#include <MFRC522_I2C.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiClient.h>
//#include <MFRC522_I2C.h>
#include <ESP32_Servo.h>
Servo myservo1;
Servo myservo2;
MFRC522 mfrc522(0x28);
#define servoPin1 13 // Try GPIO5 instead of 13
#define servoPin2 5 // Try GPIO5 instead of 5
String Password = "";
#define LED_PIN 26
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 4
#define button1Pin 16 // Tlačidlo 1
#define button2Pin 27
String menuItems[] = { "LED", "Temperature", "Window", "Door" };
int menuSize = sizeof(menuItems) / sizeof(menuItems[0]);
int currentMenuIndex = 0; // Aktuálna položka menu
bool newButton1State = LOW; // Tlačidlo stlačené (LOW)
bool newButton2State = LOW;
bool button1State = HIGH;
bool button2State = LOW;
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
String item = "0";
//const char* ssid = "ChinaNet-2.4G-0DF0";
//const char* password = "ChinaNet@233";
const char* ssid = "iPhone";
const char* password = "C2o2lk9VUP";
WiFiServer server(80);
#include <Wire.h>
LiquidCrystal_I2C mylcd(0x27, 16, 2);
//#include < analogWrite.h >
#include "xht11.h"
xht11 xht(17);
#include <ESP32Tone.h>
#define buzzer_pin 25
//#define windowServo 5
//#define doorServo 13
#define waterPin 34
#define fanPin1 19
#define fanPin2 18
#define led_y 12 //Define the yellow led pin to 12
#define waterPin 34
#define gasPin 32
#define pyroelectric 14
unsigned char dht[4] = { 0, 0, 0, 0 }; //Only the first 32 bits of data are received, not the parity bits
//Servo channel
int channel_PWM = 13;
int channel_PWM2 = 10;
int freq_PWM = 50;
int resolution_PWM = 10;
const int PWM_Pin1 = 5;
const int PWM_Pin2 = 13;
int DoorState = 0;
int gasVal;
Serial.println("Run Baby");
mylcd.init();
mylcd.backlight();
pinMode(button1Pin, INPUT); // Nastavenie tlačidiel na vstup
pinMode(button2Pin, INPUT);
pinMode(led_y, OUTPUT);
pinMode(fanPin1, OUTPUT);
pinMode(fanPin2, OUTPUT);
ledcSetup(5, 1200, 8); //Set the frequency of LEDC channel 1 to 1200 and PWM resolution to 8, that is duty cycle to 256.
ledcAttachPin(fanPin2, 5); //Bind the LEDC channel 1 to the specified left motor pin GPIO26 for output.
pinMode(waterPin, INPUT);
pinMode(buzzer_pin, OUTPUT);
pinMode(gasPin, INPUT);
pinMode(pyroelectric, INPUT);
ledcSetup(channel_PWM, freq_PWM, resolution_PWM); //Set servo channel and frequency as well as PWM resolution.
ledcSetup(channel_PWM2, freq_PWM, resolution_PWM);
ledcAttachPin(PWM_Pin1, channel_PWM); //Binds the LEDC channel to the specified IO port for output
ledcAttachPin(PWM_Pin2, channel_PWM2); //Binds the LEDC channel to the specified IO port for output
Wire.begin();
mfrc522.PCD_Init();
ShowReaderDetails();
Serial.println(F("Scan PICC to see UID, type, and data blocks..."));
myservo1.attach(servoPin1, 500, 2400); // Attach servo at setup
myservo1.write(0);
myservo2.attach(servoPin2, 500, 2400); // Attach servo at setup
myservo2.write(0);
mylcd.setCursor(0, 0);
//mylcd.print("Card");
// Wservo.attach(windowServo);
// Dservo.attach(doorServo);
// #if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
// clock_prescale_set(clock_div_1);
// #endif
// // END of Trinket-specific code.
// strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
// strip.show(); // Turn OFF all pixels ASAP
// strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.begin();
Serial.println("TCP server started");
MDNS.addService("http", "tcp", 80);
mylcd.print("ip:");
mylcd.setCursor(0, 1);
mylcd.print(WiFi.localIP()); //LCD displays ip adress
delay(2000);
mylcd.print("SmartHouse");
mylcd.print("Richard Gero"); //LCD displays ip adress
delay(2000);
mylcd.clear();
mylcd.print(menuItems[currentMenuIndex]);
mylcd.print(menuItems[currentMenuIndex + 1]);
WiFiClient client = server.available();
if (!client) {
return;
while (client.connected() && !client.available()) {
delay(1);
String req = client.readStringUntil('\r');
int addr_start = req.indexOf(' ');
int addr_end = req.indexOf(' ', addr_start + 1);
if (addr_start == -1 || addr_end == -1) {
Serial.print("Invalid request: ");
Serial.println(req);
return;
req = req.substring(addr_start + 1, addr_end);
item = req;
Serial.println(item);
String s;
if (req == "/") //Browser accesses address can read the information sent by the client.println(s);
IPAddress ip = WiFi.localIP();
String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n< !DOCTYPE HTML >\r\n< html >ESP32 ip:";
s += ipStr;
s += "< /html >\r\n\r\n";
Serial.println("Sending 200");
client.println(s); //Send the string S, then you can read the information when visiting the address of E smart home using the browser.
//button
if (digitalRead(button1Pin) == LOW) {
Serial.println("Button1 Push");
menuItems[currentMenuIndex] = menuItems[currentMenuIndex + 1];
mylcd.clear();
if (digitalRead(button2Pin) == LOW) {
Serial.println("Button2 Push");
mylcd.clear();
//button end
if ((req == "/led/on") || (menuItems[currentMenuIndex] == "LED ON")) //Browser accesses address ip address/led/on
client.println("turn on the LED");
digitalWrite(led_y, HIGH);
if (req == "/led/off") //Browser accesses address ip address/led/off
client.println("turn off the LED");
digitalWrite(led_y, LOW);
if ((req == "/window/on") || (menuItems[currentMenuIndex] == "WINDOW OPEN")) {
mylcd.clear();
mylcd.print("Okno - otvorene");
myservo2.write(0);
client.println("open the window");
//ledcWrite(channel_PWM, 100);
//The high level of 20ms is about 2.5ms, that is, 2.5/20*1024, at this time, the servo angle is 180°.
//Wservo.write(175);
if ((req == "/window/off") || (menuItems[currentMenuIndex] == "WINDOW CLOSED")) {
mylcd.clear();
mylcd.print("Okno - Zatvorene");
myservo2.write(180);
client.println("close the window");
//ledcWrite(channel_PWM, 60);
//The high level of 20ms is about 0.5ms,that is, 0.5/20*1024,at this time, the servo angle is 0°.
//Wservo.write(0);
if ((req == "/music/on") || (menuItems[currentMenuIndex] == "MUSIC ON")) {
//client.println("play music");
if ((req == "/music/off") || (menuItems[currentMenuIndex] == "MUSIC OFF")) {
mylcd.clear();
mylcd.print("Hudba - OFF");
birthday();
noTone(buzzer_pin, 0);
mylcd.clear();
if ((req == "/buz/on") || (menuItems[currentMenuIndex] == "BUZZER ON")) {
client.println("buzzer");
tone(buzzer_pin, 392, 250, 0);
Serial.println("1");
if ((req == "/buz/off") || (menuItems[currentMenuIndex] == "BUZZER OFF")) {
mylcd.clear();
mylcd.print("Reprak - OFF");
client.println("off");
mylcd.clear();
if ((req == "/door/on") || (menuItems[currentMenuIndex] == "DOOR OPEN")) {
mylcd.clear();
mylcd.print("Dvere - otvorene");
client.println("open the door");
ledcWrite(channel_PWM2, 120);
myservo1.write(180);
if ((req == "/door/off") || (menuItems[currentMenuIndex] == "DOOR CLOSED")) {
mylcd.clear();
mylcd.print("Dvere - zatvorene");
client.println("close the door");
ledcWrite(channel_PWM2, 20);
myservo1.write(0);
if ((req == "/fan/on") || (menuItems[currentMenuIndex] == "FAN ON")) {
mylcd.clear();
mylcd.print("Ventilator");
mylcd.print("ON");
client.println("turn on the fan");
digitalWrite(fanPin1, LOW); //pwm = 0
ledcWrite(5, 100);
// mylcd.clear();
//The LEDC channel 1 is bound to the specified left motor output PWM value of 100.
if ((req == "/fan/off") || (menuItems[currentMenuIndex] == "FAN OFF")) {
mylcd.clear();
mylcd.print("OFF");
client.println("turn off the fan");
ledcWrite(5, 0);
// mylcd.clear();
//The LEDC channel 1 is bound to the specified left motor output PWM value of 0.
if (req == "/red/on") {
client.println("red on");
colorWipe(strip.Color(255, 0, 0), 50);
if (req == "/red/off") {
client.println("red off");
colorWipe(strip.Color(0, 0, 0), 50);
if (req == "/orange/on") {
client.println("orange on");
colorWipe(strip.Color(200, 100, 0), 50);
if (req == "/orange/off") {
client.println("orange off");
if (req == "/yellow/on") {
client.println("yellow on");
colorWipe(strip.Color(200, 200, 0), 50);
if (req == "/yellow/off") {
client.println("yellow off");
if (req == "/green/on") {
client.println("green on");
colorWipe(strip.Color(0, 255, 0), 50);
if (req == "/green/off") {
client.println("green off");
if (req == "/cyan/on") {
client.println("cyan on");
colorWipe(strip.Color(0, 100, 255), 50);
if (req == "/cyan/off") {
client.println("cyan off");
if (req == "/blue/on") {
client.println("blue on");
colorWipe(strip.Color(0, 0, 255), 50);
if (req == "/blue/off") {
client.println("blue off");
if (req == "/purple/on") {
client.println("purple on");
colorWipe(strip.Color(100, 0, 255), 50);
if (req == "/purple/off") {
client.println("purple off");
if (req == "/white/on") {
client.println("white on");
colorWipe(strip.Color(255, 255, 255), 50);
if (req == "/white/off") {
client.println("white off");
if (req == "/sfx1/on") {
client.println("sfx1 on");
rainbow(10);
if (req == "/sfx1/off") {
client.println("sfx1 off");
if (req == "/sfx2/on") {
client.println("sfx2 on");
theaterChaseRainbow(50);
if (req == "/sfx2/off") {
client.println("sfx2 off");
if ((req == "/rain/on") || (menuItems[currentMenuIndex] == "RAIN ON")) {
mylcd.clear();
int rainVal = analogRead(waterPin);
mylcd.print(rainVal);
client.println(rainVal);
if ((req == "/rain/off") || (menuItems[currentMenuIndex] == "RAIN OFF")) {
while ((req == "/gas/on") || (menuItems[currentMenuIndex] == "GAS ON")) {
mylcd.clear();
gasVal = analogRead(gasPin);
if (gasVal <= 300) {
Serial.print("GasVal: ");
Serial.println(gasVal, DEC);
client.print(" safety");
mylcd.print(" Bezpecie");
if (gasVal > 300 && gasVal <= 1000) {
client.print(" Warning");
mylcd.print(" Pozor");
beep(1000, 200); // Keep it ON for 100ms
/*tone(buzzer_pin, 294, 250, 0);
delay(1);
delay(1);*/
if (gasVal > 1000) {
client.print(" Dangerous");
mylcd.print(" Nebezpecne");
delay(1);
delay(1);*/
mylcd.print(gasVal, DEC);
delay(300);
if ((req == "/gas/off") || (menuItems[currentMenuIndex] == "GAS OFF")) {
mylcd.clear();
mylcd.clear();
if ((req == "/body/on") || (menuItems[currentMenuIndex] == "BODY ON")) {
mylcd.clear();
mylcd.print("PIR Stav");
boolean pyroelectric_val = digitalRead(pyroelectric);
if (pyroelectric_val == 1) {
mylcd.print("Pohyb detekovany");
client.println("someone");
mylcd.print("Ziaden pohyb");
client.println("no one");
//mylcd.setCursor(0, 1);
//mylcd.print(pyroelectric_val);
if ((req == "/body/off") || (menuItems[currentMenuIndex] == "BODY OFF")) {
if ((req == "/temp/on") || (menuItems[currentMenuIndex] == "TEMP ON")) {
if (xht.receive(dht)) {
mylcd.clear(); //Returns true when checked correctly
mylcd.print("Teplota:");
mylcd.print(dht[2]); //The integral part of temperature, DHT [3] is the fractional part
mylcd.print("C");
Serial.print("Temp:");
Serial.print(dht[2]); //The integral part of temperature, DHT [3] is the fractional part
Serial.println("C");
delay(200);
} else { //Read error
Serial.println("sensor error");
client.println(dht[2]);
delay(1000); //It takes 1000ms to wait for the device to read
if ((req == "/temp/off") || (menuItems[currentMenuIndex] == "TEMP OFF")) {
if ((req == "/humidity/on") || (menuItems[currentMenuIndex] == "HUMIDITY ON")) {
mylcd.clear();
mylcd.print("Vlhkost");
if (xht.receive(dht)) { //Returns true when checked correctly
Serial.print("Humidity:");
Serial.print(dht[0]); //The integral part of temperature, DHT [3] is the fractional part
mylcd.print(dht[0]);
mylcd.setCursor(5, 1);
mylcd.print("%");
Serial.println("%");
delay(200);
client.println(dht[0]);
if ((req == "/humidity/off") || (menuItems[currentMenuIndex] == "HUMIDITY OFF")) {
// Kontrola tlačidla 1 pre posun v menu
if (newButton1State && !button1State) {
currentMenuIndex = (currentMenuIndex + 1) % menuSize; // Posun v menu
mylcd.clear();
mylcd.print(menuItems[currentMenuIndex]); // Zobrazenie aktuálnej položky
mylcd.print(menuItems[(currentMenuIndex + 1) % menuSize]); // Ďalšia položka
delay(200); // Odrušenie preťaženia
// Kontrola tlačidla 2 pre výber aktuálnej položky
/*if (newButton2State && !button2State) {
mylcd.clear();
mylcd.print("Selected:");
mylcd.print(menuItems[currentMenuIndex]); // Zobrazenie zvolenej položky
handleMenuSelection(); // Funkcia na spracovanie výberu
// Aktualizácia predchádzajúcich stavov tlačidiel
/*newButton1State = digitalRead(button1Pin) == LOW; // Tlačidlo stlačené (LOW)
newButton2State = digitalRead(button2Pin) == LOW;
button1State = newButton1State;
button2State = newButton2State;*/
//client.stop();
if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
delay(50);
Password = "";
//Serial.println ("Reading the card");
return;
Serial.print(F("Card UID:"));
Password = "";
for (byte i = 0; i < mfrc522.uid.size; i++) {
//Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i]);
Password += String(mfrc522.uid.uidByte[i]);
Serial.println(); // New line after UID print
//if (Password == "42 141 63 181") {
if (Password == "4214163181" && DoorState == 0) {
Serial.println("Access granted: Opening door");
mylcd.clear();
mylcd.print("Otvorene");
DoorState = 1;
myservo1.attach(servoPin1, 500, 2400); // Ensure servo is attached
delay(2000); // Wait before closing
myservo1.write(0);
myservo1.detach(); // Detach to prevent jitter
} else if (Password == "4214163181" && DoorState == 1) {
Serial.println("Access granted: Closing door");
mylcd.clear();
mylcd.print("Zatvorene");
DoorState = 0;
myservo1.write(0);
myservo1.write(0);
Serial.println("Access denied");
mylcd.clear();
mylcd.print("error");
delay(2000);
Password = "";
void birthday() {
tone(buzzer_pin, 294, 250, 0); //The four parameters are pin, frequency, delay and channel
tone(buzzer_pin, 440, 250, 0);
tone(buzzer_pin, 532, 250, 0);
tone(buzzer_pin, 494, 250, 0);
tone(buzzer_pin, 587, 250, 0);
tone(buzzer_pin, 784, 250, 0);
tone(buzzer_pin, 659, 250, 0);
tone(buzzer_pin, 698, 250, 0);
tone(buzzer_pin, 532, 500, 0);
void colorWipe(uint32_t color, int wait) {
for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
// Rainbow cycle along whole strip. Pass delay time (in ms) between frames.
void rainbow(int wait) {
for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show(); // Update strip with new contents
// Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
void theaterChaseRainbow(int wait) {
int firstPixelHue = 0; // First pixel starts at red (hue 0)
for (int a = 0; a < 30; a++) { // Repeat 30 times...
for (int b = 0; b < 3; b++) { // 'b' counts from 0 to 2...
strip.clear(); // Set all pixels in RAM to 0 (off)
// 'c' counts up from 'b' to end of strip in increments of 3...
for (int c = b; c < strip.numPixels(); c += 3) {
int hue = firstPixelHue + c * 65536L / strip.numPixels();
uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue - > RGB
strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
void handleMenuSelection() {
if (menuItems[currentMenuIndex] == "LED") {
Serial.println("LED selected");
// Pridaj kód na spracovanie výberu LED
} else if (menuItems[currentMenuIndex] == "Temperature") {
Serial.println("Temperature selected");
// Pridaj kód na spracovanie teploty
} else if (menuItems[currentMenuIndex] == "Window") {
Serial.println("Window selected");
// Pridaj kód na spracovanie okna
} else if (menuItems[currentMenuIndex] == "Door") {
Serial.println("Door selected");
// Pridaj kód na spracovanie dverí
void ShowReaderDetails() {
byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
Serial.print(F("MFRC522 Software Version: 0x"));
Serial.print(v, HEX);
if (v == 0x91)
Serial.print(F(" = v1.0"));
else if (v == 0x92)
Serial.print(F(" = v2.0"));
Serial.print(F(" (unknown)"));
Serial.println("");
if ((v == 0x00) || (v == 0xFF)) {
Serial.println(F("WARNING: Communication failure, check connections"));
void beep(int frequency, int duration) {
ledcAttachPin(buzzer_pin, 1);
ledcWriteTone(1, frequency);
delay(duration);
ledcWriteTone(1, 0);
You could clean it up a bit more, like have separate functions (with descriptive names) for initializing your buttons, LCD and servo, maybe another for the WiFi stuff. I see you also have stuff for your password, which can also be its own function call. It would probably be best to make a copy of the sketch first, this way if something does go wrong, you don't lose a working version.
You can do the same for everything in the loop and have separate functions for those parts too.
Make it readable for someone who has no idea about coding, than can go through and at least understand what each part does based on the name of the function.
A lot of lines like this "(req == "/led/on")" can probably be moved into a switch statement instead of IF statements.
Things like that can make a big difference.
Maybe not a good idea to share your passwords...
Why? Its only a hotspot through a phone, and the whole smarthouse thingy is in a miniature form, its my graduation project.
Since you did not develop the menu logic as the beginning part of your program, I suggest you write a completely separate program to develop, test and debug your menu system. Then incorporate that menu logic to your existing program.
Been there, done that, and apparently failed too.
It's not about the seriousness, it's just that you don't do it. For all I care, put up posters where you live with your hotspot login, but don't do it here. Hard to grasp I know, but you can do it.
Why argue with people offering help? Rather odd way to get help. Why if you "have a working code" do you need help correcting it? What does it do? What does it not do? From where did you copy it? Why did you comment-out the Neopixel object initialization but leave the code?
