Hi, can someone help me with downloading the program
My board keeps saying that it can not download. The board is an duemilanove or diecimila
Here is the message:
Arduino: 1.6.6 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Sketch uses 3,088 bytes (10%) of program storage space. Maximum is 30,720 bytes.
Global variables use 198 bytes (9%) of dynamic memory, leaving 1,850 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xef
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Thanks.
michal1503:
Which is it? Where did you buy it?
Depending on how old it is, you may need to change to the "Board Options" to ATmega168
michal1503:
This is a good hint.
It dose not say which one specifically it just says It a Duemilanove or Diecimila.It also says that it is Based on ATMEGA328 surface mount chip (Uno design) and L298P H Bridge and I bought it from robotshop.com as a DFRobotShop Rover V2 - Arduino Compatible Tracked Robot (Autonomous Dev Kit).
Thanks for the help.
You need to include a link, or contact the seller's technical support team.
michal1503:
The DFRobotShop Rover V1.5 is essentially a standard Arduino Duemilanove board while the
DFRobotShop Rover V2.0 is essentially a standard Arduino Uno board. All code and examples found on
www.arduino.cc can be used.
First off is it V1.0, V1.5 or V2.0
http://www.robotshop.com/media/files/pdf/dfrobotshop-rover-user-guide.pdf
If its a v2.0 try selecting UNO as the actual board. and not Duemilanove.
It looks like a pretty neat toy
not in sync resp 0xEF? Dollars to donuts, you're trying to upload with the wrong speed, probably because it's using the Uno bootloader (optiboot) at 115200 baud, and you've got the Duemillanove selected, which uses the old crappy bootloader that operates at 19200 baud, so it's trying to talk at 19200. Nowadays, people almost always bootload '328 based boards with optiboot, because it's just plain better; it's faster, and more importantly, uses 512b of flash, instead of 2048.
