Hi Guys ! :) want to start a project need guidlines
Hi, so my project would be somthing Relativly, simple to some of you i guess,
i'd like to have 3 on\off switches, 1, push switch, RGB Led's, and small Speakers,
phase 1: I want the switches to turn on the RGB, with a set of animation, (let's say blinking red for one switch,blue wave for another, and constant green for the third)
phase 2: i want the push switch to turn on a sound when i press it down, and a diffrent sound when i press it up.
phase 3: when the animations for the switches will take place i want to activate a sound between some random sounds.
i know it's a really difficult project to start with .. but hey.. life isn't easy...
so i don't really know on what to buy for that project, can you help me with what to buy and how to do all of that ?
(in the final real project i'll do it will have to input around 20 switches some on\off, some push... so it's better if i buy the gear to support the final project)
thnx guys !!! your the best !
I've only started with the Arduino a week ago myself, and I'd strongly suggest to complete a few basic tutorials before you jump in to the deep, if you are new to electronics/Arduino.
You could then build on top of the samples to do what's needed for your project:
See these for example -
http://www.arduino.cc/en/Tutorial/Button http://www.arduino.cc/en/Tutorial/Tone
You need to know some other essential bits beforehand as well, like button debounce for example - http://www.arduino.cc/en/Tutorial/Debounce
Good luck!
Milko: Hi,
Good luck!
thnx !!!!! :)
You have a number of basic tasks that need to be done and combined.
A Uno would be a good basic to start on.
You should start by using the learning information supplied on this site. Work out how to do each thing on its own then add together.
Read up on how to connect devices to output pins and input pins.
Weedpharma
