.println(keyfullnumber);
void deletenumber() {  // Used to backspace entered numbers
   if (fourthnumber !=99) {
    fourthnumber=99;
  if (thirdnumber !=99) {
    thirdnumber=99;
  else {
    if (secondnumber !=99) {
      secondnumber=99;
   else {
     if (firstnumber !=99) {
       String displayvalue = "";
       firstnumber=99;
void calculatedistance() {  // Used to create a full number from entered numbers
    if (fourthnumber == 99 && thirdnumber == 99 && secondnumber == 99 && firstnumber != 99 ) {
      keyfullnumber=firstnumber;
      movestepper(keyfullnumber);
    if (secondnumber != 99 && thirdnumber == 99 && fourthnumber== 99) {
      keyfullnumber=(firstnumber*10)+secondnumber;
    if (thirdnumber != 99 && fourthnumber==99) {
      keyfullnumber=(firstnumber*100)+(secondnumber*10)+thirdnumber;
      if (fourthnumber != 99) {
      keyfullnumber=(firstnumber*1000)+(secondnumber*100)+(thirdnumber*10)+fourthnumber;
    resetnumbers(); // Reset numbers to get ready for new entry
void movestepper(int z) {  //  Move the stepper
  int calculatedmove=((z*1600)/80);  //  Calculate number of steps needed in mm
  stepper.runToNewPosition(calculatedmove);
  currentposition = String(z);
  u8g.firstPage();
  do {
    u8g.drawStr(0, 10, "ENTER DISTANCE");
    u8g.setPrintPos(57,47);
    u8g.print(currentposition);
void resetnumbers() {  // Reset numbers for next entry
  firstnumber=99;
  secondnumber=99;
  thirdnumber=99;
  fourthnumber=99;
void drawnokiascreen(String y) {
    u8g.firstPage();
    do {
      u8g.setPrintPos(0,29);
      u8g.print(y);  // Put entered number on Nokia lcd
      u8g.print(currentposition);  //  Display current position of stepper
You're welcome.
Please remember to use code tags when posting code
Your post was MOVED to its current location as it is more suitable
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi kimort,
You din't know it yet. You should re-edit your first posting.
Posting so much code as plain text instead of a code-section is annoying.
look into this tutorial. Scroll down to the section where
re-editing
an existing posting is explained.
best regards Stefan
In place of your switch/case
  case '1':
    checknumber(1);
  case '2':
    checknumber(2);
  case '3':
    checknumber(3);
  case '4':
    checknumber(4);
  case '5':
    checknumber(5);
  case '6':
    checknumber(6);
You could might just
   checkNumber(keypressed - β€˜0’);
which uses the ASCII code of the character β€˜0’ to make the characters β€˜0’ through β€˜9’, conveniently placed in order in the ASCII table, to change the characters into their numerical equivalent.
a7
  if (keypressed >= '1' && keypressed <= '6')
What about the digits 0, and seven through nine?
The switch statement that @alto777 quoted only covered cases '1' to '6'.
