hi i have a problem about tlc5940 's blank function.. help..
hi i make 8x8 led display by using tlc 5940 pwm controller and 74595 shift register.
but bleeding is occured. so i think this is because of randomly blank wave like this osciloscope image.
wave1 is blank wave, 2 is 74595’s one pin output, 3 is 74595 latch.
this image shows that wave 1(blank wave) is randomly occured.
i don’t know why the wave is randomly occured…
and i want this wave occured periodically based on my source code.
please help… ( i’m really sorry that my English skill is very bad…)
and this is arduino source code
#include <Tlc5940.h>
#include <tlc_config.h>
#include <tlc_shifts.h>
#include <tlc_fades.h>
int DataPin=7;
int LatchPin=6;
int ClockPin=5;
byte row[8]={B00000001,B00000010,B00000100,B00001000,B00010000,B00100000,B01000000,B10000000};
double col[8][8] ={{0,0,0,0,0,0,0,0}, {0,4000,4000,0,0,4000,4000,0},{4000,4000,4000,4000,4000,4000,4000,4000},{4000,4000,4000,4000,4000,4000,4000,4000},{0,4000,4000,4000,4000,4000,4000,0},{0,0,4000,4000,4000,4000,0,0},{0,0,0,4000,4000,0,0,0},{0,0,0,0,0,0,0,0}};
void setup(){
  Tlc.init(0);
  pinMode(LatchPin,OUTPUT);
  pinMode(ClockPin,OUTPUT);
  pinMode(DataPin,OUTPUT);
   for(int i=0;i<8;i++){
   digitalWrite(LatchPin,LOW);
   shiftOut(DataPin,ClockPin,LSBFIRST,row[i]);
   digitalWrite(LatchPin,HIGH);
   for(int a=1;a<9;a++){
     Tlc.set(a,col[i][a-1]);
   digitalWrite(10,LOW);
   Tlc.update();
    digitalWrite(10,HIGH);
   delay(1);
Post a wiring diagram!
thank you for your replying!!!
i’m really sorry that i don’t have any ‘wire diagram’ using specific tools…
so i made self wire diagram attached by using my pen…
i really appreciate if you reply my question!!
thank you very much!!!
2 is 74595's one pin output
If you mean QA by "74595's one pin output", the following line must be changed
to
shiftOut(DataPin,ClockPin,MSBFIRST,row[i]);
wave1 is blank wave
Does that mean D10?
   Tlc.update();
You must not touch pin D10 if you use the Tlc5940.h library as the library is handling that pin.
