Hi guys, i have problem with BTS 7960
I connected Arduino, BTS 7960, Flysky i6, at first, I turned the joystick, the motor ran, I didn’t switch joystick, the motor didn’t run. After a while, I didn’t control joystick and the motor was still running.
this is my code
#include <Arduino.h>
#define pinLeft_R_EN A1
#define pinLeft_L_EN A0
#define pinLeft_R_PWM 9
#define pinLeft_L_PWM 10
#define pinRight_R_EN A3
#define pinRight_L_EN A2
#define pinRight_R_PWM 3
#define pinRight_L_PWM 11
#define pinRemoteSteer 5 // PCINT21
#define pinRemoteSpeed 6 // PCINT22
// motor speed
#define motorSpeedMax 255
#define motorMowSpeedMax 255
// R/C measurement
int remoteSteer ; // range -100…100
int remoteSpeed ; // range -100…100
unsigned long remoteSteerLastTime ;
unsigned long remoteSpeedLastTime ;
boolean remoteSteerLastState ;
boolean remoteSpeedLastState ;
unsigned long nextInfoTime = 0;
// BTS7960 motor driver
//(8-bit PWM=255, 10-bit PWM=1023)
// IN1 PinPWM IN2 PinDir
// PWM L Forward
// nPWM H Reverse
void setBTS7960(int pinR_PWM, int pinL_PWM, int speed){
if (speed < 0){
digitalWrite(pinR_PWM, HIGH) ;
analogWrite(pinL_PWM, 255-((byte)abs(speed)));
digitalWrite(pinR_PWM, LOW) ;
analogWrite(pinL_PWM, ((byte)speed));
int rcValue(int ppmTime){
int value = (int) (((double)((ppmTime) - 1500)) / 3.4);
if ((value < 5) && (value > -5)) value = 0;
return value;
// RC remote control driver
void setRemotePPMState(unsigned long timeMicros, boolean remoteSpeedState, boolean remoteSteerState){
if (remoteSpeedState != remoteSpeedLastState) {
remoteSpeedLastState = remoteSpeedState;
if (remoteSpeedState) remoteSpeedLastTime = timeMicros; else remoteSpeed = rcValue(timeMicros - remoteSpeedLastTime);
if (remoteSteerState != remoteSteerLastState) {
remoteSteerLastState = remoteSteerState;
if (remoteSteerState) remoteSteerLastTime = timeMicros; else remoteSteer = rcValue(timeMicros - remoteSteerLastTime);
// remote control (RC) ppm signal change interrupt
ISR(PCINT2_vect){
unsigned long timeMicros = micros();
boolean remoteSpeedState = digitalRead(pinRemoteSpeed);
boolean remoteSteerState = digitalRead(pinRemoteSteer);
setRemotePPMState(timeMicros, remoteSpeedState, remoteSteerState);
void setup(){
Serial.begin(115200); // setup baud rate
pinMode(pinLeft_R_EN, OUTPUT);
pinMode(pinLeft_L_EN, OUTPUT);
pinMode(pinLeft_R_PWM, OUTPUT);
pinMode(pinLeft_L_PWM, OUTPUT);
pinMode(pinRight_R_EN, OUTPUT);
pinMode(pinRight_L_EN, OUTPUT);
pinMode(pinRight_R_PWM, OUTPUT);
pinMode(pinRight_L_PWM, OUTPUT);
// enable outputs
digitalWrite(pinLeft_R_EN, HIGH);
digitalWrite(pinLeft_L_EN, HIGH);
digitalWrite(pinRight_R_EN, HIGH);
digitalWrite(pinRight_L_EN, HIGH);
// R/C (enable interrupts)
pinMode(pinRemoteSteer, INPUT);
pinMode(pinRemoteSpeed, INPUT);
attachInterrupt(pinRemoteSpeed, PCINT2_vect, CHANGE);
attachInterrupt(pinRemoteSteer, PCINT2_vect, CHANGE);
//---------------------------------------------- Set PWM frequency for D9 & D10 ------------------------------
TCCR1B = TCCR1B & B11111000 | B00000001; // set timer 1 divisor to 1 for PWM frequency of 31372.55 Hz
//TCCR1B = TCCR1B & B11111000 | B00000010; // set timer 1 divisor to 8 for PWM frequency of 3921.16 Hz
//---------------------------------------------- Set PWM frequency for D3 & D11 ------------------------------
TCCR2B = TCCR2B & B11111000 | B00000001; // set timer 2 divisor to 1 for PWM frequency of 31372.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000010; // set timer 2 divisor to 8 for PWM frequency of 3921.16 Hz
// R/C
PCICR |= (1<<PCIE2);
PCMSK2 |= (1<<PCINT21);
PCMSK2 |= (1<<PCINT22);
/unsigned long endTime = millis() + 2000;
while (millis() < endTime){
setMC33926(pinMotorLeftDir, pinMotorLeftPWM, -127);
setMC33926(pinMotorRightDir, pinMotorRightPWM, 127);
delay(100);
void loop(){
// R/C conversion to motor speed (left/right)
float steer = ((double)motorSpeedMax/2) * (((double)remoteSteer)/100.0);
if (remoteSpeed < 0) steer *= -1;
int motorLeftSpeed = ((double)motorSpeedMax) * (((double)remoteSpeed)/100.0) - steer;
int motorRightSpeed = ((double)motorSpeedMax) * (((double)remoteSpeed)/100.0) + steer;
motorLeftSpeed = max(-motorSpeedMax, min(motorSpeedMax, motorLeftSpeed));
motorRightSpeed = max(-motorSpeedMax, min(motorSpeedMax, motorRightSpeed));
setBTS7960(pinLeft_R_PWM, pinLeft_L_PWM, motorLeftSpeed);
setBTS7960(pinRight_R_PWM, pinRight_L_PWM, motorRightSpeed);
if (millis() >= nextInfoTime){
nextInfoTime = millis() + 1000; // choose time interval here
// serial console output
Serial.print(“steer=”);
Serial.print(remoteSteer);
Serial.print(" speed=");
Serial.print(remoteSpeed);
Serial.print(" mleft=");
Serial.print(motorLeftSpeed);
Serial.print(" mright=");
Serial.print(motorRightSpeed);
//delay(15);
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.... :slight_smile:
